Page 1 of 15 12311 ... LastLast
Results 1 to 40 of 591
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    B8/B8.5 Buyer's Guide and "Looking to buy" Question Thread
    Long overdue, but I think that it's way past time that we compiled purchase advice into one single thread which hopefully we can get stickied. If anyone has additional specifics to add, post it below and I'll work to integrate as much as possible into this initial post. Anyone with questions about a purchase they are considering can feel free to post here for advice and feedback.
    For anyone looking to buy a used or CPO B8 (2009 through 2012) or a B8.5 (2013-2016), they're great cars and generally very reliable. This thread will hopefully answer some common questions about the cars, and provide some specific things to consider and watch out for when purchasing. If you are looking at an older or higher-mileage car, please see the bottom of this post for maintenance to be aware of.
    - 2009 was the first year the B8 platform was sold in the US. It was also the only year that the 3.2 V6 was available. Most 2.0T motors from this year, a decent percentage of '10s, and some '11MY cars were affected by severe oil consumption, requiring a PCV replacement (stage 1) and usually a full engine rebuild for new pistons and rings (stage 2). These repairs were almost exclusively done by Audi dealerships. If you call a dealership with the VIN of the car(s) you're looking at, they'll be able to tell you if stages 1 and/or 2 of the consumption fix were completed. If stages 1 and 2 completed, you're in the clear. If they weren't, or if only stage 1 was done, run; you don't want to pay for that $4-6k repair out of pocket. On a car with an unmodified motor, Audi extended the warranty for this car to 80,000 miles. Some people have had the repairs covered with modified cars, and some have also been covered until slightly over 100,000 miles. YMMV on both of these. The other early-build issues were intake manifolds cracking, control arms which caused a vibration at high speed, usually above 65 MPH and a power steering hose that would cause the wheel to shudder during slow-speed parking lot maneuvers. These were covered by Audi under service bulletins. If a seller has proof that they were resolved or Audi confirms that the repairs were done, you'll probably be fine. A lot of 2009 and a small percentage of 2010 cars also have a manufacturing defect which causes the turbo to fail prematurely. The wastegate was made of an insufficiently strong metal, causing it to bend over time and bleed boost. It isn't serviceable and requires a turbo replacement. A dealer should be able to confirm whether a given car was affected and whether or not the turbo was replaced.
    - 2010 cars have significantly fewer issues than 2009s. A much smaller percentage were affected by the intake manifold, oil consumption and turbo issues, and the control arms and steering shudder were resolved.
    - 2011 cars were yet better; the oil consumption issue was almost completely resolved by mid-year production and the issues with the faulty turbo are no longer present. 2011 also marked the switch to the 8-speed automatic transmission (8AT) from the 6-speed (6AT) auto used in 2009 and 10 models. 2011 and '12 Premium trim level cars no longer have heated seats as standard equipment. Prem+ and Prestige do still include them.
    - 2012 cars had no significant issues, however a very small percentage still suffered from high oil consumption.
    - 2013 was the switch to the B8.5, which is mostly just a facelift. The Avant was also discontinued in the US and replaced with the Allroad, which has a higher ride height and additional body cladding. The engines and transmissions carried over, although some automatics with Quattro can run E85. The major mechanical change was the switch to electric power steering from the B8's hydraulic system. There is a noticeable difference in feel, and if you're debating between a 2012 and 2013 definitely drive both. Some early 2013 Allroads had defective electric steering racks. Audi replaced them under warranty.
    - 2014 through 2016 cars didn't change much aside from slight variations in equipment, and a slight power bump. 2014 had larger shift paddles on the S-line steering wheel with the automatic transmission, and also included the S-line exterior (see below) and push button start as standard equipment with the Premium Plus trim level.
    General minor issues that exist regardless of model year are wheel bearings, coil packs (updated versions of the coil pack largely eliminated this one), PCVs, and door lock solenoids as they age. The CVT transmission is also not known for smooth operation or longevity. Timing chain tensioners should be replaced around 100,000 miles as a preventative maintenance item. Any time the engine is apart, or around the same 100k mark, a carbon clean out can't hurt.
    I won't even try to go through all of the variations of equipment and trim level, but I'll run through the basics.
