Results 1 to 13 of 13
    Senior Member Two Rings Saifxnyc's Avatar
    Oct 19 2012
    Pittsburgh, PA
    Exclamation C6 Battery Coding Question.
    Hi everyone i just got my vehicle back from the dealership. I am assuming they didn't charge it they had it for over 10 days. The car cranked quite a bit for a while before it started the battery percentage was 20% but it charged up to 100% under an hour. I did a VCDS scan this is the only thing that concerns me i am wondering if the battery needs to be coded or not. I don't know if it was every coded but i never had issues with it. If these codes are the result from being at a low voltage than that's a good thing . Does any know how to check if the battery is coded on a 2007 AUDI A6
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000027224
    Shop #: WSC 40322 403 54476
    VCID: 23450907E2202306A91-8076
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2605081815
    Coding: 344630393135313035442056413032363035303831383135
    Shop #: WSC 00000 512 00290
    2 Faults Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 6
    Reset counter: 255
    Mileage: 183987 km
    Time Indication: 0
    Date: 2015.12.14
    Time: 17:10:55
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 255
    Time Indication: 0
    Date: 2015.12.14
    Time: 17:16:07
    Jul 17 2011
    Sin City, USA
    If the battery wasn't changed, then no need to recode it. Most likely the faults you are seeing are a result of the power drain. Clear them and see if they return. My suspicion is they won't.
    A tell tale sign the battery is not registered with the car is if you get a message "battery level low. Will recharge while driving" if you get this after putting in a new battery then you need to code it.
    '09 C6.5 A6
    Oct 19 2012
    Pittsburgh, PA
    Thanks sin I never saw that sign in my life and the battery was replaced in 2014 February from the original factory battery. I was told it is a Volkswagen battery and that they're the same as Audi part. Is it normal for this car to not have any charge in battery if not driven for more than a week?
    Established Member Two Rings haloguy628's Avatar
    Sep 01 2011
    Castle Pines North
    The battery charge indicator on MMI is not really accurate so don't worry about the 20%. The codes Quiescent Current Stage 1 & 2 are battery drain codes and go up to 6. I would check the battery with voltmeter to just make sure the battery is good.
    https://www.youtube.com/watch?v=COJr7OB23Hw
    Oct 19 2012
    Pittsburgh, PA
    Quote Originally Posted by haloguy628 View Post
    i have VCDS software can't i test the battery with that? I will test the battery with a volt meter tomorrow at the garage as well thanks for your input. The car battery was not coded properly since it was replaced and i coded it right but it still has shut off on me twice... I drove it for 60 miles at 70 mph average today to charge up... If it doesn't start in the morning i'll know
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by Saifxnyc View Post
    Theoretically, the power management module that is connected to the positive terminal of the battery will regulate charge/discharge of the battery. When the battery drains to a certain level, the system will start shutting down various components to keep the battery from draining, but it will go dead if there is a power draw. The other day, while messing around with my new HEX-NET VCDS module from Ross-Tech and installing my new dash cam, I drained the battery in my car to the point it would not crank over. Total time; approx. 2 hours.
    '09 C6.5 A6
    Jul 17 2011
    Sin City, USA
    With VCDS, you can monitor battery charge levels and charging system output, but I don't think it will test the battery to see if there in an internal issue (bad cell, etc.)
    '09 C6.5 A6
    Oct 19 2012
    Pittsburgh, PA
    With VCDS, you can monitor battery charge levels and charging system output, but I don't think it will test the battery to see if there in an inertial issue (bad cell, etc.)
    Ok I had it tested yesterday at advance auto parts. They directly hooked the machine that check the cold cranking Amps and battery volts in the trunk. The battery stated it was good. I drove the car for 150 miles. 3 hours and turned it off and five mins later turned it on and it hesitates to start with the same symptoms. I see i will double check it with another mechanic to make sure if the battery is good or bad. Is it common for a battery to just die pretty much after 22 months? it's an original Varta battery...
    Were you able to charge your battery up by just driving it for a while? Should I check the alternator as well?
