Results 1 to 25 of 25
    Junior Member Two Rings
    Mar 23 2015
    '63 Vette Split-Window Coupe
    Question Simple oil change turns into vacuum extractor debacle... help!
    2014 S4. Doing my 2nd oil change myself with my Topsider vacuum extractor. First time I did this ~6 months ago no problems whatsoever.
    Today is a whole different story. Sucked the oil out, everything seemed fine. Changed the filter, again no problem. Then I started filling with new oil, put in 6 liters. Got the bright idea to pour the extractor back into the old oil jugs to see exactly how much I'd need to refill. It was less than 5 liters. Uh oh. Obviously I hadn't sucked all the old oil out. And I'd already refilled more than I took out.
    Pull the dipstick, and yep, over the max line. So I put the extractor tube back in the dipstick tube to suck some oil out. Pushed it in a little too far, in retrospect. Pull it out and... it's stuck. I twist, and pull, and it's not moving.
    Go online, see this isn't entirely uncommon. Twist, pull, let it cool down it'll come out, or so the story seems to go. But for me, no good. I pulled so hard that it started stretching the plastic tube, and no movement. Stuck a wire down the tube to try to straighten it out, and nothing.
    So... any suggestions? Can the car be driven with a piece of plastic tubing somehow lodged in the oil pan or is that a terrible idea? Is my only recourse to drop the pan and figure out what it's stuck on? How big a job is dropping the pan?
    How in the world does a 30 minute oil change turn into this?
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Oh dear!
    Is it possible to try and manually turn the engine over very carefully (I'd suggest lightly in each direction as 1 was may loosen while the other will tighten) while someone puts a slight pull on the pipe?
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    yes it's a terrible idea to drive around with a plastic tube stuck .. You're not even sure what it's caught on.
    My suggestion would be to push it in even further. Push in and out until it dislodges .. I don't see any other solution, unless you're dropping the pan.
    Did you use a mechanic wire?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Aug 03 2014
    Queens
    Quote Originally Posted by RyanJon View Post
    Oh dear!
    Good idea.. Only way he can do that is by turning the crank or going under the transmission and turning the flywheel..
    Previous
    Mar 23 2015
    Quote Originally Posted by DGVR6 View Post
    I just used a long piece of fairly heavy gauge wire.
    Mar 23 2015
    So I see this DIY for changing the oil pan. Doesn't look impossible, but not fun either.
    From the pictures between steps 6 and 7 it does look like there are quite a few baffles(?) that the hose could have become stuck on.
    Aug 03 2014
    Queens
    If you have access to a borescope you can probably remove the oil sensor and see wassup before dropping the pan.
    Previous
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    weird i work at a dealership and use my oil extractor everyday . never had it not come out.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Apr 20 2012
    Honolulu, HI
    Use the wire and bend the end to form a small hook. Feed it through enough so that it should pop out the end of the hose and then pull the wire back. The hook on the end will catch the end of the hose and pull on it, hopefully dislodging the stuck portion of the hose.
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Suck the oil out, and get a bore scope in through whatever you can. It's probably caught on something fairly benign, but if its caught on a sensor (like the oil level sensor) and you give it a good yank...you might not even know you've broken something until it's too late.
    Better to take a bit of extra time and get eyes on what it's caught on.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Mar 23 2015
    Quote Originally Posted by amz View Post
    Any idea where to loan/rent a borescope? Doesn't look like Autozone has them as part of their loan-a-tool program. I don't know that I want to buy one just to satisfy my curiosity then have to pull the oil pan anyway.
    I've mostly convinced myself that I'm going to pull the pan tomorrow. I'm off work, and the wife is too, so she can watch kids and her car will be home to run errands.
    Anyone have an opinion on using Audi-specific silicone gasket/sealant as opposed to something like this? I'm an hour and a half from the nearest dealer.
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    Man that sucks..I have to admit I had something similar happen on my S5. I had the tube in there and trying to make sure I got it all, I pushed the tube in a little farther and it caught on something, probably the same thing you have. I had visions of disaster, but by working the tube in and out it finally let go and came out. Since then I use a smaller tube and once it hits bottom I don't push it in any more. You probably have already tried it, but I just kept pushing and pulling until it let go. Good luck, I feel for you, this has got to be a major PITA.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Apr 29 2013
    Ottawa
    Quote Originally Posted by Thor Sanchez View Post
    I ordered one off ebay for $10, but it took 2 months to arrive lol. Try posting in your local section, reach out to your local Audi group, or check boxing day sales? They're pretty useful things to have around.
    Aug 03 2015
    Calgary
    I did the same thing the first time I sucked the oil out. The tube got stuck.
    Push it in more with a twisting motion, then try to pull it out with a twisting motion. Eventually the tube will come out.