    Trim Levels:
    - Premium
    - Premium Plus
    - Prestige
    Engine/Transmission Possibilities:
    - FWD/CVT (all years)
    - 3.2 V6/6AT (2009 only)
    - 2.0T/6MT (all years)
    - 2.0T/6AT (2009-2010)
    - 2.0T/8AT (2011-2016)
    Premium model cars come with halogen headlights unless the lighting package is specified, and some do not have seat heaters. HID/LED headlights can be easily retrofitted into B8s for about $1,000, however B8.5s are more difficult to retrofit. Premium trim B8s have halogen tail lights, while some higher trims/packages (which vary by model year) also came with LED tail lights. These are difficult to retrofit into non-LED cars. B8.5 Premium trim package cars come standard with halogen headlights and tail lights, however higher trim levels (and Premium trim cars with the lighting package) come with HID/LED headlights and full LED tail lights.
    For the high-end features and amenities that Audi is known for, Prem+ and Prestige cars are the way to go. Prem+ adds tri-zone climate control, automatic headlights and wipers, bixenon HIDs with LED DRLs, more display options in the gauge screen, and other minor features. It is highly recommended to get a car with Quattro; the FWD/CVT cars are not as high-performance or reliable as the Quattro models with the manual or automatic. If you're looking at pictures and it isn't specified, MMI controls behind the shifter (towards the rear of the car) means it is equipped with navigation. If not, the area behind the shifter will be blank and there will be a knob just below the MMI screen for audio control, and one knob (for Premium trim cars) or two knobs for climate control will exist on the console below that regardless. I annotated some pictures below to illustrate this.
    Get a manual assuming that it would work for your use case. It transforms the character of the car completely, and makes it feel much more like a sports sedan. They retail for higher prices but hold value better. 5% or less of B8/B8.5 sedans are manual, and all Avants and Allroads were automatic.
    The sports package (slightly lower sports suspension, 18 or 19 inch wheels, amazing sports seats, 3-spoke steering wheel, and S4 sway bars so there's a little less flex) is also very desirable, as is the S-line package. The contents of the S-line package varies slightly by year, but it has everything the sports package has, plus S4 front and rear bumpers, side blades, and even better seats. The Titanium/Black Optics package (the name changed midway through the B8's life) was available on standard and S-line cars and contains a gloss black grille surround along black window trim. The S-line Competition Plus package was available for 2015 and 2016, and contained everything in the S-line package plus more aggressive front and rear bumpers and the black optics package.
    A note on cars with S-line bumpers: for most of the B8.5's model run Audi offered an "S-line appearance package," which gives you the S-line front and rear bumpers along with side blades and (for some reason) S-line fender badges. The interior and suspension were left unchanged. This does NOT make the car an S-line, as all "true S-line cars" have the exterior equipment, interior changes, and sports suspension.
    A few pictures to illustrate differences:
    B8 Premium with (European spec) halogen headlights:
    B8 Premium with HID/LED headlights:
    B8 (left) and B8.5 LED tail lights:
    B8.5 Premium with halogen headlights:
    B8.5 Prem+ with HID/LED headlights and sports package (note lower ride height and larger wheels than the B8.5 above):
    Standard suspension:
    Sport / S-line suspension:
    B8 non S-line front and rear view:
    B8 S-line appearance package front and rear view:
    B8.5 non S-line front and rear view:
    B8.5 S-line appearance package front and rear view:
    B8.5 S-line Competition Plus front and rear view:
    B8 standard steering wheel (this car has navigation):
    B8 Sports package steering wheel (this car is Premium trim, note the single climate control knob, and does not have nav):
    B8.5 standard steering wheel (this car does not have nav):
    B8.5 Sports package/S-line steering wheel:
    B8.5 S-line Competition Plus FBSW (flat-bottom steering wheel):
    Standard seats:
    Sports package seats:
    S-line seats:
    If you are looking at an older or higher-mileage B8, please see the list below. Thank you to member Zach L for aggregating all of this together.
    - Timing Chain Tensioner: The original Audi design is faulty. Replace around the 100,000 mile mark (immediately if you just bought a car over this mileage without any record of the repair). Severe engine damage will result if the original part fully fails.
    - Fuel Filter: Replace every 80,000 miles.
    - Transmission fluid and rear differential fluid: All transmissions, even manual, and even though Audi says they use "lifetime" fluid. Fluid change should be done every 60-80,000 miles.
    - Lube sunroof tracks: Seems unimportant until your sunroof fails. The OEM sunroof grease is proprietary. White lithium grease is an alternative, but not as good. Do this at 80-100,000 miles.
