Results 1 to 20 of 20
    Dec 19 2015
    Florida
    Brilliant Black vs Mythos Black
    Hey guys! This is my first post so sorry if anything was done incorrectly. I am planning on buying an S5 in the next month or so and would like to know if there is any considerable differences between Brilliant Black and Mythos Black and which one you guys prefer. Pictures are appreciated. Thanks a lot!
    Sep 28 2010
    NW NC / DE
    If I remember correctly, Mythos has some light flake, so imperfections will not show as much than on BB, as its a solid color. The metallic makes it a bit more interesting too. That being said, BB is awesome if kept mint.
    Mar 18 2011
    Denver
    Mythos, all the way.
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Definitely, pick Mythos Black which is metallic unless you want flat brilliant black..
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    Mops is right. I have a Mythos Black RS5 and I would not want flat on that. My old Z is flat paint and it shows every little imperfection and is pain to maintain.
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Mar 18 2015
    2015 GL450
    IL
    Just to clarify, Brilliant is not "flat" but just doesn't have a metallic flake. I went back and forth and went Brilliant. They both look good but if you're willing to put in the work, Brilliant can look amazing.
    The advice is correct though, Brilliant is a lot more work to keep looking mint. The thing is, for me at least, I would follow the same routine regardless. With Mythos though you will notice imperfections less and probably be able to space out full details a bit more. It definitely will hide any minor swirls better.
    Couple pics of mine...
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Mar 18 2015
    2015 GL450
    IL
    A few extra thoughts...
    Whatever you go with (especially if it is new / ordered) tell the dealer not to touch the paint, no wash, etc. Dealers are a big source of swirls on brand new cars. I took mine straight to my detailer for some minor paint correction and then had a ceramic clear coat applied. A lot of guys here either go with a coating or a wrap. (XPEL, Suntek, etc.)
    Nov 26 2015
    79' FJ-40, Ducati 1299s, 12' R1 (race bike), KTM 250, American IronHorse custom chopper
    Detroit Mi
    Ceramic clear RVJ? Who does it and is it comparable to a clear bra?
    15' S5 Mythos, S-tronic, Alu-Optic, sport diff, adaptive suspension, driver assist, Tech, heated mirrors/seats, black nappa, B&O
    AWE Touring, GIAC St.2, AWE CAI carbon
    Mar 18 2015
    2015 GL450
    IL
    There are several ceramic clear products out there. I went with CQuartz Finest. Most good detail shops will do it for you. It does have a "measurable" thickness but a clear bra / wrap is going to offer more protection against rock chips, etc.
    Essentially it is an additional ceramic clear coat over your factory paint / clear coat. It is harder once cured and helps with swirls, etc. Depending on how you care for the car and your climate they can last anywhere from 1-2 years before it needs to be redone.
    Some people do both as the clear can be applied on top of a wrap. For instance, if you wrap the front and then apply the ceramic on top.
    Senior Member Three Rings astonmartin007's Avatar
    Apr 19 2015
    Mythos Black all the way!!
    My S5 is BB but like people mentioned its very hard to keep it nice.
    I didn't want to wait longer to get Mythos Black but if I had to do it again I would wait.
    Dec 19 2015
    Florida
    Thanks for all the input guys! Mythos seems the way to go in terms of maintenance and upkeep. Which color do you all think looks better in the sun, considering I live in Florida? Thanks again!
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    I have BB and absolutely love it when it's clean. As mentioned before, I'd definitely get a professional detail and a coating applied - Cquartz finest is a great option. Coatings should last 3-5 years if applied correctly, and they'll help to keep your paint looking mint.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Mar 18 2015
    2015 GL450
    IL
    ^ Actually a good point on how long it will last. I'm just a bit "insane" when it comes to paint. Plus I'm outside of Chicago so I deal with winter and salt on the roads. In Florida you'd have it last longer. Either way, I can't recommend a coating enough. Really gives black that deep, wet look.
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by ricorodriguez32 View Post
    Mythos is awesome in the sun
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jan 07 2011
    2013 C300 4Matic
    my car was brilliant black, and repainted to bmw sapphire black, which is very close to mythos black
    brilliant black was pretty hard to maintain, but looked really good when clean, like a deep stealth black. with sapphire black, it hides swirls pretty well, and when in direct sunlight, u can see all the metallic flakes and a hint of grey in it. pretty awesome imo , esp under direct light
    you would get similar results to that shine under the sun with mythos ^^^
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Apr 05 2014
    Edmonton, Alberta, Canada
    BK i really like your car
    2009 Mercedes-Benz C63 AMG. Agency Power Headers, Eurocharged Tune, High flow air filters, secondary cat delete 490RWHP
    *SOLD*2010 A5 S-Line, Deep Sea Blue 6 Speed M/T
    Unitronic K04 Turbo, Vossen CV3 Matte Graphite, H&R Spacers, ECS Vent Boost Gauge, Injen CAI, CTS Turbo Test Pipe, Forge BOV, Tint.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by talkinghamster View Post
    I like his bod
    Jan 07 2011
    2013 C300 4Matic
    <3333333333
    I like his bod
    <333333333333
    Present:
    IG: bknewtype
    Sep 02 2016
    How does sapphire black compare and phnstom black pearl ??
    Feb 27 2020
    Midwest
    Brilliant Black all the way here and that's what my 2018 A5 is.
    Reason being - I have been a long time buyer of black cars. Nothing looks better than a freshly WAXED black car in my opinion.
    Brilliant Black looks better waxed, it is also look BLACKER or almost WETTER looking than Mythos which is more of a CHARCOAL color in my opinion. Mythos reminds me of a faded black (to me at least).
    This is probably why some people describe BRILLIANT as FLAT as it doesn't have the metallic flake and depth as MYTHOS - and that is exactly what I want. "FLAT" (or "NON METALLIC" in this case) paint jobs tend to look better waxed than metallic (to me) and it is this same reason that they also look dirtier than metallic when not cleaned - they show their surface more than opposed to the depth of the paint job.
    If you like metallic flake, depth and not washing your car - get MYTHOS. If you want a TRULY BLACK paint job that will show everything, but look stunning when waxed - get BRILLIANT.
    My experience has been the darker and the "FLATTER" (non metallic) the color - the better it looks waxed. I had a silver and tan metallic paint jobs on cars and they never looked as satisfying when waxed as darker, flatter colors.
