Results 1 to 24 of 24
    Oct 16 2008
    South Florida - Ft Lauderdale
    Diy: Bumper repair
    A fellow Ziner stopped by the house today with the well known bumper broken, after backing out a parking spot while the bumper stayed stuck on the concrete stop.
    Good
    Bad
    Since this has happened to some of you in the past, I decided to make a quick DIY.
    You will need the following components:
    Fusor 143
    Fusor 602EZ (make sure to order this otherwise the 143 will not bond correctly)
    Step 1
    Remove the bumper and remove both headlights
    Step 2
    Clean the edges of the broken part and fender with alcohol. Then reinstall the broken piece on the fender using both screws.
    Step 3
    Spray the edge of the bracket and the inner part of the fender. Don't be shy and this step is mandatory. Let dry for 5 mn.
    Reinstall the fender and make sure that with the bracket installed, the fender sits flush with the bumper.
    Step 4
    Load the Fusor 143. I forgot to mention that each bag for Fusor comes with 2 mixing nozzles. Be really careful with this product: it dries almost instantly (less than 1 mn) and become hard like concrete once dry.
    While keeping the bumper side pushed in position, fill the gap between the bracket and the bumper with fusor
    Keep applying the same pressure for 2 mn.
    Step 5
    Remove bumper
    Wear gloves for this step: using the second mixing nozzle, you are going to fill the little gap and smooth with your finger.
    Let dry for 2 mn
    Step 6
    Reinstall headlights and bumper, you are done
    Let me know if any question, I am around
    Phil
    May 20 2014
    e92
    You have given me confidence on fusor. I have the same tear on the passenger side. I tried plastic welding which held the bumper for exactly 30 seconds.
    I am deciding between fusor or bumper latch. I have seen mec's car with good results with a latch.
    I have thought of a used bumper considering the cost of fusor, prep spray and application guns. But you know a used ocean blue bumper is not am easy thing to find.
    Thanks for the DIY. Will have to wait till this cold weather is over to do anything to the car.
    Oct 16 2008
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Diy: Bumper repair
    This is really cool Phil. Thank you so much. I fixed mine with JD Weld and is keeping up fine so far.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Jan 06 2009
    Nice. I did a very similar approach but with 3M products.
    3M Super Fast Plastic Repair 04247 and 3M Adhesion Promoter 05907. It is holding up great.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Phil so my method failed today with the florida heat hahahah dammit...it lasted quite a few 6 months total....blahhh
    Sent from my C5306 using Tapatalk
    Ivan
    Oct 16 2008
    Quote Originally Posted by dalmation53 View Post
    Not sure what was your method but you can always follow mine
    Phil
    Oct 24 2015
    Perth, WA
    I did mine today, used Masterweld RR60. Shit to a blanket. http://www.waysideadhesives.com/Mast...--154_prod.php
    My respray thread
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by Okedokey View Post
    Feel like helping me out?
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Oct 24 2015
    Perth, WA
    Sure, i have some left. come over.
    My respray thread
    Aug 19 2013
    Miami
    Update. So i tried jb weld /plastic weld the one the looks like playdough mixed it in my hands and put it through out and is been like that for a month and holding on like a champ. Only cost me $4 and a six pack of stella.
    Ivan
    Senior Member Three Rings Luccatavares's Avatar
    Aug 15 2016
    Florida
    Do I really need the 602 EZ? I got the 143 alredy
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by Luccatavares View Post
    If Phil says you need the 602 EZ... then you 110% need the 602 EZ.
    Aug 15 2016
    Florida
    Quote Originally Posted by Hugh@EuropaParts View Post
    Ugh! Kill me now
    Aug 19 2013
    Miami
    Ugh! Kill me now
    bruh just try my method works as well just gotta let it cure overnight. phils way is just faster.
    Ivan
    Aug 15 2016
    Florida
    Yeah I will do that!
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Does anyone have the Fusor 300 gun that is used with the repair epoxy? Selling?
    Also does the Fusor "glue" come with the mixing applicator nozzle.....sometimes it's in the pic (Amazon) and other times (JB Tool-where Phil linked to-it doesnt)
    Thanks
    Oct 16 2008
    Quote Originally Posted by B72011 View Post
    Thanks
    Yes, each fusor kit will come with 2 mixing nozzles
    I will check the gun PN tonight
    Phil
    Jun 15 2011
    Exiled.......
    Can other guns be used? Do the glue tubes come with a typical plunger like most epoxies? I think that would work...otherwise a gun I guess.
    Jun 15 2011
    Exiled.......
    Also when my girl backed up the grille and it's upper black plasting part cracked and broke....almost in half. Will this fusor product allow the broken pieces to stay together?
    Aug 11 2018
    Stanchfield, Minnesota
    Good
    Bad
    Fusor 143
    Step 1
    Step 2
    Step 3
    Step 4
    Step 5
    Remove bumper
    Let dry for 2 mn
    Step 6
    Phil
    I added a thin sheet metal bracket made from an old license plate and fitted over the two bolts and extending into the inside of the bumper cover several inches. Hopefully this reinforces the repair. Sorry, I didn't think to take photos while I was doing it.
    PLBrand
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Bringing this thread back up to see for those that have used the Fusor on how well it's holding up.
    Still intact?
    Any slippage or gaps?
    "Beep beeeep bloop boop" - R2D2
    Jun 15 2011
    Exiled.......
    Reviving this --I never did the bumper as the car sat for awhile--about to try it. I am wondering if anyone knows if the fusor will work on the blk plastic that sort of covers the top of the engine compartment when you open the hood? Its probably a much different and stiffer plastic--was just wondering if anyone had a idea or info on that is the fusor would work on this stuff as well.
    Jun 15 2011
    Exiled.......
    Guess not....lol
    Will try and report back....
