Results 1 to 13 of 13
    Dec 06 2015
    Winnipeg, MB
    Instrument cluster scratches
    I realize this has been asked before, but when I searched I wasn't able to find a definite answer.
    I read the B8 A4 instrument cluster is very prone to scratching, is it safe to use Meguiars Plastx?
    It looks like Armorall overspray on my cluster with some scratches that I can't get off, I tried from the inside but that didn't help.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    If for the answer as well. The cluster face on my car has a slight haze I can't get rid of. Been that way since I drove it off the lot.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Might as well spend the extra couple dollars and get the Audi instrument cluster cleaner ;)
    Dec 15 2015
    Denver
    Also found this with a Google search, cmon people http://www.audizine.com/forum/showthread.php?t=434050
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    I used Plastx to remove some of the scratches. It's not perfect as you can still see a little under certain lighting conditions, but it's definitely an improvement.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Dec 06 2015
    Winnipeg, MB
    I tried it out today, and it worked very well! I had some sort of residue and some light scratches, all gone now.
    Before:
    After:
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    ive heard valvoline does instrument cluster scratch repairs
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by ST3 View Post
    Which of the recommended products did you end up using?
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    I use to use plasti x on my G35 cluster. It works great, but doesn't last. You'll have to do it at least once a month. Uses good microfiber cloth.
    Pedal Responce first responder.
    Dec 06 2015
    Winnipeg, MB
    Quote Originally Posted by adamazing View Post
    Meguiars Plastx worked great.
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    The key is the cloth your using to clean and or polish it, as well as how you remove the dirt resting on the surface. The plastic is extremely soft and yes, even ordinary microfiber clothes will scratch it. You need to use those smooth cloths they give you with those fine eyeglass lens cleaner kits from the Optometrist.
    First you want to mist the dirty instrument cluster lens with a good amount Meguiar's Quick Interior Detailer- Cleaner, just to the point it doesn't run. Then GENTLY "lift" any loose dirt in a straight motion left to right until clean and dry.
    Then use a new eyeglass polishing cloth and apply Meguiar's #17 Clear Plastic Cleaner. Then follow up with a Meguiar's #10 Clear Plastic Polish, again with separate eyeglass cleaning cloths. Sometimes these cloths also come with fine electronics to clean the screens. You can probably also purchase them at Best Buy or on line. I think they are a type of microfiber but very fine.
    I was given this advice by the Tech Support staff at Meguiar' had good results with this method.
    Senior Member Three Rings SickAWD's Avatar
    May 16 2012
    VW Taos
    Bellevue, WA
    I used The Chemical Guy's V34 to remove unknown substance on my instrument cluster. It worked wonders.
    Before
    After
    Sent from my SM-G935T using Tapatalk
    Audi RS3 8Y
    Dec 01 2011
    i'm planning to do a good polish and cleaning on mine, and then was going to get some clear vinyl to seal it up, like a big screen protector, will be much better protected and easier to maintain.
    IG @theshawon
