Results 1 to 17 of 17
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    Audi A7 Standard Stereo vs...
    I doubt many people here get bare-bones A7, but that's precisely what I'm looking at.
    Just curious if anyone has any first-hand experience between the three audio options: standard, Bose and B&O.
    I'm not an audiophile or bass junkie, per se, but I do enjoy listening to standard fare at moderate levels.
    Can anyone share their thoughts between the three audio systems in the A7?
    Thanks.
    Established Member Two Rings SunDevil's Avatar
    Aug 18 2015
    Scottsdale, Arizona
    It's a fact that you spend a majority of your time IN your car. The interior/sound is very important. Especially in a luxury sports sedan such as an A7. I could care less about the stereo if I was in a Ferrari or R8. I had B&O in my R8. Not sure I could tell the difference with my Bose in my A7. At the very least .... get the Bose. You'll thank me later,
    Current: 2016 A7 Prestige. Ibis White. 20"s
    A8 Black
    996TT Arctic Silver, 6 manual .... my 1st dream car
    997cab Black, 6 manual .....utter disappointment
    997TT Guards Red, body colored grill, 6 manual
    R8 V10 2010 Blue, gated 6 manual
    Veteran Member Three Rings BlueSVT's Avatar
    Oct 06 2013
    With aftermarket integration becoming more difficult in modern cars, having an upgraded sound system from the factory is almost a "must" if you really enjoy music and don't want to spend a lot of time and money retrofitting an aftermarket system.
    I have the B&O and absolutely love it, but I haven't had the Bose to compare to. From what I've heard the Bose is also great, just not as clear all around, or as loud before distortion is noticeable.
    Arguing with an engineer is a lot like wrestling with a pig... After a couple hours you realize the pig likes it.
    Sep 05 2012
    Boston
    I bought my car used and it happened to have the B&O which is decent. If I were to buy new I would not have gotten that.
    What is the price for the Bose option? I am curious as I know for sure I would have saved the B&O money and spent about half on a system that is much better. If the Bose is around 2k I wouldn't but it.
    Senior Member Two Rings Glacier6's Avatar
    Mar 11 2014
    Chicago
    Quote Originally Posted by fantaxp7 View Post
    Bose is standard on Prestige and only $850 upgrade on Prem Plus. If you step down from B&O to Bose you will absolutely notice a difference. Just wait til you get a 6 or 7 loaner with the Bose. Albeit, it's probably not worth the $4k price difference.
    2019 Q8 Prestige Daytona Gray / Year 1 / Black Optic / S Line / Luxury Package / Alcantara
    2012 A7 Prestige Quartz Gray / Innovation Package / Driver Assistance Package / Sport Package / LED Headlights / B&O / 20x10 Niche M116 (Gone)
    Sep 05 2012
    Boston
    Quote Originally Posted by Glacier6 View Post
    $850 may be worth it. But as I understand it from reading user's reviews, it's not very good. But for $850 you wouldn't get far at all with an aftermarket setup...
    So as with all things audio, it's best for you to go listen to the differences.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    There is quite an appreciable difference between the bose and beo. Much bigger of a difference between the stock and bose. The price difference is huge though- $850 vs $5000 . There are a lot of people who have gone the aftermarket route with good success. I would at the least get the bose. Not as good as beo but miles better than the stock. Plus you can use lossless codecs for your music - it does make a difference!
    Sent from my SM-N920P using Tapatalk
    Oct 25 2007
    Scottsdale AZ
    curious,
    can someone more knowledgeable with the bose & b&o systems and going aftermarket chime in, bose is easier to upgrade/go aftermarket yes? why, in detail?
    16 Glacier S6 - Sport, Black Optic, Layered alum, Bloze
    13 Orca Black Q7 - TDI Prestige - S-line - S-line Plus - Air Suspension - B&O - Tech - Towing
    16 Nardo Gray RS7 - GONE
    11 Ibis S4 - Prestige - Titanium - Sport Diff - APR Stage 2+ - 35% Huber Optik - Black BBS CH-R 19x9.5 - KW SC coils - E-codes - RS6 Air Shifter - AK and USS sway-bars and end-links, GONE
    08 GMG S5 - GONE
    01 Casa S4 - GONE
    Veteran Member Three Rings dennisg's Avatar
    May 11 2013
    United States
    Generally the consensus is that going aftermarket can get you a much better system for the money than you will spend on the B&O option. For the S6 it was 6k to go from Bose to B&O. I have not heard the B&O that much to know how much better it is than the Bose, but I chose to go aftermarket and my car sounds amazing at this point. I ended up spending more than 6k but I went pretty high end. You could spend less and get WAY better than the Bose.
    The Bose was OK but not good enough for me. I am not sure if the B&O would have satisfied me. I am pretty picky as I used to have a recording studio and have a lot of fantastic quality audio experiences in my memory banks. If you want the least amount of hassle, getting the car delivered with a system that is satisfying to you would be the best. You will have to listen to determine if any of those systems will do the trick.
