On another note, do you have wood flooring in your garage?
Lol, you are not the first who asks me about that floor
the previous owner of the house did some wood work or something in the garage, so he put that plastic carpet in there. Itīs not the best choice for the floor, but since there is no possibility to use water, I left it there. And itīs quite easy to keep clean, if the car leaks oil or something
And no, I donīt have any spacer.
I just thought that if the engine is little more back in the engine bay, it helps with the clearence between engine and subframe. But in the other hand, the distance between engine mounts and transmission mounts should be same in all swaps, so it has an effect on many things.
But I donīt want to mess this thread too much with this, so no more of that
