Results 1 to 8 of 8
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    Memory Feature for Driver Seats not working
    All of a sudden the memory feature for my seat stopped working.
    Has anyone else experienced this and found a solution? I really would hate to go the dealer for this....it's a huge hassle.
    FYI: I believe the 5F status is there because I upgraded to 3G+ a while ago....
    I ran the car through the VAGCOM and here are the results:
    Saturday,05,December,2015,18:21:08:54135
    Chassis Type: FL (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 36 3C 42 46 47 52 53 55
    56 5F 62 6C 72
    VIN: WAUKGAFL0CAXXXXXXX Mileage: 88770km-55159miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA) Labels: 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
    Component: 3.0T SIMOS84 H08 0003
    Revision: --H08---
    Coding: 0104000A240F0128
    Shop #: WSC 06324 000 00000
    ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
    ROD: EV_ECM30TFS0218K0907551D.rod
    VCID: 326BCE8465FC16AEAD-8066
    No fault code found.
    Readiness: 1110 1101
    Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
    Part No SW: 8K2 927 156 S HW: 0B5 927 156 F
    Component: 0B5 30TFSINAR H10 0003
    Revision: --H10--- Serial number: 0000000684
    Coding: 000001
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMDL501 A02087
    ROD: EV_TCMDL501.rod
    VCID: 46838254F9749A0E11-8012
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 290D1A
    VCID: 020B5E449DDC662E7D-8056
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 0D0100
    VCID: 77FD3F90C61E33865A-8022
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0180
    Revision: C1000000 Serial number: 01171120111987
    Coding: 66102000
    VCID: 000F544C93D0743E6B-8054
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000001136769
    Coding: 26001011003CAF212700080300003D0D0F9CD2480201016100 0000
    Shop #: WSC 06325 123 12345
    VCID: 3C77E0BCBFB8D0DE77-8068
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 211111 H07 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
    Component: HOMELINK H01 0010
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
    Component: PARKHILFE 4K H01 0081
    Revision: 11001001 Serial number: 36861132602082
    Coding: 20010D
    VCID: 4A9BB664E56C7E6EF5-801E
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H44 0610
    Serial number: 003GLD0PCB3I
    Coding: 303837354230303030304A55304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 45818558C472911618-8010
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R11000072EX
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME67252C2FO
    Crash sensor for side airbag; front passenger side:
    Serial number: 6344MSME4A052F6AQ
    Crash sensor for side airbag; rear; driver side:
    Serial number: 6352QSME216608448
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 6362QSME12654D4CP
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME23641664V
    Crash sensor for front airbag; front passenger side:
    Serial number: 63832SME1466394A0
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
    Component: Lenks.Modul H03 0005
    Revision: -------- Serial number: 90372LJ8000A9
    Coding: 000036
    Shop #: WSC 05146 444 109180
    VCID: 4487985CC748A81E0F-8010
    Component: E221 - MFL H03 0004
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
    Component: KOMBIINSTR. H12 0258
    Revision: 00000000 Serial number: EJG534JCC
    Coding: 8B1F09008B00D705010000
    VCID: 41899148D85ABD3624-8014
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AJ HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0120
    Revision: FC201059 Serial number: 5900F11B098048
    Coding: 00C303
    VCID: 09194968A0EA35763C-805C
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8040
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
    Component: 4 Wheel Drive H13 0025
    Serial number: 000911110001028
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 2E53DAF471C4324EC9-807A
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0076
    Revision: AA000000 Serial number: 00000018671768
    Coding: 00581B00000000000000
    VCID: 3B75E3A0BAB6D7E67E-806E
    1 Fault Found:
    03332 - Motor for Height Adjustment
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 88773 km
    Time Indication: 0
    Date: 2015.12.05
    Time: 16:52:48
    Address 3C: Lane Change Labels: None
    Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
    Component: J0769_SWA_MasterH01 0030
    Revision: 00H01000 Serial number: 6PZ 009 014-82
    Coding: 0000001
    VCID: 3C77E0BC7FB8D0DE77-8068
    Subsystem 1 - Part No: 8K0 907 568 H
    Component: J0770_SWA_Slave_H01 0030
    Subsystem 2 - Serial number: 6PZ 009 014-92