    If you decide to go aftermarket, you first need to find an installer that you trust to take your beautiful new car apart. I was going to stay with the Bose for that reason, but I found a very talented installer while getting radar detector/laser jammers installed. The guy knows how to take an Audi apart and put it back together without any evidence of it being done. And then someone that can tune it for you. No guarantees, there are a lot of hacks out there. So the aftermarket route is more challenging, (finding people/selecting components) but potentially much more rewarding
    Probably the biggest factor in the improvement of my sound system was using a device like a Mobridge or Audison Bit DMI to tap the digital signal right off of the MOST bus and bypassing all of the Bose amps and processing. From there you use a programmable standalone processor to feed the amps/speakers of your choosing.
    HRE ADDICT
    2013 S6 Phantom Black Pearl, self inflicted Black Optics, 20" HRE P101, brushed dark clear, CF Caps, Tikor lugs, H&R ETS, AWE Touring Exhaust... Eurocode sway bars. Disc Italia ceramic pads. Bel Stir Plus w/ radar mirror display, AL Priority quad "parking sensors" ;-). Hertz Mille speakers, 3 way front/2way rear, Audison Bit DMI, Audison Bit One, Audison Voce 5.1 amp, Audison Voce Quatto amp, Hertz ML2000 sub.
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    In C7 platform I have been through all 3 systems and may share my experience a bit.
    Base - Just okay to listen but don't expect much...actual should not expect any at all. Although A7 is several times more expensive than a Camry but the base stereo in both cars are more or less the same.
    Bose - It's definitely an upgrade from Base Stereo and it's pretty decent if you have never listened something better. Well, actually in my other car I only replaced base speakers with JL-Audio speakers and the sound overall is already better than Bose in my then S6. You can tell that it's not something you can expect much out of it.
    B&O - Definitely the best among all 3 systems, it's like day and night compared to Bose. Clarity is great and bass is enough for my taste (never like chest crushing heavy bass) but $4900 upgrade option is a hefty price tag for factory sound system.
    Of course if you are some audiophile you will never satisfy with any and even the mighty $4900 B&O will not be good enough for you but you have to ask yourself that do you have any shops in your radar that you can completely trust them to work around with the electronics in your car and even if you do, are you ready to deal with the electronic issues that may arise and take time to figure out? I'm not saying you will have an issue but that chance is there and it's not low. Modern cars are so complex so some tiny errors can cause so many issues so you have to bare that in mind. If you don't want to deal with any issues and want the best sound system, paying $4900 for it may not be so bad.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Sound is in the ears of the listener just as beauty is in the eyes of the beholder.
    I had B&O in my S4, and liked it.
    My S6 has the Bose, which to me sounds at least as good as the B&O in the S4 - in some ways it sounds better. The S4 B&O isn't anything like the B&O in the C and D cars - no pop-up tweeters, nothing really fancy - just the B&O-branded speakers.
    As good as the B&O may be in the C cars, I personally wouldn't pay the upcharge, but the small upcharge to get the Bose in the A/S/6/7 seems well worth it to my ears...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Established Member Two Rings AnTarbh's Avatar
    Oct 17 2015
    2008 Q7
    MN
    I couldn't justify the cost of the B&O and I wouldn't be able to sleep at night if someone were to work on an electrical project of that scale on my car. So on both my '13 A6 and '16 S6 I got the BOSE. It meets my needs perfectly and didn't break the bank.
    2016 S6 Goodwood Green Pearl
    2014 A6 3.0 TDI Prestige Phantom Black Pearl (SOLD)
    2008 Q7 3.6l Premium Lava Grey
    2006 A4 2.0T MT Brilliant Red (SOLD)
    Dec 13 2015
    '17 Audi S7
    CA
    Thanks for the reply!
    I just learned that the car I want does indeed have the Bose option, but it still is bare bones, so to speak! The dealer said, quite amusingly and haughtily, that this car with this level of options are actually rather rare, like I'm some pauper. I kind of laughed as a pauper I am so I guess it fits me well, lol.
    I may get it tomorrow. I have another question, but I'm going to make a new thread on it.
    Oct 06 2013
    Quote Originally Posted by Frenetic View Post
    The SALESMAN said, quite amusingly and haughtily, that this car with this level of options are actually rather rare, like I'm some pauper.
    Fixed. hehe
    Jul 21 2015
    Bratislava, Slovakia
    wow, did not realized that there is a base option.. tought its only BOSE or B&O .. whats the brand of the base audio?
    May 18 2014
    Dubai
    I'd rather spend difference between B&O and Bose for some performance upgrades or similar... price difference doesn't justify for me going to B&O (unless I have unlimited budget)
    2013 Audi S6 - mtm catback exhaust - AWE S-FLO CF intake - Revo Technik Stage 1 - vKool X15 -
    Mar 29 2014
    Hampshire, UK
    Here in the UK we also have 3 audio options:
    No cost base option
    Bose option at $1,500
    B&O option at £10,000
    Couldn't justify the 10k B&O option, so just optioned out my S7 to a similar value. Bose is good enough for me
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
