Page 1 of 11 123 ... LastLast
Results 1 to 40 of 412
    Veteran Member Three Rings slowone11's Avatar
    Feb 15 2015
    Castle Rock Colorado
    My 2011 A4 2.0 build
    I bought the car in February of 2015. The car had 52k on it and i paid $19,500. Found out after i bought it that it was stage 2 revo and had 034 hfc. Here is a pic of the day I bought it.....
    So i started getting little stuff here and there like ecs turbo inlet hose, stvbek lip, carbon trunk lip, s4 style rear diffuser and custom dual quad exhaust,
    Next was a step....Wagner Tuning FMIC, rs4 grill and fog grills
    And now the best step...its almost done and being built by SHAUS MOTORSPORT in Aurora Colorado.....Mahle pistons, IE riffle edged H beam rods, ARP head studs, new forged crank, full engine rebuild, loba performance HPFP, fluidamper harmonic balancer, all new baffles and tensioners, IE intake manifold, southbend clutch, new dualmass flywheel, 034 street density motor and tranny mounts, apikol rear diff mount, full custom 3inch exhaust and full custom tune.
    Feb 15 2015
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Nice build! . Are you going to stick with the revo tune?
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Senior Member Two Rings asal's Avatar
    May 09 2011
    inside the beltway, VA
    truly a unique 2.0T! very nice build sir.
    B8 Avant S-line
    ...former A3 TDI, mkiv owner
    Sep 09 2010
    Destin, FL
    Damn, very nice! How much would you say the engine rebuild was? I have my eye on the EFR plus the intake manifold but maybe I should rebuild my engine and do what you did. Also, did you change out the injectors and fuel pump?
    We also want dyno numbers.
    Feb 15 2015
    I am having a custom tune done this week. So no i wont be using Revo. The total for the build was very expensive. But cheaper then buying a new S4. I used the stock injectors stock head but upgraded to a LOBA high pressure fuel pump.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Thanks for making the dedicated thread. Very envious!
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by slowone11 View Post
    Hmm, I'll have to find all the parts and see what the cost would be... I don't think I want to find out.
    Feb 15 2015
    You really dont! Its not good. You could probably do it for less but i kinda went overboard with all the mounts and replacing everything inside the motor....a brand new motor from Audi is 10k....so
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    This build is nuts, can't wait to see what kind of output you end up getting. I'd also be curious to hear what the "all out" number is, via PM if needed. A dedicated toy car is in my relatively short term plans...
    Sent from the Pedal Responce Emergency Bat Phone
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Beautiful....this could be the way I want to go in about 10 years or so....lets see!
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Sep 09 2010
    Destin, FL
    I hear ya. I plan on keeping my car and I've done almost everyone I can so this might be down the road.
    Veteran Member Three Rings Carlos74's Avatar
    Mar 30 2014
    Palatine, IL
    This is probably by far the most serious build (documented/shared) on the B8 platform. All your info is greatly appreciated!
    APR l CTS l EUROCODE l ECS l 034 l PODI l GFB l MAGNAFLOW l H&R l SPC l STANCE l SPULEN l HANKOOK l NGK
    IG: c_lowsB8
    Aug 04 2010
    Queenz/Westchester
    WOW
    Nice build, and a real build at that. Where did you source the forged crank?
    Feb 15 2015
    This build was the hardest decision ive ever had to make. But now that its almost done im fricken stoked about it. The stock cranks are forged. I just got a new one to save the time of having a rebalance. The power output is expected to be around 450+hp to the crank. There isnt very many done like this so who knows till its tuned. The tuner is using Meistro 7 software with a eurodyne cable.
    Dec 27 2013
    B8 A4
    Ann Arbor
    was there an issue with the enigne before you went for the full build or did you just want more power, either way solid
    Junior Member Two Rings
    Jan 02 2016
    Colorado
    Car looks great. Where about it aurora are you? (I'm from aurora).
    Senior Member Two Rings kmunz264's Avatar
    Dec 19 2014
    Port Republic Maryland
    Quote Originally Posted by liqidvenom View Post
    I was wondering the same
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    The turbo looks like a complete bolt on. unfortunately im looking to go through the same route next month with an EFR6758. if you dont mind me asking, what turbo are you using?
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    Looks awesome!
    Sent from my SM-G925W8 using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
    Feb 15 2015
    Yes there was a problem with the motor as i money shifted the piss out of it. Something was wrong with the trans as it would not go into 3rd gear easily and i happened to try and force it in this time and went to 1st gear.
    This turbo is a complete bolt on unit. Comes with manifold, and new diverter valve. Im actually down in castle rock but the car is in aurora.
    Established Member Two Rings SLVR-B8's Avatar
    Dec 12 2014
    Larkspur, CO
    Very nice. Seen your car around town!
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Could you link where you got the turbo?
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Feb 15 2015
    Jan 02 2016
    Colorado
    Lots of Colorado guys on here, do you guys ever meet up?
    Sorry to hi Jack.
    Apr 21 2015
    Thanks! Love you build!
    Sub'd to see the dyno / track numbers!
    Feb 15 2015
    Quote Originally Posted by Zygoat View Post
    Sorry to hi Jack.
    No ive not met anyone from this website. I am part of a couple groups on facebook here in colorado though and have been to a couple cars&coffee meets.
    Veteran Member Four Rings bermudakid's Avatar
    Nov 02 2010
    Santa Barbara
    Saving for the final results.
    Nice work OP
    2011 A4 6MT - APR Stage II - Bang & Olufsen Aftermarket Sub - Eurocode HFC + Alu Kruez - 034 Trans Mount - S4 Brakes
    "Forget the "line" Get the real S"
    Instagram TPR.Visuals
    B6 Totalled - RIP
    Oct 26 2012
    St. Louis, MO
    The Loba K04 is what Revo recommends be used with their tune.
    Slowone's build, though, is far past an off the shelf program.
    I may copy the pinstriped lip, love the red accent.
    Feb 15 2015
    Yes my shop SHAUS Motorsport went through all my options on stages of this build..i decided to go for 400+hp. I could have gone for more but im not looking for a straight racecar. So 400+ was perfect for me. Most of the big name companys didnt make a tune for this hp rating so im going with a custom tune specific for MY car and the altitude.
    Feb 15 2015
    Cold start video https://youtu.be/oXCbwkzxBZM
    Backing into the shop https://youtu.be/SVsuLQ8PTLk
    Dec 19 2014
    So did oil consumption problems prompt the engine rebuild?
    Feb 15 2015
    Some more random pics of the car.
    ..the day after i bought it... p3cars boost gauge
    Feb 15 2015
    Quote Originally Posted by kyleowen94 View Post
    No this was on my mind though. I had been thinking about going with an apr k04 upgrade before any of this miss shift stuff happened. My decision to go bigger was to well......have a badass car instead of a mediocre 4cyl car which is what the apr kit is. I didnt want to spend that kind of money to still get beat up by STI's and EVO's. Which most of the punk kids here in colorado drive!
    Dec 19 2014
    Nice man I can't wait to see it up and running
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    i think you just did what a lot of us would like to do to our cars. great build! love to see some dyno numbers when you get your tune.
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Feb 15 2015
    The guys at the shop are pretty excited about this build too. As soon as i get some dyno numbers and a graph ill be posting them up.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Any chance you'll be going to the track? Would love to see some real numbers from this beast.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Feb 15 2015
    What kind of track are you referring too?
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Probably thinking 1/4 mile~
    Great build, and I am also excited for the results! Awesome car all around sir.
    Where did you get the CF cover that fits over grill/air dam?
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
