Results 1 to 40 of 63
    Jan 15 2010
    Santa Barbara, CA
    Absolutely best control arm kit?
    I recently installed TTX Ohlins, and at the same time had all of the control arms, tie rods, and front sway bar links replaced. The shop that did the install just ordered the kit their parts guy recommended, which has proven to be junk. I've had non-stop squeaking from something up front (likely the upper control arms), and a lower control arm boot is already torn 3 months later. I'm also getting clunking over broken pavement, similar to the sound one gets when all the control arms are getting old.
    I'd like to replace the entire kit with the best components I can get. What's the best overall kit or set of control arms and links I can get for a primarily street-driven car (with the goal of comfort and reduction in noise, so no solid bearings)?
    Thanks in advance!
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    give 034 a call
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    I've got the 034s.
    installer said they are a great piece of kit, but a pain to instal
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    OE, in my opinion.
    It seems aftermarket never last as long.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Established Member Two Rings WTF its Arturo's Avatar
    Jun 08 2011
    C8 RS6, B9 SQ5, B7 RS4
    034 Density line UCAs. They're local to us as well. I've used these UCAs on my B6 avant and my RS. One of the nice things about them is that they'll warranty their parts for a year after you have them install it.
    I think the only other comparable options are the Stern UCAs, which I'll let other folks chime in about them.
    Garage
    Ultra Blue RS6 | Sprint Blue RS4 | Ibis B9 SQ5 (wifey)
    IG: @rs.turo
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    replaced stock UCAs with 034s at 60K. Original ones were 80% shot. These have been solid for the last two years. 🏼 sucks that part guy didn't know his parts!
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    I had several sets of 034 control arms installed by 034 on my B6. They did seem to wear out quite quickly, but 034 would replace them without any hassles. Adil is a good dude
    Mar 13 2011
    Perth Australia
    Quote Originally Posted by LINDW4LL View Post
    OE, in my opinion.
    but OE arent adjustable, so if you want to lower the car, you will wear out tyres a lot faster than the control arm bushes
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    I went with Sterns. They seem to be decent so far.
    Ghost
    Apr 20 2009
    Orange County, CA
    I've had CPT units with my Ohlins for ~5 years with no problems
    2007 Audi RS4
    Milltek exhaust//Stasis MS suspension//CPT control arms//TTRS steering wheel//JHM shifter/intake spacers//Apikol trans mount//034 diff mount/rear sway bar/endlinks
    Sep 27 2011
    Tomatoes
    Eastern PA
    My sterns lasted about three years and two winters before crapping out. I think their biggest downfall is the lack of dust boots. Put on the 034 kit this summer and so far so good but only time will really tell if they last any longer.
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Sep 20 2015
    I have Sterns and they seem good so far. Sterns are easy to adjust and are serviceable.
    Jan 15 2010
    Santa Barbara, CA
    OK, thanks guys. Since I have my car serviced at 034, I'll just ask Adil about their kit. I don't run the car very low (26" all around), so I'm not sure if adjustable uppers are necessary.
    Veteran Member Three Rings musasabi's Avatar
    Aug 11 2014
    Chicago, IL
    Another vote for the 034 Density kit (non adjustable, in my case). A year so far. =)
    The only pain installing them was getting the OE's out of the stupid upright.
    Oh, and breaking one of my DRC lines.
    2014 S4 | 6MT, Moonlight Blue, Black Optics, Sport Diff, Navi+, B&O
    2008 RS4 | Daytona Grey, Titanium, Exclusive
    2013 Jetta TDI | 6MT, Fender Audio, Sat Nav
    2003 Passat GLS | 5MT, APR 93 Tune, Koni FSD/Eibach Pro Kit, Magnaflow Muffler
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by musasabi View Post
    ugh im scared to do that too. more of a reason for me to do coilovers while doing arms
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    034 density! Love them! Come with dust boots. 2 years running
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by skhan91 View Post
    Ahh, just be careful. I did my passenger's side without so much as a scare. I only broke my driver's side because I was rushing.
    Plus, I don't know about you, but I feel good about keeping my DRC's. They're the right ride height for my Titanium rims, they're stiff enough and supple enough for me, etc. Basically, I bought an RS4 because I think Audi did it almost perfectly.
