I have a b5 1.8t with ram air intake, dv, fmic, 3in dd catless down pipe back exhaust and stage 2 dual to single mass flywheel clutch conversion, stage 1 tune. Im having maf problem when the maf is plugged in the car goes into limp mode causing my boost to drop from 15 psi to 5psi. If i clear the cel maf codes that do show it runs ok but has a slight studder at times under full boost mid to high rpm and im pegged out own my afr gauge at 17.0 Unplugged it runs completely fine full boost just the cel for no maf detected. I have did a complete vacuum check and boost leak test. no leaks. Tried two different brand new mafs nothing changes. any suggestions and there might be more that iv tried just cant rember right now
So new update i have checked my maf readings. At idle im at 0.3 (lb/min). With the maf plugged up i am getting more codes the p0411 and p0140 are because i have no cat and no secondary injection both were deleted. They only show when my maf is plugged in tho. Never when it is unplugged
IMG]https://images.tapatalk-cdn.com/15/11/27/f4b6497dd8e5de79c097757ae67f5942.jpg[/IMG]
One other code i get from it i cant remember but it says system two lean bank 2 or 1 im not certain
