Results 1 to 13 of 13
    Established Member Two Rings hacgumyu's Avatar
    Jan 05 2010
    Swapping Used Stock ECM questions
    Swapping Used Stock ECM / Part revision # matters?
    I need to replace the ECM on my 3.2 due to P0106 Baro sensor(F96) inside the ECM went bad. Computer reading found F96 at idle(measure block 113) requested 1000 mBar but actual only 902 mBar which range discrepancy over >80 will cause MIL ON
    Stealership quote whooping $1900 OTD. I lookup youtube there is DIY how to easily swap it out, and there are plenty used matching ECM on ebay.
    1. Does part number must matched including the revision letter ex: 8E0910559A (2005.5) vs 8E0910559J (2008), both design for B7 3.2L just different manufactured date...
    2. Will Audi do the reprogramming/transfer soft code from bad ECM to the replacement Used ECM ( I will paid labor hour) ?
    3. If Audi won't do it, how to retrive the Secret Code so I can try with VCDS?
    4. What Immobilizer version is on B7 3.2 and is it harder to adapt even with the SC key?
    I don't have any tunes or coding that I'm afraid to lose, but definitely don't want to hack cluster to risk bricking the whole thing.
    thanks all
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    For the parts I would normally recommend europa parts. They're a forum sponsor here on the east coast. Since you're out in the north west though, I have to recommend hitting up Jeremy at Matrix Integrated. He's always been great to me and they're located in Portland, so they can probably get you the part quicker.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jun 27 2011
    You mean MAF sensor right? MAPs are for turbocharged cars so they can read intake charge pressure for the turbo.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 05 2010
    I am confused too.. mine B7 is 3.2L but the shop say it's MAP
    Jan 05 2010
    anyone know the part number? is it a MAF or MAP sensor on 3.2L engine?
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    There is a MAP sensor on the 3.2. If the shop scanned your car with VCDS they should have given you a different fault code rather that a p0xxx fault, such as a 16490 fault. If that is in fact the fault it could just be a vacuum leak, or loose intake tube etc causing the fault. It could as well be a faulty sensor too. If you want to replace the sensor the part # is 03C906051F. A brand new OEM sensor from the dealer is $80 or so, and it's 2 bolts holding it to the intake so a shop quoting you $300 seems pretty high to me.
    Oct 24 2015
    Perth, WA
    If it were me id get the Bosch and DIY it https://www.ecstuning.com/Audi-B7_A4....2L/ES2678229/
    My respray thread
    Jan 05 2010
    I'm going to buy the sensor and diy first. Attached VCDS scan report below
    Mar 24 2013
    Oakdale, CT
    As stated above, the 3.2 has a MAP sensor. It does not have a MAF sensor and operates on a speed/density style tune. MAP stands for manifold absolute pressure. While the 3.2 does not operate in boost like a turbo car does, it most definitely will operate at varying levels of manifold vacuum depending on throttle and engine load.
    -Adam
    Jan 05 2010
    I finally located the MAP sensor on my 3.2L, right under the plastic center cap cover.
    It has a code reads : 0 261 230 095, while the current MAP sensor have newer part # as below. So i guess my MAP sensor is pretty old and needs to replace. Found a seller on Amazon selling for $30 shipped http://www.amazon.com/gp/product/B00BJLGYOU
    Bosch #: 0 261 230 234
    OE #: 03C 906 051 F
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    ll Audi Sport "Vorsprung Durch Technik"
    Jun 27 2011
    Huh. Learn something new everyday I suppose.
    -CP
    2017 Q7 3.0t
    Jan 05 2010
    updated original post