    - Brake fluid and coolant flush: These should be done every 2 years regardless of mileage, especially the brake fluid.
    - Intake valves carbon cleaning: Ideally every 40,000 miles, but most do every 80-100,000 miles. Helps fuel mileage, engine smoothness, and power. If the car has been burning oil and repaired, this becomes a higher priority as burnt oil will create carbon buildup.
    - Timing Chain and Guide Rails: Replace every 120k miles to be safe. The guide rails are made of plastic and ruts wear into them from metal chain sliding across. See pictures below.
    For more specific date on the oil consumption issue, here is a chart illustrating the percentage affected by high oil consumption by model year. For MY2009 cars it was damn near 100%, so just assume it will need to be done if it isn't documented. Thanks to @audrobotic for tracking this down.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Aug 04 2010
    Queenz/Westchester
    Excellent work
    2014: Larger shift paddles on the Sline steering wheel, Sline exterior and push button start standard with premium plus,
    2011:In the B8, titanium package (only available with S-line), offering blacked out exterior trim including the grill and window trim. Also included are black headliner and piano black trim, with the famous 19" Rotor wheels on summer tires
    2013: B8.5 Titanium package became known as black optics, offering essentially the same trim as above.
    2015: The competition models were released offering essentially the same trim as the black optics, but with black accents including side skirts, mirrors and rear valence. Wheels were the same on the Titanium package
    2016: Competition plus offered everything the competition model did but with an exclusive RS style bumper and front parking sensors
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    hopefully this will cut down on the redundancy every couple of weeks.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 24 2014
    Quote Originally Posted by bakedziti View Post
    That's the hope. I asked stubek if we can get it stickied.
    Sent from my iPhone 6 using Tapatalk
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    cue the:
    1. im new to the B8 what are the best mods?
    2. will these wheels/tires fit?
    3. best coilovers?
    4. what exhaust options are there?
    5. How do you replace your fogs?
    6. H11 or H7? i dont know?
    lol- i love the concept....there is a ton of information on products...
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Nicely done, this is overdue.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Jan 03 2012
    Wilmington NC
    i feel like this could be taken a step further and discuss aftermarket options for the most popular mods for the B8 and B8.5
    also, you need to add in (in bold) that the s-line valence does NOT fit on a non-sline and vice versa. SO therefore, an S4 valence WILL in fact fit a s-line A4 but will NOT fit a non-sline a4 because of the difference in curvature of the s-line bumper to the non-sline bumper.
    2019 S4 Build
    IG: @steves_s4
    Aug 06 2012
    Parker, CO
    Some early 2013 allroads had defective electric steering racks. Audi replaced them under warranty.
    Dec 12 2015
    Houston, Texas
    This is exactly what I was looking for but even with the info I'm still undecided between two cars.
    It's between a
    2013 Premium 8 speed automatic AWD moonlight blue with 47k miles on it at 23k - WAUBFAFL8DN012479
    or a
    2012 Premium Plus S-Line CVT FWD Phantom Black with 59k miles on it at the same price. - WAUEFAFLXCN004993 But the more I look at it and the more I read I'm thinking that someone just slapped the S-Line badges on the side and the dealer is non the wiser. It has a 4 spoke steering wheel and no s-line badge on the front grill.
    I would have really wanted a Manual with sports suspension but there is literally 1 ugly one in my area, Houston Texas.
    Any help would be appreciated.
    Mar 24 2014
    Quote Originally Posted by _thelostone View Post
    It's between a
    or a
    AWD automatic every time. If you post links we can validate about the S-line on the other one. And what's ugly about the 6MT sport? Throw some listings and we can definitely advise.
    Aug 04 2010
    Queenz/Westchester
    It's between a
    or a
    It wouldn't have the s-line badge on the front grill. It may have just the exterior package, not interior. Are there side skirts? Well doesn't matter anyway, pass on the CVT and go AWD.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Great job PQ!
    Agree, don't get CVT. Quattro is great and rear wheel biased. Better drive and more capable in winter or rain.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Quote Originally Posted by blbroo View Post
    Great job PQ!
    One of the only cars you can drive in the middle of a blizzard like its summer time with out any worry.