    The car is was hesitant to start just now and the HVAC error is new I am not sure but I think it is related to the car having a hard time starting because this error was nonexistent. In fact the only thing that had a fault code was the Control Head in which I have turned off the TPMS sensor. I am inclined to believe the battery probably dying.. I won't get a second opinion till Monday unless I can find a local shop that’s open on a Sunday that’s not auto zone. The dealer had this car for a long time prior to the ten days more like 3 weeks and when I got it back it was doing this I drove it around for a while it stopped. The second time I get it back after 10 days the problem will not go away. I drove the freaking hell outta this car in the first snow we got here and it still did not solved the hesitant start issue it just cranks really hard then starts. 7 out of 10 times it will start. Could be the alternator? And is the alternator the same thing as the starter motor? Just looking at the long picture here in case I’m f$%^&*d
    And if the battery is bad do you recommend buying this? Or do you recommend something else. Thank you
    http://www.autozone.com/batteries-st...ue#tab-reviews
    Here are the latest results from VCDS
    Saturday,19,December,2015,19:39:22:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WAUDH74F27N003624 License Plate:
    Mileage: 184400km-114580mi Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
    62 72 77
    VIN: WAUDH74F27N003624 Mileage: 184400km/114580miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 4F2 910 559 HW: 4F1 907 559 E
    Component: 3.2l V6 FSI 0020
    Revision: --H19--- Serial number:
    Coding: 01050109190F0120
    Shop #: WSC 02325 785 00200
    VCID: E9D9DB2FC08CB956A3D-80BC
    1 Fault Found:
    005634 - Power Supply Terminal 30
    P1602 - 008 - Voltage too Low
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 184402 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 3.0°C
    Engine Off
    Load: 0.0 %
    Speed: 0.0 km/h
    Readiness: 0110 0101
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0210
    Revision: 27120501 Serial number: 10601000410184
    Coding: 0000011
    Shop #: WSC 02323 785 00200
    VCID: E3C5C90722A0E306691-80B6
    Subsystem 1 - Part No: 4F0 910 131 J
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 220 A
    Component: FBSAUDIC6 IDG H01 0040
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 195
    Mileage: 184396 km
    Time Indication: 0
    Date: 2015.12.19
    Time: 06:06:40
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 731 F HW: 4E0 035 729
    Component: Interfacebox H43 2740
    Revision: 00000000 Serial number: 303E6067523000
    Coding: 0000003
    Shop #: WSC 02335 785 00200
    VCID: 2541171FEC14DD36C75-8070
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    Subsystem 2 - Serial number: 00000000416935
    Subsystem 3 - Serial number: 0115.05.060000000100010550ÿ
    Subsystem 4 - Serial number: 010550ÿ
    2 Faults Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 156
    Mileage: 184402 km
    Time Indication: 0
    Date: 2015.12.19
    Time: 19:26:00
    02244 - Button in Control Head is Stuck
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 184399 km
    Time Indication: 0
    Date: 2015.12.19
    Time: 06:11:41
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 0000010
    Bin. Bits: 000
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000030 Serial number: 00000030126282
    Coding: 0524326
    VCID: DBB5F1E71AD0DBC6211-808E
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 A HW: 4F0 907 801
    Component: EPB CA3C0040 H03 0040
    Revision: --H03---
    Coding: 0005022
    Shop #: WSC 02324 785 00200
    VCID: 1E3338F3C9420EEE86F-804B
    1 Fault Found:
    01487 - System Function Test
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 196
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    Voltage: 0.00 V
    Count: 184
    Subsystem 1 - Part No: 000 915 10D L
    Component: von VA0 33060441F7
    Coding: 3030303931353130444C2056413033333036303434314637
    No fault code found.
    End ---------------------------------------------------------------------
    Mar 21 2015
    Oct 19 2012
    Pittsburgh, PA
    Thanks 14S4GWM I was able to follow the directions on the Ross tech website
    http://wiki.ross-tech.com/wiki/index...ry_Replacement
    https://www.youtube.com/watch?v=IJAScg6JrYI
    it's very straight forward that link is also very helpful much appreciated. I know it says after market battery can cause electrical issues but i have been reading posts on the forums some people don't have any issues with an autozone or walmart battery but if the original is a must i can do that the price is the same anyways.
    Oct 19 2012
    Pittsburgh, PA
    I installed a new battery and the car did crank a bit extra but starts fine. The old battery stated it was good but wasn't holding a charge i assume. If it won't start anytime soon I'll know it was not the battery but so far changing the battery has solved the issue. I did not get a chance to drive it on the high way for a long time but i will take it out on Sunday give it a nice run and see if i experience any issues at all further. Apparently Audi batteries can go bad in 22 months....
    Aug 22 2015
    Cincinnati
    Audi OEM batteries now have a 4 yr, full replacement warranty (no prorate.) From my research, that beats any aftermarket battery warranty, they are competitively priced, and there is no issue with recoding VAG COM.
    Established Member Two Rings JohnnyTooBad's Avatar
    Aug 14 2009
    NoVA
    Bringing this back up. I just put as new battery in my car. It's an Autocraft H8 AGM from Advance. So I have 2 questions. The battery has no codes of any kind written on it. If I were to enter codes, would I just try to find any similar codes for a 950CCA AGM battery? Also, how do I enter the codes? Do you have to have a VAGCOM? I looked through the MMI and didn't see anything. Maybe I didn't look in the right place?
    (DEAD) 2006 B7 A4 Avant 2.0T. Blue/Tan, Auto. 100% Stock, except for some window tint
    Replaced with a unicorn.... 2011 A6 Avant 3.0T, also Blue/Tan. Premium Plus, S-Line, Cold Weather Package.
