Page 1 of 23 12311 ... LastLast
Results 1 to 40 of 913
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    2013 audi s5 6466 turbo s-tronic
    Hi everyone,
    My name is Oleg I bought this 2013 Audi S5 DSG with 14K Miles on it fully loaded. Engine was hydro locked, cylinder number 3 had cracked piston and bended Conrod. This is a good time to start real build of 3.0T engine with turbo setup plus stock supercharge. I'm looking to get from this setup around 600-800whp. let's see how much power can take S-Tronic . Just wanted to share this information and data with all of you
    Currently stock block with 6466 SINGLE TURBO
    TESTED BEFORE 187mm / 57.5mm Pulley tuned by 034Motorsport Stage 2+ Car run 11.9 / 113mph had Issue on E40 file peak boost was 18psi with opened bypass valve.
    2018 UPDATE : J-FONZ CUSTOM TUNE
    Forged Engine is getting rebuild over the winter
    Thanks a lot to Caste Systems Performance _ Fonse Performance _ 034Motorsport
    Special thanks to my buddy Motvey!!!!!!!!!!
    Check Facebook group for latest updates " Boosted World "
    Instagram "@svarog_performance"
    Also ask me about my custom Chiller setup is ready for sale with all accessories high quality solenoids
    2013 AUDI S5 S-Tronic 14K miles on it
    J-Fonz Custom tune Single Turbo
    J-Fonz S-Tronic Tune
    3.0 TFSI Engine Stock
    Custom made turbine manifold with 2" SS
    Precision 6466 V band Turbo upgraded to Garrett 66.3mm/67mm turbo
    Precision 46mm wastegate
    3.5" Down Pipe
    3.5" Middle pipe
    2.5" Cat Back
    3.5” Cutout
    Custom made Cold Air Intake
    K&N Cold Air Filter
    H&R Coilovers
    Cortex Boost controller
    Water/Meth 750cc controlled by Cortex unit
    Innovate SCG-1 AFR/Boost
    Stock S-Tronic with Stage 3 Clutch Pack Kit good for over 1200Nm+
    Custom Dual Supercharger water cooler
    1000 HP Water To Air intercooler
    Custom Chiller A/C Refrigerants for Supercharger Cooling
    Custom Transmission oil cooler
    Custom Oil cooler
    Custom Crankcase ventilation with Catch Can
    Custom made A/C Chiller for supercharger
    Two electronics solenoid for 100% cooling mode " Track Use Only " water is below 0 on this mode!
    Autotech High Volume Fuel Pump Upgrade
    Water meth injection
    E85 Bluetooth Ethanol Content Analyzer
    Dual Walbro 525 Main fuel pumps
    S4 B5 Intake manifold with 850cc additional port injectors
    Microsquart V3 Fuel injectors controller
    Torqbyte MP4 Pump controller
    8AN Fuel Feed line
    034 Transmision/Rear Diff inserts kit
    034 Billet Engine Mount
    CanSensor OBD In OIL PRESSURE / WATER TEMP / E85 ANALYSER / BOOST / BYPASS / IAT etc...
    Front 6 pot from Q7/RS5 calipers and 375mm brake rotor
    Custom Rear 4pot Brembo calipers with 356mm brake rotor
    18x10.5 Enkei GTC02 +35
    Nitto NT05 275/35/18
    Svarog Chiller and CANSensor
    Bone stock C63 S and heavy modified S5
    E35 26 psi Single Turbo 6466 fuel issue up top
    My previous builds
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    wow......this will be serious. kudos to you!
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Shit is about to get real...real crazy.
    Jan 09 2010
    New York
    Quote Originally Posted by d1amund View Post
    Quote Originally Posted by chrissurfr View Post
    Here is more porn pictures )
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    Subscribed. Really looking forward to seeing the outcome on this.
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Jan 09 2010
    New York
    More pictures
    Jan 06 2008
    Dacia Sandero
    Arizona
    Crazy - in for more updates on this
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Established Member Two Rings DburrellA4's Avatar
    Jun 20 2009
    2003 Audi A4, 2012 Evo X (RIP) 2013 Audi S5
    Bremerton
    Im here for the ride!
    2013 Audi S5
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    You're going to paint that front beam, right?
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jan 09 2010
    New York
    Quote Originally Posted by HazeMyth View Post
    Yes Sir , over the winter I'm planning to install build motor and huge custom front heat exchanger
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    Wow Subscribed ! Cant wait to see the outcome ��
    2014 Brilliant Black | 034 Motorsports filter | 034 DSG Tune | Black Fine Nappa Leather | Prestige | 7 Speed S-Stronic | Apr tune | Roc Euro Intake | X pipe Exhaust | Akebono Brake Pads | Deval CF Rear Diffuser | ECS Spacer Flush kit 10F 12.5R |
    Aug 04 2010
    Queenz/Westchester
    Wow, would love to see this in person. APR who? That side by side downpipe pic looks like Bruce banner next to the Hulk! Subbed!
