Originally Posted by
renold458
**If this is the wrong section let me know**
So Im coming from another forum as I wasn't getting any help. I have an 2002 A4 1.8T Quattro automatic and I pretty much copied and pasted my thread I had over there.
Key fob literally works whenever it wants to. I replaced the battery and even then it still doesn't wanna work when I need it to. Oddly enough, the trunk button ALWAYS works, which Im glad because sometimes I lock the car and the alarm sets and if I unlock the car with just the physical key the alarm lights flash until I can get the fob to unlock to disable it, so I have to open the trunk first then unlock the door with the physical key to disable the alarm. Not sure what this is, also just noticed my rear driver side door doesn't lock either.
So any ideas?
since the trunk key ALWAYS WORK, this mean your transmitter (keyfob) working fine. the lock and unlock buttons worn out? have you ever thinking of open up the fob and clean the contacts? is it happen with all they key fob or just one particular one?
WB650
Same boat for me, it will work one second then literally the next second it won't, sometimes it won't work unless I'm right next to the car, other times I can be 25ft away and it will work no issue. Replacing the battery usually fixes it for a week or so then it starts up again.
is your key fob has one button that ALWAYS WORK as well? if not, then you might want to check with the antenna receiver on the driver side, top corner back of the car. clean those contacts. there is a link that show how to do it as well.
check out this link it might help
http://www.audizine.com/forum/showth...-Fob-Reception
