Results 1 to 30 of 30
    Dec 24 2013
    United States
    On two occasions the gas pedal got stuck full throttle....
    Not much to explain, was trying to pass two different cars on two different occasions, press the pedal down 60% of the way and released and car would keep going, and to apply the brake super hard for it to disengage and slow down...... any ideas whats causing this? Car is a 2014 with only 20,000 miles, where would you guys do from here? cheers!
    Deactivated Three Rings
    Aug 24 2015
    That's scary dude. What do you mean??? You check the rubber floor mats? Your CC was off??
    Sent from my iPad using Tap,Tap,Tapatalk
    Dec 24 2013
    United States
    Quote Originally Posted by jimblkmazda View Post
    Yup, I checked the floor mats wasn't them, they weren't in the way at all.... literally the pedal was stuck in the depressed state, it didn't come back out, it released upon a hard press on the breaks.... I'm literally scared to go full throttle coz I wasn't sure if it would happen again
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I'm sure the dealer would be very motivated to check it out for you at no charge. I'd get it to there service department ASAP and let them investigate. Could have thrown some codes but even if not, there are likely things they would know to look for for "unintended acceleration" situations.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Aug 24 2015
    Take the service advisor/manager for a ride and have him drive to WOT to replicate issue. Just make sure to sit in the back with 2 seat belts on.
    Dec 24 2013
    United States
    It's due for its next service in 18 days, so I'll let them know when I go.... just don't wanna believe my baby is turning into a lemon after her accident
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    if the pedal was pushed down and didn't come back up I would triple check the weather mats. This happened a few times on my dads tundra until I figured it out that the mat was the culprit.
    terrifying when it happens.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by fast_furious View Post
    You didn't mention an accident in your original post. Was it front end damage? Maybe something is binding. If you press the pedal to the floor when the car is shut off (engine not running), can you get the pedal to stick in the down position?
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Quote Originally Posted by LYKUNO View Post
    OP has a thread "Fender Bender" .. damage was on right side with 27k in damages back in Feb
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Audi invented unintended acceleration. https://www.youtube.com/watch?v=otyax6onMWw
    Suggesting it's a lemon after extensive damage is horse shit.
    Dec 24 2013
    United States
    It was side damage, the right side to be exact. Theres a thread called fender bender, it has pics of the accident
    I'll have to try that test with the pedal and the car off and tell you
    Dec 24 2013
    United States
    Quote Originally Posted by B-Time View Post
    I said turning into a lemon (meaning maybe it is now), I didn't suggest it was a lemon from the start... quite the contrary she was a princess.
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    since most modern cars now use telemetry [drive by wire] but the pedal was stuck in wot position, logical deduction would lean towards a physical obstruction of some sort? if the drive by wire was all kiddywompus it might stick in wot position even if you never floored it or partial throttle...
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    May 03 2009
    East
    Good to hear. Only had a throttle stick once. It was a 30+ year old benz sl with an american crate motor :) Killed ignition and put it in the grass.
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Did the pedal it's self stay in the open position when you lifted your foot up or did the pedal rise and the acceleration continue? Sounds like it could possibly be a problem with the throttle body to me?
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by RyanJon View Post
    That wouldn't happen anyways. If the throttle was stuck open and he pedal was at 0% that's a serious redflag and the car will catch it immediately and possibly limit the throttle and throw a cel and close the TB. There are so many safe guards in the drive by wire its not funny. The computer is constantly looks at all 4 sensors and if one doesn't agree with programed strategy it will red flag it.
    But an accident can do anything and everything to a car. You really have no idea oh bad an accident can screw something up that had nothing to do with or was far from the accident. Your sending a shock wave threw the car and it can do anything. So its not unheard that the accident could of caused it by tweaking the Acell pedal. But if you take it to the dealer I wouldn't tell them anything about the accident at first if the car is under warranty. Just to protect you and from them not finding anything and washing their hands of it with the "must be the accident" excuse.
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by Johnnycash View Post
    this, would still take it to the dealer, let them figure it out
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Apr 04 2012
    MSP
    I'm not buying it... sorry. Something doesn't smell right about this...
    On two occasions you experience a stuck throttle (which I've never heard of with this car - MAYBE if your floor mat got wedged - but it's a floating throttle pedal so that would be a big maybe - and you said it was not the case)... and now you are dropping the lemon hint and saying you will wait over 2 weeks to tell the dealership?!... I'm sure if it really happened you would not be waiting 18 days to take it in... lol. makes no sense man.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    The throttle has inexplicably stuck open on two separate occasions? I would have it towed to the dealer.
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Quote Originally Posted by The Fat Kid View Post
    +1000. Someone could have been hurt or killed. Do not drive the car.
    "Unintended acceleration" (never proven) is what almost killed Audi in the 80s in the US market. I'm sure they will be interested in looking at the pedal for you.
    As others said, check floormats. It was known issue with several brands including Toyota and their recent infamous unintended acceleration media mess.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Aug 02 2012
    Boston
    I have had that happen due to floor mats once.....very scary!
    2017 S8
    Dec 24 2013
    United States
    What is there not to buy lol?? I live in a farmtown in WV, no Audi dealership near me for 200 miles, and my daughters wedding is in two days and I have a lot of preparation for to do for that, as well as vacation after the wedding, so yeah I have other stuff on my plate
    I have 5 other cars so I have transportation
    So yeah, as soon as I have time to get it serviced I'll tell them about the issues
    My mercedes and Infiniti are my daily drivers
    As far as the tranny, sometimes I hear knocking in the engine when I turn it on, but I think thats just the cold start
    Also I always noticed the car is slow to engage in drive or reverse when I switch gears
    just two things I can't help but notice when I do drive it
    Jul 10 2015
    5 other cars, damn bro.
    Dec 24 2013
    United States
    Quote Originally Posted by bizzy View Post
    I mean I have a family, so 3 kids = 3 cars, wife= 1 car, husband = 2 cars!
    Apr 04 2012
    MSP
    Hm, just a bit fishy is all... especially with you bringing your lil accident thread back to life too.
    If the repairs ended up costing 27k for that accident I'd also want out of it - and a lemon claim would be a nice way out
    Regardless - If this is in fact truth then whomever repaired your car after the accident would be liable I'd say... take it back there (towed at their expense) and don't drive the car any longer. You don't want to accidentally run over your daughter's new husband or something now would you (aka obviously a public safety issues here)...
    Jul 31 2014
    Mpls, Mn.
    thats six cars unless my math is wrong? carry on
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    He did say "5 others", 5+1=6, right?
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Jul 31 2014
    Mpls, Mn.
    Quote Originally Posted by RingsOfFire View Post
    i think you are correct good sir. thx
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Is it possible that the cruise control could have been activated or malfunctioned?
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Cheers!
    To keep this on topic and reply to OP, don't drive it anymore. Take it in to get looked at. Happy holidays everyone!