    Subsystem 3 - Serial number: 5F17.11.1100H010003C324711’
    Subsystem 4 - Serial number: 324711’
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1501
    Coding: 011C13204E00410001
    VCID: 53A5AB0032263FA686-8006
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0163894284
    Coding: 01060E3A00FA440580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0070
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS050 H08 0043
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
    Component: DSP Prem H10 0190
    Revision: 00010001 Serial number: 34804011648103
    VCID: 7AFB26A4F50C2EEE25-802E
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1501
    VCID: 52ABAE040D3C36AE8D-8006
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 20000000149411
    Shop #: WSC 00000 000 00000
    VCID: 3467C89C97E8189EBF-8060
    Address 55: Headlight Range Labels: 8T0-907-357.clb
    Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
    Component: AFS 1 H01 0040
    Revision: 00H01001 Serial number:
    Coding: 0000019
    VCID: 326BCE84ADFC16AEAD-8066
    Subsystem 1 - Part No: 8K0 941 329
    Component: AFS-Modul links H01 S001
    Subsystem 2 - Part No: 8K0 941 329
    Component: AFS-Modul rechtsH01 S001
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 082 G HW: 4G0 035 082
    Component: Radio U SIRIU H53 0133
    Revision: AB001007 Serial number: 156KG0B7575889
    Coding: 020007010000000001
    VCID: 244738DC2708881E2F-8070
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 746 D HW: 8R1 035 746 A
    Component: H-BNT-NA H42 0738
    Revision: -------- Serial number: 096EX0C7510516
    Coding: 120200000206E1EF57028F5E00000403140000000100000002
    Shop #: WSC 12345 123 12345
    VCID: 387FFCAC8B80FCFE93-806C
    Subsystem 1 - Part No: 8R0 060 884 AD
    Component: NAR 2011 0505
    Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Component: DU7 High H41 0104
    Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0030
    Subsystem 4 - Part No: 8R0 060 961 B
    Component: CD-Database 3371
    3 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 88773 km
    Time Indication: 0
    Date: 2015.12.05
    Time: 16:48:53
    Freeze Frame:
    Text: DUA130,Front,M,0,0,6
    03175 - Invalid Data Set
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 88773 km
    Time Indication: 0
    Date: 2015.12.05
    Time: 16:48:51
    Freeze Frame:
    Voltage: 14.60 V
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 157
    Mileage: 88773 km
    Time Indication: 0
    Date: 2015.12.05
    Time: 16:49:01
    Freeze Frame:
    Bin. Bits: 00000001 00000000
    Bin. Bits: 00000000 00010000
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000001
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1501
    Coding: 010C13204000210001
    VCID: 56A3521421D42A8E61-8002
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H05--- Serial number: 525PA8-J1890UB
    Coding: 1000006
    VCID: 387FFCAC4B80FCFE93-806C
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H06 1501
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Run the seat all the way forward and then back...
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Mar 21 2015
    Up and down too I believe. It needs reset. There was a couple threads on it.
    Oct 04 2012
    Berthoud, CO
    I tried back for forward- nothing yet.
    Should this be done with the car running I would imagine?
    I will try F/B & U/D tomorrow- thanks.
    (yes, I did search the forums and didn't find anything, perhaps I will try some additional key words. Thank you)
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    The memory seat is not set to off position on panel?
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 21 2015
    Quote Originally Posted by jygesq View Post
    I don't think it would throw a code if it was in the off position.
    Veteran Member Three Rings cchoi83's Avatar
    Nov 10 2014
    Long Island, NY
    I had an issue similar to this where my memory settings seemingly disappeared. I didn't run my VAGCOM at the time but I did move my seat to full retract to extend and full rise to fall and voilą, my memory settings worked right away. Cycle the seat positions to their limits one by one a few times and see if that works. I only had to cycle mine once in all four directions but ymmv. Give a shot.
    2018 RS 3 | Nardo Gray | Crescendo Red | Dynamic Plus | Black Optic | RS Design Pkg | Tech Pkg | Dynamic Pkg
    P3 | XPEL Ultimate Full Wrap | Nanolex Si3D HD
    I swear I'm keeping this one stock.
    Eventuri CF Intake | JRZ RS PRO3 | BBS CI-R | Michelin PS4S
    Oct 04 2012
    Berthoud, CO
    Quote Originally Posted by cchoi83 View Post
    YES!!
    I cycled the seat through all positions and the "set" button now works.
    Thanks everyone!!!
