Put a new engine in my car - same trans - same ecu - just swapped the engine.
Went to start it and it says - Press clutch pedal to start engine. ITS TIPTRONIC THERE IS NO CLUTCH PEDAL!
Scan with vcds shows -
1 Fault Found:
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 208770 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 14.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.684 V
Readiness: 0110 0101
When I try to access " auto trans " in VCDS it says no response from controller.
So I'm trying to find the Trans Control Module. I havent found a conclusive answer yet on where it is located.
I understand that for CVT transmissions its located in the transmission itself. (i am not CVT)
In a b5/6 its located under the ecu.
Does the B7 ME9 ECU have the TCM integrated?
anyone have any idea on why this would happen?
Thanks.
