Results 1 to 40 of 66
    May 09 2012
    Virginia
    Any other Audi seats swap into our cars?
    I know the B6 S4 and the B7 S4/RS4 seats will swap into our cars. Anyone done anything else that is OE Audi without custom brackets or extensive modifications?
    Veteran Member Three Rings RickB_7's Avatar
    Feb 26 2015
    Tacoma, WA
    I don't know, but there is a set of B8 S4 seats on craigslist that I really want to scoop up. With the new B8 A4/S4 seats I think the wiring harness is different and has to be modified to work with the B8 seats but I think the rails are the same. The rear seats though I don't think will fit.
    Quote Originally Posted by misterjj2u View Post
    Just to clarify: A5 seats are a DIRECT bolt on, including the rails that are attached.
    Modification required: the A5 has different connectors than the B6 A4. Need to cut (give yourself a good foot or so) your existing seat wiring harness and splice to match the A5 / S5 seats.
    That's what I've found in my research. At the end of the day I'll hopefully end up with B7 S4 Recaros
    Nov 15 2011
    Montreal | I sell in USD
    You need to cut the guide pins on the B8 seat rails and swap connectors with the ones from your B7 seats. The connectors are different.
    *****I sell in USD*****
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Yep- B8 S4/S5 seats have the same rails and are really nice.
    TT S-Line and TTRS seats also have the same rails and are actually surprisingly nice as well (same as US R8 seats).
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    May 09 2012
    Virginia
    Interesting. The B8 seats seem to be more readily available. Would ideally like to stick with something from a B7 as it would be the least modification. Anyone know if C6 S6 seats will fit?
    Have done seats in my B5. Axis, what do you mean by guide pins?
    Dec 07 2009
    East Coast
    RS4 bucket seats or bust!
    B8 seats are indeed a decent upgrade.
    Forget the B8, keep the V8!
    Nov 15 2011
    You can see the guide pin on the rail on the right, also pictured are the different connector (one locking tab in the front instead of one on each side on the B7)
    And the guide pin as to be removed on ttrs seats, I'm not even 100% positive on B8 seats but I assume its the same.
    May 09 2012
    Virginia
    Quote Originally Posted by Mr.Wrong View Post
    I would only do S4 or RS4 seats. I like the side support from the Recaro's. The RS4's are nice but not worth the extra premium they seem to garnish in my opinion.
    Quote Originally Posted by Axis View Post
    Thanks. I am really only looking to replace the fronts. So it's just a matter of swapping guide pins and splicing in the connectors from my B7 seats?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I have seen a pair of Euro TT-RS clam shells and a pair of Golf R clam shells (same Recaros as euro B7 RS4) for sale in Canada. Both pairs were $6500 CAD obo...
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    May 09 2012
    Virginia
    Quote Originally Posted by james12lucy View Post
    That's crazy.
    Anyone know about the C6 S6 seats?
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by jbain2 View Post
    That's crazy.
    Seems like unnecessary hassle considering they're the same design as B8 S4/S5 seats, unless you have a line on a pair for silly cheap.
    1) They say "S6" on them
    2) Are much less common/harder to find compared to S4/S5 seats
    2) No confirmation that rails are the same.
    -Hayden
    May 09 2012
    Virginia
    Quote Originally Posted by LINDW4LL View Post
    I do. Frankly I have been searching for months for a set of B7 S4/RS4 seats. The closest I could come was a set Axis had for sale, but couldn't sort out a way to get them shipped from Canada. Have asked the seller to send me a pic of the bottom rails and connectors.
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    B6/B7 cabrio sports seats are another option. They aren't as bolstered as the S4/RS4 seats, but still an upgrade from the stock seats.
    Sep 22 2011
    Western MA
    Quote Originally Posted by heateris View Post
    The Cab seats have power head rests too.
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
    Aug 16 2004
    SE PA
    Cabrio seat in my old B6.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    For the B6/B7 the S4/RS4 Recaro's are (in my opinion) the best option. I sit in a lot of different seats on a daily basis, and they're still one of my favorite.
    Nov 15 2011
    Quote Originally Posted by Sales@DriveAuto View Post
    X2
    Alcantara is a must imo, no cold like leather in winter, they warm up faster and you dont sit on Satan in summer when your car is in the sun.
