Results 1 to 9 of 9
    Jan 10 2016
    San Diego, CA
    2010 A4 "Low Oil Pressure - Turn Off Engine
    Got the dreaded "Low Oil Pressure - Turn Off Engine" on my display. I checked the oil pressure at idle = 20 PSI. Slowly increased the RPM's to 2,000 and the oil pressure stayed at 20 PSI. However, when I gunned it the oil pressure jumped up to 45 - 50 at 2 to 3,000 RPM's. Anyone have any ideas on whats going on? Thanks,
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    probably the the oil pump is going bad. any coded you can scan? also the pcv valve sometimes when going bad gives this code.
    Jan 10 2016
    San Diego, CA
    It appears to be the pcv value. To check I started the engine and tried to remove the oil cap, which I could not do.....to much vacuum pressure, which I am told is the result of a bad PCV valve. Ordered a new oil separator, will advise if this fixes the problem. Thanks for the reply.
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    Quote Originally Posted by A42010 View Post
    Thanks for posting this. I'm getting the same error message. I'll subscribe to this thread to monitor results.
    Dave
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Easy thing to try, to determine if the PCV unit is bad:
    1) With a warm engine (warm oil), shut it off and goto the next step.
    2) Remove the PCV hose from the intake manifold, and then block-off the nipple on the intake manifold. (You could take a plastic bag, put it over the nipple hole, and wrap some electrical tape around the nipple to hold it.)
    3) Start the engine, and see if your low oil pressure warning is gone. If it is, your PCV unit is bad (ruptured diaphragm in the pressure regulating valve section).
    Established Member Two Rings GerCarFan's Avatar
    Dec 25 2013
    B8 A4 2.0T and Camry SE 2015
    Cooper City, Florida
    Had the same issue come up not while ago for me, so what I did was, I went to Audi stealership and ask for the part number and bought it from them separately for $90.
    Replaced it for my self rather than paying $360 for stealership to replace it for me.... Issue was gone and engine was running with no problem.
    Oct 21 2015
    Chicagoland, USA
    A little more reading, I found this. I'm taking mine to Audi to have it fixed at no cost.
    Go here and put in your VIN: http://web.audiusa.com/recall/
    Service Campaigns
    Crankcase Pressure Regulating Valve REPAIR NEEDED
    START DATE
    Nov 10, 2015
    AUDI ACTION CODE
    17F9
    DESCRIPTION
    On certain Audi vehicles with 2.0L TFSI engine, the diaphragm of the crankcase pressure regulating valve may have been damaged.
    REMEDY
    Inspect and, if necessary, install a repair kit for the crankcase pressure regulating valve.
    Oct 21 2015
    Chicagoland, USA
    Had service done this morning. In and out in an hour at no cost to me. And a got a car wash out of it too. My MPGs had been shitty recently and idling rough, so I'll report back about the results.
    Junior Member Two Rings
    Nov 13 2013
    porsche various
    I was driving on highway the other day and msg said low oil pressure turn off engine. it threw codes P2187 and P12A2.
    the oil cap had lots of suction when I tried to remove. I replaced the PCV valve today and it made no difference.
    I am wondering what to do next? is there a way to check the oil pressure? what else other than take to shop?
    - - - Updated - - -
    2010 a4 2.0 turbo with 150 k kms btw.
