Results 1 to 40 of 56
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Car starts and dies immediately
    This happens today and couple days ago too. The car start and dies immediately like no fuel coming. I started and press the gas paddle dies out. It start up for 2 second. Don't know how many times I cranked last crank I press gas paddle boom it started same thing 2 days ago. Battery still good coil and plug changed 10k. I use vcds scanned 2 days ago no CEL no code come up so I keep my vcds in my car and happens just now start and dies like no fuel so I scan it nothing comes up no cel no code. It start up fine now. I'm not sure I hear my fuel pump prime or not bc the area is noisy but I check fuel pressure on vcds block 106 field#2 reads 66%. Is it my fuel pump on its way out? If it is shouldn't it give me a code or something?
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Could be the engine speed sensor
    Oct 01 2014
    Audi Q5
    chicago,il
    That's the symptom of bad speed sensor?
    Veteran Member Four Rings clumsyme's Avatar
    Jun 12 2013
    Nashville
    Quote Originally Posted by johnruan View Post
    I am dealing with a similar issue right now.
    Does it do it when the car is cold or hot or both?
    How many miles on your car?
    Does the car idle at all like for a few seconds or just start die?
    "He-Man with that long sexy hair, in those provocative tights with his butt looking oh so scrumptious in those booty huggers." -Seerlah
    Jun 17 2013
    jersey city nj
    Crank sensor
    Oct 01 2014
    Audi Q5
    chicago,il
    I think it does it when engine running hot. It happen 2013 once and 2014 once but it happen twice in one week this year. Not sure it's related to engine is hot. It did idle for few seconds and die. I try to press the gas when start it still dies out. Maybe at 7th try I started and press gas paddle it started. Up until now I start up the car fine.
    Oct 01 2014
    Audi Q5
    chicago,il
    So actually I went in to post office for 5 mins come out start up the car and put in gear moved few feet and dies after that I can't start her up until 10mins later finally start.
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Could be a air leak. Did you try unplugging the maf sensor and starting the car?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Sep 26 2013
    Ohio
    I had this exact thing happen a week ago, and once again today. First time around I thought it may have been some bad/dirty fuel; I am still on the same tank of gas so I have not entirely dismissed that theory. The car runs perfect once it gets past that initial "issue"
    I too ran a full VAG-COM scan after and no stored codes.
    Jun 12 2013
    Nashville
    I have a test for you to do.
    First drive the car until the needle is vertical, stop somewhere you will be ok for a few minutes and where you wont get looks for having your hood up. Turn the car off and pop the hood. Try to remove your oil fill cap. Hard to remove?
    now leave the oil cap off and start the car. does the car die on you with the oil cap off?
    Then with the car running put the oil cap back on, does the car then die?
    Let me know
    Senior Member Two Rings vwgtivr6's Avatar
    Dec 21 2010
    2015 S4
    SF
    I had this exact same problem. Car dies abruptly after running normally. Waiting for 15-20 minutes seems to resolve the issue.
    It was the fuel filter.
    Hasn't happened since replacing it.
    Good luck.
    Ken
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by clumsyme View Post
    Let me know
    I tried it runs didn't die. The oil cap is easily to get it off even the car is running. So I think my vacuum is good?
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by vwgtivr6 View Post
    Good luck.
    Ken
    I replace the fuel filter last year I think it's about 15k on it now. Think I should replace it?
    Jun 12 2013
    Nashville
    You got me then. That was my thought I am still trying to fix the same issue as you. But I just finished swapping my pcv and that didn't fix it.
    Oct 01 2014
    Audi Q5
    chicago,il
    Have you try to replace crank sensor? Think that's the culprit
    Sep 26 2013
    Ohio
    FYI, I replaced my fuel filter ~1,000 miles ago (Mann filter). Not saying that couldn't still be the source the problem, but seems unlikely (in my case).
    Sep 26 2013
    Ohio
    Didn't get a chance to try your test, but I have replaced my front and rear pcv, as well as my valve cover within the past 10,000 miles. I have not replaced the crank sensor, so may explore that avenue if the problem reappears with my next tank of gas.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Cam sensor and crank sensors would both their codes typically
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Mine was the crank sensor. I was left cranking my car once for 10 min's before it started..
