Results 1 to 21 of 21
    Jan 03 2010
    Socal
    TPMS Light wont go away
    Hey.. so i have a 08 A4 2.0T if that makes any difference...
    But the light (!) has come on and it will not go away. I have taken it to 3 tire places and all of them assure me the tires have correct pressure (Even the spare in the trunk was checked)
    I know how to use the dash menu and resent tire pressures and wheel replacement....
    Whenever i reset the tire pressure light it goes away but then comes back after driving maybe 100-500 yards.
    would this likely be tire pressure sensor fail... or something else?
    Is there a way to just make it go away.
    Thanks,
    Oct 16 2008
    South Florida - Ft Lauderdale
    VAGCOM IT OUT
    Phil
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Check all your tire pressures, then set the psi a bit lower on the menu. Example: tires @36psi, computer menu to trigger @30psi, or raise the threshold a bit higher.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Also, remember to check your spare tire pressure!
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jan 03 2010
    Socal
    You can vagcom it out? does it basically disable that feature?
    I have checked the spare.
    80sguy - how do you set the tire pressure to be lower?
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    does all the a4 version has the tpms?
    I have the canadian version, and I never got the light. One of my tire got 22psi pressure, which is very low for continental extremecontact. I have no spare as well.
    Oct 09 2007
    Miele S7
    Quote Originally Posted by blackb7a4 View Post
    Yes. I run at 39-40psi and set the warning at 30psi.
    Jul 01 2015
    Mtl
    never mind, I just figure out that tpms was an option and I probably don't have it.
    Veteran Member Three Rings DaveyDave424's Avatar
    Aug 02 2012
    LOS ANGELES
    I would assume to release tire pressure until the tires are at 30psi, then use the stalk to set that as new tire pressure. Then inflate tires to desired PSI
    Jan 03 2010
    Socal
    So I deflated the the tires (even the spare) set the pressure. Then refilled the tire pressure to required amount.... 2 minutes after driving the light came back on.... so guessing faulty sensor?
    Mar 29 2014
    Hampshire, UK
    This may help in troubleshooting:
    http://www.tirereview.com/tpms-diagnostic-strategies/
    The issue will be in identifying which TMPS sensor has gone bad, especially if your car doesn't actually tell you which TMPS sensor is alarming. Remember it might not be "bad" it may just needs a new battery installed.
    If you have or know of someone with VAGCOM, they may be able to help identify the bad TMPS sensor, or at least tell you if the TMPS receiver is good.
    If its a bad TMPS sensor, then your going to have to visit the tyre shop as removal of the tyre is the only way to get access.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    The battery is on the inside, so at a minimum you will have to press in the tire bead near it (without damaging the unit), to gain access.
    Any good tire shop has a TPMS reader that they can place near each wheel and tell you the PSI above or below the set pressure. They can also tell you just by standing next to the wheel if the sensor is not sending a signal (either battery, or bad sensor) to the unit.
    My suggestion is to either code it out with VAG-COM like others are saying, or go to a tire shop and have them diagnosis/resolve the issue.
    Oct 09 2007
    Miele S7
    Did you set the appropriate psi threshold on the obd so it can trigger?
    Jan 03 2010
    Socal
    does anyone have a vagcom in the area? Im close to Santa Monica / west La area.
    Called the euro place I usually get work done and they wanted $50 to check the sensors.
    Veteran Member Four Rings jschrauwen's Avatar
    Aug 08 2013
    08 R8 TT, 08 A5 3.2 QTip, 90 300ZX TT 572whp 590wtq, Ducati TT2
    Frankford, Ontario, Canada
    The battery in the TPMS sensor is not replaceable. It's a sealed unit so when the battery fails (life expectancy is ~ 6 to 10 years), the whole sensor needs to be replaced.
    The sensors work on 315mhz which a good tire shop should be able to easily read each sensor's signal/pressure reading.
    A 315mhz type of TPMS sensor is quite common and was used on a number of various makes/models of cars including the 2003+ 350Z.
    I just received 8 new TPMS sensors - 4 for my oem wheels where the batteries are beginning to fail and 4 for my winter wheels that never had any.
    15977338_10154350404203613_4087424888749673974_n.jpg16003051_10154350404453613_636360174283366912_n.jpg
    2008 A5|Ice Silver|3.2 QTip|Premium Pkg|Technology Pkg|B&O & JL10W0-4 sub|15/20mm spacers|HID Fogs|Ext. & Int. LED's|RS5 grill|AWE/K&N Intake|Quad tipped OEM mufflers|CF Mirrors, Spoiler & Diffuser|Facelift Ecode Tail lights|CR-15 Strut Bar|Ecode headlights|Alu Kreuz|ProdigyWerks 6pot 2pc 356mm front 350mm 2pc rear BBK|Eibach springs
    2008 R8|Ice Silver|R-Tronic|Huffman TT Conversion|Focal/Mosconi stereo upgrade|H&R Coilovers|HRE wheels
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    I've had 3 of the sensors removed from my wheels and regular valve stems put in. I intend on coding out the TPMS because it has always shown an error.
    Oct 09 2007
    Miele S7
    Quote Originally Posted by jschrauwen View Post
    I need to do mine because my sensors are gone. It's been gone for almost a year now. Orange TPMS glowing on my dash. Get the annoying high pitch BEEEEEEEP every time I put the car in gear. Are they pretty easy? Can a regular tire shop install them?
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    I get the nice TPMS sensor light every time i turn my car on. I dont have TPMS sensors on my car. VAGCOM is bro. Not really a bother to me when I have a Christmas tree of lights on my dash.
    Aug 08 2013
    Quote Originally Posted by drmonkey View Post
    You deleted/disabled a perfectly good system because you didn't want to replace the sensors?
    Quote Originally Posted by 80sGuy View Post
    I am trying to find out more details on the actual replacement process. Part of my search has found that the sensors may need to be programmed first. I'm not sure if that's a generic TPMS thing or if it's Audi specific. And I believe I may have read that they may need to be coded in via VCDS after that programming.
    But a good tire shop who has a TPMS reader can determine which sensor has failed and what the tire pressure is on the serviceable ones.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Mine are showing errors too, Im just going to turn them off since I check them whenever I wash my car, which is bi monthly usually
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Aug 08 2013