    I went with the 034 arms because the kit was cheaper than OE and I trust the brand. But my DRC's are already the second gen units, so I was glad to keep them.
    So save the magic hydraulic sticks and just be careful. =D
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    yea for now im keeping the suspension. its fine for what i need but might do coils in the summer!
    Apr 03 2012
    Raleigh, NC
    What are you going to get?
    Sent from my Galaxy Nexus using Tapatalk
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    For those with the 034 UCAs what camber are you able to get before being maxed out?
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Jun 08 2011
    Quote Originally Posted by MattboyR32 View Post
    I'm maxed out at around -2.1/2.2
    Garage
    IG: @rs.turo
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Love my 034 kit
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Jan 14 2009
    Audi's
    Just ordered 034 adj UCAs along with rear sway bar and adjustable end links
    Apr 24 2010
    you can always keep the DRC and get the KW H.A.S. kit 🏼
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by singleframe View Post
    can that be installed without recharging the DRC system?
    Sent from my SGH-I337M using Tapatalk
    Nov 28 2006
    yes, the install instructions are floating around the KW website somewhere with pics. basically tilt it out and do the spring change with drc still connected.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    I was under the impression, anytime you are changing the springs out on the DRC you will have to discharge/recharge the system? I initially jsut wanted to do H&R springs on DRC
    Jun 18 2009
    Phoenix, AZ
    I have H&R's and never had to discharge my DRC system. It's a tight fit and it's best to have an extra set of hands to help, but you can drop the strut down and then point the top of it out of the fender well enough to get to the nut ontop of the strut assembly to remove the top mount, then swap the springs and put the nut back on and put the strut back into place. Like I said though, it's not easy, but it is doable.
    2017 Camaro SS 1LE
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by FWP! View Post
    hmmm okay.
    i am planning on having my local shop do it so I'm guessing an actual mechanic shouldn't have trouble with it as oppose to me possibly Fing up the DRC
    edit: sorry for thread jacking! :S
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    skhan, I have the KW HAS kit. Riegel did the install and no problem with the DRC as mentioned above.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by musanoadsaba View Post
    awesome! i will call them up again. got a very high quote $$ last time on coilovers
    Mar 14 2014
    E46 M3 [sold] | Audi RS4 [sold] | 2010 GTI [sold]
    Northern Ohio
    I'm about to do my uppers - I found a DIY for the S4 how different is the RS4 swap with DRC? or does someone know of a DIY more specific to the RS4 for replacement of uppers? sorry for the somewhat threadjack... :)
    2015 Sepang S3
    APR Stage II [ ECU & TCU ] AWE SwitchPath Exhust | APR downpipe | Neuspeed RSe102 wheels
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by voidopolis View Post
    Just be careful with the DRC's. Mind that the steel flex line to the shock doesn't get put at any uncomfortable angles and you'll still have plenty of room to work. Like I said, I only ruptured my driver's side because I rushed it.
    Jun 18 2009
    Phoenix, AZ
    Just ordered a set of 034 front lower control arms, I already have SPC adjustable uppers. $300 shipped.
    2017 Camaro SS 1LE
    Jan 15 2010
    Santa Barbara, CA
    My car is at 034 right now getting some suspension issues resolved (previous installer botched the TTX install), and getting their front control arm kit installed. Will report back when I get the car back.
    Jan 15 2010
    Santa Barbara, CA
    Final update - car is back from 034 with their complete front set of Density Line control arms. No noise, ride feels great.
    I have the parts the previous installed used, and it turns out they were Febi/Bilstein, which are supposed to be high quality. Unsure why they were making noise. I have to assume the previous installer did something wrong, since he also made two other mistakes when installing my Ohlins. If anyone wants a complete set of controls arms minus the lower driver side (which has a torn boot) for dirt cheap, let me know.
    Active Member Two Rings samman01's Avatar
    Dec 23 2010
    Gaithersburg, MD
    Are the O34s better than the OEM? Majority of what I have heard is that they are best at price point.
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    Im getting they're upper control arms as soon as i come back fromvacation
    Sent from my iPhone using Tapatalklk
    Jan 29 2010
    north ga
    I got a set for sale for $315 (shipping included) with the brand new rebuild kit, so basically a brand new set of UCA's for $120 less than what 034 charges
