Results 1 to 18 of 18
    Established Member Two Rings ShadowA4's Avatar
    Aug 15 2010
    Harlingen, TX
    Lightbulb Due for control arms: OEM vs VAICO vs Lemforder
    Hello all,
    As the title suggests I am in need of a full set of front control arms (Upper/Lowers on both sides). My vehicle falls under that category with the high speed vibration, however, I've just grown used to it over the years. The car is now approaching 80k miles, and it's due to for a control arm refresh. I've looked over some of the available options, but I only found the following COMPLETE kits for the front:
    OEM, either from ECS or Stealership.https://www.ecstuning.com/Audi-B8_A4...Arm/ES2712645/
    Lemforder https://www.fcpeuro.com/products/aud...rder-b8cakitoe
    VAICO https://www.ecstuning.com/Audi-B8_A4...Arm/ES2795510/
    I am aware of other options such as Meyle and 034, but neither of these companies sell a COMPLETE kit. The reviews and threads on multiple forums are very mixed, so I'm looking for some fresh input from direct experience. Price differences are considerable across these kits, so I'm looking for a good balance between cost and reliability. Thanks.
    2009 Audi A4 Quattro Premium
    Performance: APR Stage I, Ecode IC Pipe, Conti Ext. DW
    Practical: Hardwired V1, Live Scangauge, StopTech PosiQ
    Cosmetic: Debadged, CF Mirror Housings, Red Front Calipers, Custom Plates with CF Holder, BLESK LED, Plasti Dip Grill
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Why don't you just replace the bushes I had a vibration issue and that went away after that.
    Aug 15 2010
    Harlingen, TX
    Quote Originally Posted by bluetori View Post
    I was under the impression that around 50k the control arms began to rattle, noise, clunk anyway, so I was planning on a complete overhaul. I know you can buy the bushings seperately, but with a car almost at 80k wouldnt it be best to change it all out?
    Jan 14 2010
    Georgia
    No the control arms are not failing it's the bushings that fail, and a I replaced all of my bushes for a quite a bit less, but if you want to spend that much go ahead. Oh and I got to around 100k before replacing mine.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    OE arms are either TRW or Lemforder. Stay away from Vaico, it's Chinese crap. If your doing the work yourself and have a shop press you can replace just the inner bushings, but if not, your paying labor to have them pressed in, it's certainly way easier to replace the whole arm, I'd go with the Lemforder Kit if you can't find a TRW one.
    Aug 15 2010
    Harlingen, TX
    Damn, literally a case of YMMV. Thanks
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    Meyle makes a HD bushing for the lowers too.
    Aug 15 2010
    Harlingen, TX
    Quote Originally Posted by o1turbo30v View Post
    I was leaning towards Lemforder already, not nearly as affordable as Vaico, but the quality issue keep coming up when comparing them.
    If your doing the work yourself and have a shop press you can replace just the inner bushings, but if not, your paying labor to have them pressed in, it's certainly way easier to replace the whole arm.
    I'm having a shop install them. I get what you're saying about install cost being similar for bushings vs. arms, and of course I'd rather pay for just bushings. However, I don't want to have to replace the arms later on if I can do it already.
    Aug 15 2010
    Harlingen, TX
    Quote Originally Posted by Dub_prime View Post
    What's your take on replacing bushings vs. arms altogether?
    Nov 03 2007
    A6(C7.5), Q7(4M), Q5, A5(B8.5), Escalade(MY08/MY15), H2, 360
    Is there a DIY I am thinking of doing this soon.
    Jun 26 2009
    Bremerton WA
    I replaced 4 upper control arm bushings. I had started writing a DIY but once into stopped. I ended up having to make my own bushing press by grinding down a socket to the appropriate size. None of the control arm kits and adapters that Oreilly carried fit properly. Once I had to make tooling I felt it wasn't really a DIY that most would want to tackle. Shopping around I had run across the 4 upper arms for some good deals; and they are very easy to install. You can jack the car up a few inches and even do the with the wheel still installed. I would try the upper arms first and see it that fixes your vibration issue. The uppers don't even drive an alignment check afterward.
    VMR 710's, APR software, Eurocode HFC
    Sep 10 2012
    Bham AL
    Quote Originally Posted by ShadowA4 View Post
    Same as the others, if you can DIY it you can get a better bushing, but there is actually more labor involved. Plus sourcing the races and fittings if you don't have them for the press.
    Sep 10 2012
    Bham AL
    Quote Originally Posted by lx4life View Post
    No real need for a DIY except for the torque specs, if you are doing the arms pull out the old arm and replace with new arm. Same for the bushing except for the extra step of removing/reinstalling the bushing.
    Jan 14 2010
    Georgia
    Yeah you just have to remove the pinch bolt that holds the control arms to the spindle assembly.
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    I don't have any high speed vibs, but I think my ride is on it's way to needing to be re-bushed.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    https://www.europaparts.com/ultimate...b8-q5-sq5.html
    Europa has a better price on a quality kit
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    Quote Originally Posted by A4QuattroV6 View Post
    That's a nice kit. If I still have my Q around 100-120k miles (mostly highway commuting miles), I'll probably do something along this line.
    Jul 16 2008
    Finland
    The kit in the Europaparts kit is not for the B8, BTW. The listing seems correct though. I'd stay away from anything other than TRW / Lemforder. You don't want to re-do this after 20k miles just because you cheaped out on parts.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