    "The Pedal Response Kanye West" using Tapatalk
    Jan 11 2014
    You should have used a black car to compare the Headlights on the 13+ or used two red cars instead
    Dec 12 2015
    Houston, Texas
    Quote Originally Posted by Project Quattro View Post
    The s-line 2012 CVT: http://texasauto.com/Used-2012-Audi-...TX/vd/31274791
    The 2013 AWD: http://texasauto.com/Used-2013-Audi-...TX/vd/31703931
    The MT I'm not too keen on, not sure if it's sport: https://www.autonation.com/houston/u...HFAFL6CN003403
    The reason I don't like it is purely on the color styling exterior and mores so on the interior no offense if that's someone's preference.
    I test drove the 2012 and I liked the way it handled, I was kind of disappointing that it did not have the paddle shifters and when I did put it into manual mode the transmission did not let me go above 6k rpm before automatically bumping me to the next gear. Am i just supposed to limit myself to keeping it under 6k rpm if I want to drive in high revs?
    My first car was a BMW e36 5 speed RWD, when I moved up to the AWD Volvo T5 I definitely felt the difference in handling so it's something I would like to keep, both being MT's I was worried about moving to automatic, but when I test drove it, it was snappy enough that I could live with it, and I wouldn't mind not having to ride the clutch in Houston traffic.
    Thanks again guys!
    Aug 04 2010
    Queenz/Westchester
    Honestly the 6mt looks to be the best option, it does have the Sline exterior but you're right about the interior, not very good looking. As not a whole lot of options. I would wait and keep looking, doesn't sound like you'd be content with any of the current choices, and last thing you want after purchase is regret.
    Jan 03 2012
    Wilmington NC
    No brainer, never get CVT. Might as well get a Volkswagen if you aren't getting quattro
    2019 S4 Build
    IG: @steves_s4
    Jun 21 2015
    Doylestown, PA. USA
    The MT I'm not too keen on, not sure if it's sport:[/QUOTE]
    Can confirm that it is not a sport. The sport package would have the sport suspension, 3 spoke steering wheel and the sport seats. The seats alone are worth the upgrade if you have the luxury of waiting to find the right car. And the manual with Quattro is definitely the way to go if you don't sit in stop and go traffic every day.
    Sent from my VK810 4G using Tapatalk
    Mar 24 2014
    Thanks again guys!
    First one has the S-line exterior, which a lot of 2012s came with. FWD/CVT is still a no-go though IMO.
    That 2013 AWD 8AT seems to be sold, but there's another one listed (http://texasauto.com/Used-2013-Audi-...TX/vd/31862937) which looks good. Has navigation, too.
    The 2012 6MT doesn't bother me aesthetically, I agree the gray interior isn't ideal but wrapping the trim in a black aluminum or replacing it with Audi's dark-stained wood trim would make a world of difference.
    In order, of those three, I'd get the 6MT (rare, manual is much more enjoyable), the 2013 (nav is nice), and then the 2012. All of them look like solid choices, though.
    Doing an Autotrader search with that dealer's zip code turns these up too, though...
    2013 Premium Plus 6MT Sport Package (the exact configuration of my car), low mileage, was probably owned by an Audi fan based on the RS grille:
    http://www.autotrader.com/cars-for-s...17563539&Log=0
    2013 Premium 6MT CPO (CPO warranty is nice to have):
    http://www.autotrader.com/cars-for-s...17404210&Log=0
    Given all 5, I'd buy the 2013 6MT Sport, then the 6MT CPO, then the three I had ranked before.
    Mar 24 2014
    Thanks again guys!
    Any news on your Audi hunt?
    Dec 12 2015
    Houston, Texas
    I'm planning to go check out the 2013 Premium Plus 6 MT Sport one later today thanks for the advice!
    Mar 24 2014
    Awesome, let us know how that turns out. I may be biased, but it's a great configuration to have!
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Great thread.
    Established Member Two Rings DangerBruno's Avatar
    Apr 15 2014
    01’ allroad
    Scranton, PA
    Hey guys! I'm looking at 2012 avant vs 2013 allroad. Almost identical mileage and only 1000$ price difference. I'm a C5 allroad guy so the AR has a place in my heart, but I don't wanna be a dumdum either. What's the deal with the electric vs hydraulic steering? Is the electric weird? Any help or advice would be greatly appreciated.
    Established Member Two Rings inv3rtig0's Avatar
    Oct 22 2014
    1976 Toyota Celica GT
    Paso Robles, CA
    It be worth mentioning which year switched to the metal intake manifold with the extra injector, therefore no (less?) carbon buildup concerns. 2013 I believe, but someone else on here would know for sure.
