Results 1 to 40 of 48
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    What brand of coolant do you use on your A4 B8?
    Hey everyone,
    My coolant level is low and has been low for some time and I was thinking of heading to the dealer to get it topped off, but figured I should look to see what brand you guys were using, if any, from your local auto parts store.
    I'm thinking of going over to AutoZone to check them out, but thought I'd post here. I did find this thread in AudiWorld when performing my search, but it doesn't really delve into aftermarket brands you can find at a local auto parts store.
    Looking forward to your suggestions. Thanks!
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Doesn't help your aftermarket brand search, but I ordered G13 from ECS when I changed my turbo. I knew I needed it, but didn't feel like driving to the dealer, so I ordered it. Curious to see what other members suggest.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Oct 09 2008
    I use g12(++?) Or is it G13 now?
    The Awesome™
    Aug 10 2011
    North Whittier
    I do believe G13 is the new standard, according to ECS tuning. But I'm wondering whether there's an aftermarket equivalent available at a local auto parts store.
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Pentosin Pentafrost. Literally the same stuff at OEM. (Pentosin makes the OEM coolant) Available at basically any parts store. But to be honest, it's not that much cheaper than the dealer.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Aug 06 2012
    Parker, CO
    I just bought a gallon of G13 at the dealer for $20.
    Aug 06 2012
    Parker, CO
    And yes...... G13
    Is the new standard
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    $9.25 for 1.5 liters at rmeuropean. Site has great prices and a lot of options for our car.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Aug 10 2011
    North Whittier
    Thank you for your responses.
    After further research on the Pentosin brand, I came across two Pentosin products that can be used on our B8's (and any Audi 2006+)
    Pentafrost E - (Violet) This one is the latest Pentosin product that can be used in our B8's.
    http://www.pentosin.net/specsheets/Pentofrost_E.pdf
    Pentafrost++ - (Pink) This can also be used but has been replaced with Pentosin E.
    http://www.pentosin.net/specsheets/Pentofrost_++.pdf
    Both can be found at your local auto parts. I found both of these for under $15 online and in stock, so I'm planning on driving over and picking one up.
    I had called the dealer before 6pm, which is when they close) and asked for a quote and they quoted me $30 but didn't mention the size. I imagine it's for a gallon. Since I only need to top off, i plan on simply buying the 1.5 Liter container for under $15. The parts associate said that I wouldn't need to dilute with water if I was simply topping off.
    What do you guys think?
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    If you go dealer coolant, you can knock a few bucks off by getting it at VW. Why is your coolant low?
    Aug 10 2011
    North Whittier
    Quote Originally Posted by MacFady View Post
    It's just under the "Min" mark and I read that it naturally evaporates over time, so I imagine that is why. I guess I should check for leaks, but I don't think I have any.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by doowopaudi View Post
    Mine was the same at 96000 miles. Took about a 1/3 of a liter to top it off.
    Aug 10 2011
    North Whittier
    Fixed.
    Jun 23 2013
    PacNW
    There are a variety of options as multiple people have posted for *replacing* the coolant in the engine during a drain/fill.
    If you're topping off - I would use only the OEM fluid or distilled water. I don't have a great reason for this except then you're guaranteed to have no problems and a single bottle is not very expensive.
    If you stay out of the mountains I imagine you can get away with significantly more DI in your coolant system being in California - so you could just fill up with DI water and not buy any coolant.
    Default 50/50 mix is good to -37C, and the back of the bottle says 40/60 G13/Water is good to -24C (-11F)
    Another interesting page:
    http://www.cabby-info.com/cooling.htm
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Fixed.
    Nice transmission!
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Prestone "any make, any model", $8 at Walmart. Been using it for over 15 years in all my VAG cars.
    Feb 06 2012
    Allentown, PA
    OP, look under your intake manifold, the leak is probably coming your water pump assembly.
    Active Member Two Rings backslide's Avatar
    Nov 06 2010
    Colorado Springs, Colorado
    I use whatever Audi uses lol.
    Sent from my Nexus 5
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    Just remember there's some coolants you can't mix with the OEM.
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Spike00513 View Post
    Curious to know how, since it's a closed system kept under pressure.
    Good question. It doesn't make sense to me either how that can happen. I found this thread that suggests the dealer believes it's normal for the level to go down without any leaks.
    See post #14.
    Veteran Member Four Rings inNout's Avatar
    Jul 22 2009
    IL->WA
    Pentosin G12 Coolant For Aluminum Engines (1.5 Liter) https://www.amazon.com/dp/B001GRNS6Y..._9noBwbA42A819
    This is what i plan on ordering to top off my reservoir.