    Oct 09 2008
    Came in ready to laugh, left impressed. Can't wait to see how this turns out.
    The Awesome™
    Established Member Two Rings johnwpowell's Avatar
    Apr 13 2014
    VA
    Paint that crash bar!
    Jan 16 2011
    irvington nj
    Nice, can't wait til it's done. Wish I could snag a S5/A5 with a blown motor.
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    Quote Originally Posted by UkuRiSh View Post
    Did you bake your housing open? I'm sure there's a few people who would like to know your process for this...it's a lot cheaper than buying ecodes. Also, sub'ed for your progress!!!
    Drew
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Wow....
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Don't we already know the DSG can't handle much more power over stock (or rather over stage 2)? That's why Audi doesn't use them in their higher end cars?
    With that said, this is awesome. Best of luck and keep us updated.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Jan 09 2010
    New York
    Quote Originally Posted by drdrewusaf View Post
    Drew
    Very easy ! First take off all black metal clips around the headlights then use a stove to heat headlights up to 180-200F, pull one side of the headlights cover done! same way heat up headlights and put back together make sure is sealed praporly.
    Jan 09 2010
    New York
    Quote Originally Posted by LordMagnet View Post
    Stock tranny would not hold my power but upgraded transmission coolant and set of All NEW 15 Plate High Performance Clutch should take care of it.
    http://www.sspperformance.com/audi-s...h-package.html
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Nice and clean install, good luck with the project. Who made the rods/pistons?
    Fonse Performance (Al Jr.) built my friend and I our Volvo motors a few years back, good guys.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Nov 26 2015
    79' FJ-40, Ducati 1299s, 12' R1 (race bike), KTM 250, American IronHorse custom chopper
    Detroit Mi
    sub'd
    15' S5 Mythos, S-tronic, Alu-Optic, sport diff, adaptive suspension, driver assist, Tech, heated mirrors/seats, black nappa, B&O
    AWE Touring, GIAC St.2, AWE CAI carbon
    Aug 05 2011
    LI, NY
    Best of luck with build. Didn't think there was that much room back there for a turbo, what turbo you squeeze back there?If your going to run E85 hopefully you're putting in larger injectors/fuel pump. E85 takes about 1.5 times more fuel but it's the way to go. Going to be running in in my 3000GT VR4 this year. Hoping for 800+AWHP
    2019 RS5
    2013 Audi S5 Estoril Blue - SOLD
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
    Oct 27 2014
    Park City, UT
    2013 AUDI S5 SUPERCHARGER + 6466 TURBO BUILD ENGINE &quot; TwinCharger &quot;
    I need new friends...
    Feb 22 2015
    PA
    someone please do this and post up more detailed pics so i can follow. i need this mod.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by godzill435 View Post
    There's a diy in the b7 a4 section. The process sounds exactly the same.
    OP, yet another awesome build. Your B7 was drool worthy.
    -Adam
    Jan 09 2010
    New York
    Quote Originally Posted by RWD2quattro View Post
    Thanks a lot, rods was custom designed with my specs and produced in China. Al Jr. from ( Fonse Performance ) doing a great work and this is my third engine i'm doing there.
    Al Jr. should place the order for custom pistons shortly i believe we going with JE set
    Quote Originally Posted by oohnoo View Post
    In europe they have V6 TDI A5! I did same style of turbo mounting, car was designed for Turbo) I got Precision CEA 6466 V-Band 2 Gen. I know about E85, I'm planning to make 550-650whp for the first year this should be enough for stock fuel and then i will push over 700whp+ with upgrading fuel system and etc.
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    epic build...
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Jun 17 2013
    jersey city nj
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Putting in work!!!
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Aug 04 2010
    Queenz/Westchester
    Perhaps the answer to whether s-tronic can handle a supercharged RS5....
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    Holy shit. Can't wait to see the results.
    Jan 11 2007
    Salt Lake City, Utah
    Subb'd for another crazy build.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Detailed write up in the B8 A4 section as well.
    DIY J-Code tinted front reflectors
    http://www.audizine.com/forum/showthread.php?t=319845
    Sent from the Pedal Responce Emergency Bat Phone
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Dude this is awesome. Waiting and watching
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Can't wait for the outcome either. Sub'd!
    Sent from my mind
    Apr 04 2012
    MSP
    Atta boy!
    Good luck with the build! Hope everything comes together...
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    Subscribed! This could be epic.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Oct 27 2011
    TOYS
    Philly Suburbs
    About time you posted this build! Interested to see where the stock roots blower becomes very restrictive. You running meth injection too right?
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Awesome!
    2021 Audi S4, P34 Intake
