Results 1 to 24 of 24
    Dec 22 2015
    MidWest
    Thumbs up Your Thoughts on purchasing high mileage 2013+ S4 ?
    So, I've been looking at Buying an S4 for years and I'm finally ready to Step-up after owning a 335xi, and currently an Acura TL SH-awd. To keep the S4 purchase price down, I'm considering a B8.5 ( 2013 ) with 60k-90k miles to keep it in my price range. I've stalked the threads here and now wanted to ask you, the experts about your experiences & thoughts of what to avoid & what to expect. Thanks in advance for your input!
    Aug 02 2012
    Boston
    I have 104k on mine, no real problems. In general, a 6 speed will be more reliable (lower repair costs) than the DSG over time/mileage.
    2017 S8
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    I seriously don't think you will have an issue. Most of the 2013s are solid when it comes to transmission, the sport diff, and the water pump. What I would be sure of is the steering on them. Since some people have an issue with the electric steering and they don't like the way it feels.
    Congrats on coming from a 335xi to an S4. Same move I made and I don't regret it. Love every bit of the S4 compared to the 335.
    Also look into purchasing a lower mileage 2012 or 2011.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    B8.5 looks better but will cost more
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    one of the things about high miles modern German cars is how to be sure its not using a lot of oil, or has a lot of carbon build up. when my friend sold his S4 at 100,000 miles, you do not even want to know how much oil it was using. people have often done oil changes at 10K, (factory stupid interval) and over time, that can end up doing some bad things internally in the engines. tranny needs to have been serviced regularly too, or it may be near the end of its trouble free period by 100K. steering on 2013's was a weak point. first year of electric steering.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    If you do buy one, I suggest getting an extended warranty, The thing about the 6MT, which I have, is that the clutch assembly will eventually need replacement on your dime. With warranty, if the DSG fails, it will be covered to repair/replace. Please don't get one without a Sport Dif!
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by bpollock View Post
    DAMN!!!! Thats awesome...
    Jul 27 2015
    North Bend, WA
    when i purchased my 2013 about 2 1/2 months ago, i knew i had to purchase a slightly higher mileage one to be able to get one at the price i could afford. i ended up purchasing a 2013 with 47k miles on it for $32k. like Dr GP mentioned, i purchased an extended 3 yr, 36k mile warranty (not through fidelity like everyone suggests because they were quoting me like $4k for the gold level ), but through a company the BMW dealership worked with for something like $3000. luckily i was still under the factory warranty and had audi check out the car before the warranty expired, but i'm at 50.5k miles now and i haven't had a single mechanical issue. good luck with the purchase!
    2018 S3 - Premium Plus
    Vegas Yellow / Tech Package / Black Optics / S Sport Seats / B&O / Resonator Delete
    Nov 16 2015
    DFW
    DSG will be less painful when doing power mods
    Apr 05 2009
    SF BayArea
    epl's dsg tune brings the shifting to a whole other level of refinement and performance. I have no regrets at this point going with a dsg on my car for a DD.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    I have 110miles with dsg and zero problems.Also running Apr stage 2t and duel pulley for quite some time.And still running high 11.59xx 1/4 mile! Also friend has one with 120miles and been problem free!
    Mar 21 2015
    ^ I hope your not having any issues with 110 miles on her.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Bought with 91k with a bad clutch, replaced it and I'm now at 109k with no issues and modified. Go for it!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Oct 31 2013
    Morris County, NJ
    Turned mine in at 103k all it ever needed repair wise was a thermostat at 86k.
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Established Member Two Rings vincenz0's Avatar
    Jun 10 2015
    2010 Audi S4, 2014 Audi Q5 3.0T, 2005 Lotus Elise
    Burlingame, CA
    I bought a 2010 with 70k on it and just passed 78k the other day. The thing is tip-top. I definitely would not be scared of a higher mileage car. Most people who bought B8 S4s aren't poor, so they typically have taken care of them, had them service properly, etc.
    2010 Audi S4, Deep Sea Blue
    2014 Audi Q5 3.0T, Scuba Blue
    2005 Lotus Elise, Magnetic Blue
    (yes, I like blue cars.)
    Veteran Member Three Rings blackjak's Avatar
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    2011 here, second owner, picked her up at 55k mileage, she now has 101k on her. I went stage 2 around 65k and I'm still on original clutch, gripping strong. The only thing I've had to replace was the thermostat, other than that runs absolutely fantastic. I have owned the B5, B7, and now B8 can confidently say the 3.0T engine is by far their most reliable and in my opinion strongest engine yet. I made sure the previous owner wasn't a puts and had all paperwork for service. Best car purchase of my life....truly look forward to driving her everyday.
    Established Member Two Rings mdeneso's Avatar
    Sep 11 2014
    B8 S4 15 T-Reg 05 ZX10R
    Mine has 118k miles currently and DSG, still going strong. Thermostat replaced around 104k.
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    Quote Originally Posted by vincenz0 View Post
    I'd agree here, with the caveat that it's a one owner car. 2 or 3 owners would worry me about the consistency of proper servicing.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Quote Originally Posted by fitzydude View Post
    Did you do the work yourself? I need one soon and wanted to know if anybody has actually done it. There's no DIYs to be found...
    Sent from my VS986 using Tapatalk
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Jbullin.. Ecs has instructions on thier site
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    Quote Originally Posted by DGVR6 View Post
    79k and running like new. As others have stated the thermostat is a ticking time bomb. I'm pretty sure mine is stuck open, but having an upgraded boost cooler keeps it from overheating.
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    Quote Originally Posted by GRUMPY-S4 View Post
    I feel the exact opposite. But I'm biased.
    Feb 20 2006
    NC
    It would only overheat if it's stuck closed....
    Quote Originally Posted by EHesh14 View Post
    Veteran Member Three Rings AFR1485's Avatar
    Nov 24 2015
    Fiat 500
    In November I took the plunge on a 2013 S4 with 61k miles on it. When I test drove the car it needed a new front brake sensor (got new pads while at it), new front wheel bearings, and the biggest concern is that the transmission began to leak (only when operating temp got very hot).
    Make sure you drive any car you look at hard. Listen carefully and you'll hear/feel any wear and tear that needs to be taken care of. The dealer took the car to Audi to fix the transmission, and three weeks later it was fixed. If the dealer does the right thing and takes care of any needed repairs, then you will get a solid car at a great deal.
    Sent from my Nexus 5 using Tapatalk