    2010 A4 Quattro Prestige 6MT S-line | build thread
    Revo stage 2 | 034 HFC | AWE Quad exhaust + downpipe | 034 trans mount insert | interior LEDs | ECS short throw shifter
    Mar 24 2014
    Quote Originally Posted by DangerBruno View Post
    It's a noticeable difference, most evident at highway speeds. The electric power steering can be disconcerting on center with a crosswind. I've had both and greatly prefer the hydraulic system, but others on here have no preference. Worth driving both to see what you like personally.
    Quote Originally Posted by inv3rtig0 View Post
    Happy to add it if we can get the correct specifics. I know that this change happened but I'm not sure when; I thought it was like 2012 or something.
    Sent from the Pedal Responce Emergency Bat Phone
    Mar 24 2014
    Updated with additional images of lighting and suspension.
    Mar 24 2014
    Updated with 16 more pictures illustrating exterior and interior differences in trim.
    Sep 09 2010
    Destin, FL
    This should be a sticky.
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    Great, i was actually searching for those answers.
    I was starting to shop for a 2011-2012 Avant, i guess i'll better stick with the 2012.
    Do anybody knows if the Avant has the same options packages than sedan?
    any links for the interiors options, i am kinda lost in the confort/sport control functions, MMI/nav/ other system advantages. What can be retrofit , which one has the hidden menu?
    thank you
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Mar 24 2014
    Quote Originally Posted by Mister W View Post
    thank you
    The Avant and sedan have the same trim levels and largely the same options... Sport package I'm not sure about, however. Both the "high" (with nav) and "low" (no nav) versions of the MMI have a hidden menu, however the high version allows you to change more parameters. My advice would be to just buy a VAGCOM cable rather than messing with that, though, because you can do way more with it. Retrofitting factory electrical components is a huge undertaking, and if you haven't bought a car yet I'd suggest just finding one with the general options you're looking for.
    What is your question about the comfort/sport control functions? You mean the Audi Drive Select where you can alter the suspension and engine parameters? I believe that this would be a tough to find option found in true S-line cars with the nav and sport package, but input from others would be appreciated since what you're describing is truly a unicorn.
    Jan 29 2011
    Otterburn Park, QC
    Thank you for fast reply. Yes i was talking about the drive select. I saw a retrofit of it in a french forum ans wonder if it is worth it. that option may be more common over there. I did a lot of retrofit on my B7, but i would like to avoid it this time. But there is such a huge price difference between standard cars and those with options that i wonder if i should not thinking of retrofitting what i want (seats, suspension, bluetooth, etc..)
    As for the MMI hidden menu, you say that i can achieve all the same coding with Vagcom? If so, i have a V-checker that does coding and also i think Carista does it too?.
    thx
    Mar 24 2014
    thx
    If you wanted to retrofit sports suspension, seats, and the steering wheel you'd be looking at $3500, minimum, and it would involve quite a bit if sleuthing in the classifieds to get it at that price. The hidden menu in MMI allows you to do some things, like a "lite" ADS (no suspension, just steering and throttle). VCDS and a VAGCOM cable will allow you to do a ton of stuff, there's a thread in the tech section with specifics.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    man stop rubbin in the FWD
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Oct 23 2014
    Buffalo, NY
    Holy shit...it's a sticky.
    °2011 A4 | 6MT
    Mar 24 2014
    Much needed.
    Thanks, mods!
    Sep 09 2010
    Destin, FL
    Sweeeet, it's now a sticky.
    May 10 2015
    Pittsburgh PA
    Actually a small amount of 2012 B8s were affected by the oil consumption issue, while most were unaffected they weren't completely immune.
    This is going off what I read in the Oil Consumption thread, and having my family's 2012 B8 receive a piston ring replacement due to and oil consumption issue.
    Mar 24 2014
    Quote Originally Posted by 19birel View Post
    Updated, thank you sir. Even having gone through the engine rebuild with my '09 I didn't see many 2012 owners who had that issue. Thanks for the reminder.
    Feb 09 2016
    San Diego Ca.
    This is exactly what I was searching for lol.. Gonna get a a4 in a couple days and wanted to know what I was getting into, from this info I believe the model I will be getting is a 2010 b8.5