    2010 B8 2.0T 6spd K04 + [HPA Motorsport, Rays, APR, Eisenmann, Bastuck, Eurocode, KW, OSIR, StopTech, ArmaSpeed]
    Aug 10 2011
    North Whittier
    Quote Originally Posted by inNout View Post
    AutoZone should have it for about $14. By the way, read above. Pentosin++ has been replaced by Pentosin E.
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    I use this stuff in my MK4 R32:
    http://www.hstuning.com/product_info...oducts_id=3709
    Is it equivalent to G12 or G12+. Concentrated so all you do is add distilled water to get to the ratio you need. There is a G13 equivalent also made by Motul but I haven't found it yet stateside.
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    If you were just topping off you could of saved yourself the headache and just used distilled water. 1 gallon is typically under $1.00.
    2024 RS3 Kemora Gray
    Jan 03 2013
    Baltimore
    I know the manual does not call for a coolant flush, but are any of you all completing this and if so what interval? I would imagine it would be good practice but did not see much when I searched.
    Sent from my XT1096 using Tapatalk
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    Quote Originally Posted by o1turbo30v View Post
    Correct. That's all I've used in bikes and cars for years. I even called Prestone to be certain if it was ok in the Audi and he said it's totally fine.
    Quote Originally Posted by integroid View Post
    This is the route I would have gone.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
    Aug 10 2011
    North Whittier
    Darnit. Wish I had known. I was under the impression that the mix ratio had to be exact, but in the event that it couldn't be exact, topping off with coolant would be the best thing.
    Oh well, at least I didnt blow $30+ on a 5 liters of that stuff.
    Thanks for the input, nonetheless.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    I just noticed I'm at the low coolant mark so I ordered 1.5L of Pentosin 8113106 Pentofrost E Multipurpose Antifreeze Concentrate which I assume I need to dilute 1:1 in distilled water.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Aug 10 2011
    North Whittier
    Quote Originally Posted by booost View Post
    Cancel your order! Simply add distilled water. No need to have the exact ratio mixture when topping off. Save your money.
    Jul 17 2008
    IDK man, water boils at just over my coolant operating temp, also it can get below freezing here in the winter. Why not just do a 50-50 ratio?
    Aug 10 2011
    North Whittier
    Ah ok. Then do what I did. Top off with the pentafrost e. Dealer told me there was no need to mix for top offs. Try giving your dealer a call and see what they say.
    Established Member Two Rings uberwgn's Avatar
    Mar 29 2011
    '06 A6 Avant, 2015 Q5
    Boston suburbs
    My local Advance Auto Parts has quite an array of Pentosin products now.
    NAPA also sells Pentosin but a lot of times they don't know it...
    Aug 15 2014
    i've always used OEM coolant ever since I read that certain coolants could possibly harm rubber seals, gaskets, etc. IMO, it wasn't worth my time to research and figure out which off name brands would work.
    I typically check on the fluids here and there so I've never had to "run to the store" in an emergency to get the car up to levels.
    I think we're talking a $20-$30 for a container of OEM VAG coolant?
    For Sale: Mini Part Out
    Mar 01 2013
    Atlanta, GA
    a 49-51% ratio wont make any noticeable difference in freezing temps or boiling temp. Water is evaporating to begin with so if anything, the ratio of coolant is to high if you are barely below the low mark.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Yup....gotta be careful when mixing coolants. I have been told by a few mechanics that if you mix coolants together they can seize. I felt it best to stick with OEM for top offs but if I was going to do a full coolant flush....you could use any of the above mentioned. Adding distilled water is fine provided that you're not in deep freeze temps.
    You should check your water pump for leaks (Known issue)....I had three water pumps on my 2009 A4. From 2009-2011, seemed like everyone who had a drop in coolant level had a pump replacement.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    mines on the same level. can i just pour g13 in there?
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jan 03 2013
    Baltimore
    Bringing this back. Anyone have a process or tips on completing a coolant flush and the refill process to remove air from the system?
    Sent from my Pixel using Tapatalk
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    You can just drain the coolant from the lower drain on the drivers side and then re-fill with fresh coolant from the tank after closing the drain. That's what I did. Probably not complete but got fresh stuff in there.
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by JeriQo View Post
    sure can.
    Jul 08 2015
    Quote Originally Posted by JBAeroEngineer View Post
    sure can.
    should i do 50-50 distilled?
    i have a gallon of G13 and i dont feel like running to the store and getting a gallon of distilled water
