Results 1 to 12 of 12
Thread: Belt tensioner
    Jan 06 2016
    JAX
    Belt tensioner
    Jeez two posts in one day!
    Now the serpentine belt tensioner goes bad and is making a racket.
    Very noisy
    $96 part
    NAPA wants $357 for part and labor
    Seems like a lot of $$$$
    Diagram off Audi parts site seems to show just one bolt holding part to block
    Looks like a torq bolt
    This should be a quick driveway fix / right?
    Jun 26 2009
    Bremerton WA
    It is only 1 bolt holding it in place. Check to see if you can get tools into that spot without having to slide the front core back.
    VMR 710's, APR software, Eurocode HFC
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by irishQ View Post
    Very noisy
    $96 part
    Sometimes the bolts on those pulleys are revers thread. Not sure if ours is or not, but something to check before you start wrenching.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Jun 26 2009
    Bremerton WA
    Ours is normal thread. I had mine off this past weekend when doing a timing chain.
    Jan 06 2016
    JAX
    Quote Originally Posted by van462 View Post
    1 bolt : do you know the size
    Jun 26 2009
    Bremerton WA
    The tensioner is a 12mm triple square. I could fit my breaker bar and bit in there but not much room left. You may try removing the 4 screws on the upper shroud and see if that gives you any angle to go under hood latch. Also be aware not only is there the tensioner but also an idler pully on bearings further down held in by I think a t25 or 27 torx that could make the same noise.
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    My idler pulley started squeaking and it seized a couple weeks later.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    If you're not planning to do it yourself, never bring it to a chain shop..
    They overcharge you like hell.
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Jan 06 2016
    JAX
    "slide the front core bacK'
    please explain, i do not understand what you mean
    thanks
    Veteran Member Three Rings WarmFuzzies's Avatar
    May 24 2017
    b8.5 S5 cab, 200-series L/C
    Montana
    Do you know the torque values for the serp. tensioner and idler pulley?
    Dec 30 2014
    2013 A4 Prestige, 2013 A6 Prestige, 2001 Range Rover, 2001 BMW 330i
    United States, Show-me state
    Quote Originally Posted by WarmFuzzies View Post
    Idler pulley bolt is 20 Nm
    Tensioner bolt is 40 Nm
    per 2013 service manual.
    audi bug --------------------------------------------------------------------------- audi bug
    @ 13 A6 Quattro 3.0L TFSI Prestige Phantom Black - Innovation package, 20" Sport package, LEDs
    @ 13 A4 Quattro 2.0L TFSI Prestige Midnight Blue - Driver Assist package, S-Line package
    @ 06 A6 Quattro 3.2L FSI - traded @185k in 16.
    May 24 2017
    Montana
    Quote Originally Posted by audi bug View Post
    Thank you!!