    2011 B8 S4 DSG Full ADS & Sport Diff - U2nelson CR-15 strut brace review - Eurocode intake - S5 rear sway bar review - Eurocode transmission insert
    2005 E46 M3
    Mar 23 2015
    I dropped the oil pan. The suction tube was looped down and back and up into the top pan/baffles. I got it out easily with the pan removed.
    The procedure, as with all things car, was 334 times more involved than the DIY implied. The top three torx screws holding on the oil cooler are all but inaccessible. Must be accessed blind. The step that says "now that you have all the bolts off the oil pan it should drop down with a little prying" was off by a factor of a million. I bent the flange of the pan trying to pry it off, then had to make a wedge out of a 2x4 to finally pry the thing off. That gasket sealant must be using some kind of exotic atomic forces. I think I've bent the thing back to it'll be fine.
    The re-assembly is about at the 60% mark. I have three bolts on the back that are giving me trouble, it's a bad angle and I don't want to strip them but they don't want to go. And those @#@(% torx screws on the top of the oil cooler are still looming.
    Oh, and I took a chance and used generic high-temp silicone gasket sealant instead of the Audi part. Otherwise I'd be ordering online and waiting, or driving 1.5 hours each way to the dealer. It says 24 hours to cure, so I'm contemplating leaving the rest for tomorrow when it's supposed to be 20 degrees warmer.
    Nothing like a 12 hour oil change. And I'll have to do it again reasonably soon since the thing that started this was the realization that I hadn't gotten all the oil out in the first place and I don't have an extra 7 liters of Liqui Moly lying around.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Sorry about all your trouble but I'm glad I simply stick to the standard way of doing it. Takes me about 20-30 minutes start to finish and clean up doing it by myself.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    when you were suctioning, did you undo the oil fill cap? not sure how tightly the tube from the extractor fits in the dipstick hole, but you could have created a vacuum inside the oil compartment when pumping oil out, thus possibly causing the tube to get pulled into/towards the pan. just a thought for future jobs.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Mar 23 2015
    Quote Originally Posted by pdqgp View Post
    I love the idea of the vacuum extractor. First time I did it was all great. But now... I don't know, it'll be hard to stick that tube back in there!
    I did go back out and get everything put back together, including the crazy torx screws on top of the oil cooler. Will let the sealant cure overnight, torque all the bolts tomorrow, and pray for no leaks!
    Mar 23 2015
    Quote Originally Posted by jomama229 View Post
    Yea, it was undone. The hose wasn't tight in the dipstick hole, pretty sure it wasn't a vacuum problem. Actually, after it stuck I disconnected the tube from the vacuum system so that couldn't have been it.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Next time, just take it to the Valvoline quick change! http://www.audizine.com/forum/showth...il-change-shop
    Jan 28 2015
    Pnw
    Glad you got it corrected. I am sticking with the old fashioned drain plug. Been doing it that way for 30 years. Works pretty well. Until you strip a drain bolt....lol....
    Mar 23 2015
    Finished up this morning. Got everything back together, torqued everything down, and... sheared off one of the bolt heads on the back of the oil pan. I don't even know if you can get a drill and a tap in there to fix it, it's at a bad angle. For now I'm just going to leave it and monitor for leaks. Ran the car for a few minutes and didn't see anything leaking at all. Will re-change the oil to get out the mixture of old and new oil as soon as I can get some. I'll have to check again for leaks then.
    Also ended up with an extra hex head bolt. I went over everything. I think it has to be from the belly pan, but can't figure out where. I put back all the torx and quarter-turn hardware and there is a hole with no bolt, but this doesn't fit. I don't know...
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Happened to me before, its like a chinese finger trap... you actually want to push the tube FURTHER and then you can pull it back safely.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Established Member Two Rings kr3w45's Avatar
    Mar 19 2014
    02 a4, 06 a4, 09 a4, yamaha r6
    Boston, MA
    Quote Originally Posted by Usa View Post
    That sounds terrifying haha. Sorry to hear what happened OP. Working on Audi's, when one thing goes wrong it always tends to snowball.
    Automate your Dealership: www.DealerScience.com
    Automotive Technician @ Amherst Autoworks
    B7 A4 - Frankenturbo F23L
    B8 S4 Stage 2
    Mar 23 2015
    One more update. No apparent leaks a day later. But I did find something interesting about the car - I took off the belly pan and was going to leave it off for a few day for better access to look for oil leaks. That's not going to work, it seems that leaving it off leads to this loud, very disconcerting slapping/buffeting sound at maybe 30+ mph. Probably from other trim that relies on the belly pan hardware to be secured. Put it back on and the sound is gone. Lesson learned, have to have belly pan on.
