Results 1 to 16 of 16
    Apr 11 2012
    Question Anyone using a Battery Maintainer?
    driving the car once a week doesn't seem to be enough to keep the battery at least half charged, so I grabbed a CTEK battery maintainer, I was wondering if anyone around here is using one and if they have tried using the jumper connections under the hood or if they had to connect directly to the battery in the trunk?
    Mar 02 2009
    State of Confusion
    I have a griots garage battery tender and have been connecting to the under hood terminals for about the last 7 years. Works great.
    Nov 10 2014
    Apex, NC
    i have a charger i used for my bike.. it will charge a battery that's down to 0.2 volts ... never had to use it on the car though.. your battery shouldn't be dying once a week though.. are you sure something else isn't drawing current? or is your driving mostly city so its not getting a chance to charge
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Apr 11 2012
    thanks guys! mostly city driving, the battery hasn't died yet, but the battery meter in MMI was down to two bars yesterday and only went up one bar after 40mins of driving, so I figure its a matter of time before it dies.
    Nov 10 2014
    Apex, NC
    how many years on the battery? i would have an auto parts store test the battery and alternator
    Present:
    Apr 11 2012
    4 years, probably getting close to replacement, going to see how it goes with the battery maintainer before taking other steps though.
    Apr 11 2012
    from the manual:
    Quote Originally Posted by Audi
    When jump starting or charging the battery,
    Never connect the negative ground cable to the battery negative post because the battery manager system must be able to detect the battery's state of charge.
    Always connect the negative ground cable to the negative ground post of the battery manager control unit.
    huh? Sounds like I should always use the jump start connections in the engine bay.
    Then in a figure showing the engine compartment, it says:
    Engine Compartment: Connections for jumper cables and charger.
    So I guess so.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Quote Originally Posted by will13k7 View Post
    from the manual:
    huh? Does this mean I should always use the jump start connections in the engine bay?
    Yes, I always connect it under the hood, and jump start as well.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Apr 04 2012
    MSP
    Driving once a week should not drain your battery. My guess is you need a new one. They only last about 4 years (remember who knows how long it sat on the shelf at Audi before going in the car).
    I have used a battery tender on mine one winter I didn't drive the car. Connected directly to battery in trunk.
    Apr 11 2012
    Quote Originally Posted by MrFunk View Post
    its probably almost done-for then. It's not in horrible shape, the maintainer went into the second mode right away, the first mode is for severely drained or faulty batteries.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    New battery yo
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    from the manual:
    I read this to mean that you shouldn't pull the negative lead off of the battery terminal when charging because doing so would disconnect it from the "system". I doubt it matters where you connect a battery charger, so as long as the battery itself remains connected to the car's computer systems.
    Feb 04 2014
    Dino GTS
    Seattle & Scottsdale
    The Desulphatioin mode of the CTEK MUS 4.3 is the best thing to extend your battery life by years
    Just received my B8.5 and the first night in my garage I put it my CTEK 4.3 on it to find it took a full day to bring up to 100%
    Moral: just because the car is brand new does not mean the battery is topped off.
    Apr 11 2012
    The CTEK went through all the cycles, charged it to 60%, didn't indicate that it thinks the battery can't hold a charge, and now is in maintenance charging mode. It was at 60% earlier in the year when I was still daily driving it. Maybe I have about a year left, but I'll probably get it replaced within a year. Anyways, the CTEK did its job and nothing got fried!
    Apr 11 2012
    Wasn't expecting this:
    This was all I did:
    12/6 around 4pm: put the ctek in normal mode, left it plugged in. This got it to 60%.
    12/7 around 6pm: power cycled the ctek and put it in normal mode to get it to start another charge cycle. This got it to 70%.
    12/8 around 6pm: disconnected the ctek. no driving until:
    12/12: charge was still at 70%, it held!, drove the car for about 30 minutes. Didn't check the level again. No driving until:
    12/15: drove to work this morning, about 20 minutes into the drive, check the battery level, it's at 100% now!
    Seems to have come back to life, for now at least.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    This was all I did:
    You need a new battery. It will false charge you at this stage. 4 years not an unheard of timeframe for battery replacement hehe.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