    Veteran Member Three Rings falconcrest32's Avatar
    May 19 2009
    2008 A4 S-Line Quattro 6MT
    MD/NoVa
    x2 on the alcantara.....you feel more planted to the seat when you get into racecar mode too
    2008 A4 2.0T Quattro S-Line 6-speed *Phantom Black*
    [SIZE=1]| Kohlefaser Luft-Technik Intake | VagCom | Ti Grille | Michelin Pilot Sport A/S 3 | fly300kts Headlights | Pioneer AVIC-8000NEX | Huper Optik Tint | BFI Catch Can | RS4 Front Brakes | GFB DV+ | 034 Snub Mount | JHM TP & DP-Y | Fast Intentions B6 S4 Catback | S4 Recaros Black/Black Alcantara | B8.5 FBSW |
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    2012 A3 Sport Seats in my 2005 A4 Avant Ultrasport
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Dec 07 2009
    East Coast
    X2
    Quote Originally Posted by falconcrest32 View Post
    ^x3 alcantara or race cloth.
    May 09 2012
    Virginia
    Biggest problem is tracking a set down. That's why I started this thread to know of other options. Really looking for a sport seat. Thanks all.
    Nov 13 2011
    b7 s4 avant
    Where at in Virginia are you? I'll keep a lookout. There have been a few sets that have gone on sale in the past year locally so have faith lol. Also, I know someone with a b6 s4 avant that is parting it out. I'll ask him about the seats
    I drive a truck now.
    May 09 2012
    Virginia
    I am in Richmond. Thanks for looking out. There was a set down in Virginia Beach though they weren't heated. That's a must for me. Would drive several hours if needed.
    For the B6 S4, the air bag pressure plate needs to be swapped which would require me to pull apart mine, essentially making them difficult to sell.
    Nov 13 2011
    b7 s4 avant
    You're welcome! The seats are in Northern Va.
    When you say they weren't heated, you're telling me that there was a set of non-heated recaros? I've never heard of a set of recaros that weren't heated, at least in the front. Those were probably the set that falconcrest picked up last month.
    As for the pressure plate, you are indeed correct. I will tell you that if you're worried about selling your stock seats, you probably shouldn't for the simple fact that there's no market for them. You'll be sitting on them (pardon the pun) for a while lol. Also, with these coming from an avant you can swap out the rear seats since they say "recaro" on them and you wouldn't have to modify anything since you also have an avant. In essence, this is probably as good a situation as you could probably ask for since a full set of recaros out of a b6/7 s4 avant are extremely rare.
    May 09 2012
    Virginia
    The seats were from a car from Florida. Geebus sent you a PM. Thanks.
    Jun 27 2011
    Quote Originally Posted by AvantNoir View Post
    I really like those!
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 27 2011
    My buddy has a set of un-heated recaros. They're from a b6 though. My guess is that front heaters were more common on the b7 s4s
    -CP
    2017 Q7 3.0t
    May 22 2007
    Santa Monica CA
    Thanks! Me too.
    Dec 30 2009
    Sacramento California
    Did you have to do wiring etc to make these fit? Those look awesome.
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by 4mymalamute View Post
    Yes, required rewiring and splicing of B6 seat connectors onto A3 seats. Also, there was a tab on the rails that needed to be cut off. Seatbelt mounting was different, so that needed modification as well. Whole job was a major PITA. Other than that, they bolted right in.
    Dec 07 2009
    East Coast
    Yup heated seats were an option on S4s. If you take a look at the cars for sale in the southern states especially, you'll notice no heated seats quite often.
    Nov 13 2011
    b7 s4 avant
    Glad I got lucky with my avant then! Heated front and rear, not that I really care about the rear lol
    Jun 27 2011
    "Other than a bunch of work, they were bolt on!" Lulz.
    I would imagine though it's not too hard, just tedious and annoying.
    -CP
    2017 Q7 3.0t
    Dec 07 2009
    East Coast
    I wish I had rear heated seats, I don't really know why but I just want to have them I'd ask for a swap, but mine are silver alcantara lol
    Aug 16 2004
    SE PA
    I figure the wiring just consisted of matching colors. I wondering about the seatbelt fabrication.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Seriously? I'm in Virginia and just sold a set. What color are you looking for?
    -Tim
    May 09 2012
    Virginia
    Quote Originally Posted by sandspeed View Post
    I am in Richmond. Looking for black Recaro's that are heated. Would drive several hours at this point. Ideally want a set from a B7 as that is plug and play but would take a set from a B6 at this point.
    Dec 07 2009
    East Coast
    Although not black, but price is hard to pass on...
    http://www.audizine.com/forum/showth...lack-Alcantara
    May 09 2012
    Virginia
    Thanks for the link. The alcantara is nice but looks pretty stretched and worn on those.
    May 22 2007
    Santa Monica CA