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by miA4 View Post
    When your crank sensor is bad did it crank and idle few seconds and dies out? Mines idle few seconds and dies out even I give it some gas dies immediately.
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by Sanjman View Post
    I scan on vcds got no codes just don't know what to look. Does these sensor faulty sometimes don't get code?
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Could also be the Throttle Body flap (Intake Manifold Flap Motor) stuck open.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by 80sGuy View Post
    It could be I also hear like metallic sound by throttle area lately. I thought was hpfp making that sound but I go closely to hpfp don't hear it.
    Nov 25 2011
    When mine was acting up I had no codes, but on cold starts the car would die a couple times after starting up. The engine speed sensor is also called the crank position sensor. I replaced mine and the problem went away
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by AJacksA4 View Post
    Where is the crank sensor located? Can I change it on top of motor or I need to get under the motor? Might change that and see how it goes.
    Nov 25 2011
    You can change it from the top, its on the right side of the block under the intake manifold. Its pretty easy but its hard to see what you are doing
    Nov 16 2006
    Skokie, IL
    Don't get confused there are two sensors that have similar jobs:
    Camshaft Position*Sensor*(G40)
    Engine Speed*Sensor(G28) also know as the crankshaft position sensor
    Here's my DIY for the latter, voila:
    http://www.audizine.com/forum/showthread.php?t=679172
    I bought the g40 sensor just haven't tried hard enough to locate it.
    Oct 01 2014
    Audi Q5
    chicago,il
    Thanks for diy pic. Isn't the G40 sensor is in front of cylinder head on intake camshaft side?
    Nov 16 2006
    Skokie, IL
    Send a picture, I have no idea and haven't looked for it yet. Also doesn't seem many have had issues yet with it. Someone actually told me it lies within the cam chain cover... I don't know why it would.
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    It is your LP fuel pump pop the rear bench seat off take the three screws off for the cover tap on the pump cover and that will make it better temporarily.
    Oct 01 2014
    Audi Q5
    chicago,il
    That's the location G40,you need to take the timing cover off.
    Oct 01 2014
    Audi Q5
    chicago,il
    Quote Originally Posted by martin0079 View Post
    I will try that when it happens again but I might change out my crank sensor and see how it goes.
    Jun 12 2013
    Nashville
    Are you 2.0t or 3.2?
    I am having the same issue on the 3.2, I figured out that if I get the car moving it will surge really bad and drop to like 400-500 rpm but if I keep the car moving and keep pushing it to go after about 30 seconds to a minute the car will stop surging and drive normally. Still no codes, does anyone know of a location to manually check fuel pressure? I was thinking the thrust sensor is failing.
    Oct 01 2014
    Audi Q5
    chicago,il
    It's 2.0t
    Jun 12 2013
    Nashville
    It's 2.0t
    Ok so it has to be a system we have in common, I am just trying to eliminate as many things as I can. I got to talking to a tech guy and he thought it might be the low fuel pressure sensor but that would throw a code as well. I am hoping you figure it before I lose it and just buy all the sensors.
    Oct 01 2014
    Audi Q5
    chicago,il
    Yeah I been crank start the car over 10 times drive these couple days no problem and the car drives fine and pulls fine too. I just ordered crank sensor from europa gonna replace that this week.
    Jun 12 2013
    Nashville
    I dont have a problem starting the car when it is cold. When it is warm the car starts and cranks fine.
    Apr 20 2015
    Burlington
    I have a 3.2 and have had warm start trouble. However the problem only occurs when the car has reached operating temperature and I shut it off for and 30-60 minutes. It's like it doesn't quite reach the adequate idle RPM when I start it back up again.
    Jun 12 2013
    Nashville
    I think I got mine fixed. it hasnt done it since last friday and I have been doing the same on/off conditions that it was in before. I replaced my fuel filter and my PCV also gave the tank some seafoam.
    I still dont hear my lpfp prime when I open the door to my car in the morning but I think that is an easy fix.
    Oct 01 2014
    Audi Q5
    chicago,il
    Mines haven't done it since last Friday also but I haven't done anything to it yet..strange. did you replace with oem fuel filter or Mann filter? I changed Mann fuel filter last year it could be faulty might change out to oem.
