Results 1 to 15 of 15
    Dec 01 2015
    Phoenix, Az
    Speed limit exceeded - 78mph -vcds fix
    As the title states, any time I reach 78mph I get a warning on the console Speed Limit Exceeded.
    Symbol is a plain MPH, NO numbers
    I have done plenty of searches regarding this issue and haven't found a solution.
    What this issue is not:
    1) Speed warning set from the dash. This warning has been enabled and canceled. The warning symbol on the cluster is a MPH1
    2)Speed warning set in MMI (3G). This waning has been enabled and removed. It shows up as MPH2 on the cluster.
    The vehicle is CPO, so not sure if this is a setting that can be set through vagcom. Dealer doesn't seem to have an answer. The traffic in Phoenix regularly moves @ 80 so this is quite annoying.
    FIX FOUND!! TOOK GETTING VCDS - INSTRUMENTATION | CODING | BYTE 0 | BIT 6
    2015 A5 2.0t Premium Plus | Daytona Gray Pearl | SLine competition pkg | Black Optic | B&O | MMI 3G
    Sep 30 2009
    b
    If it's not through the MMI I don't know. Every time I've set it, it allows me to remove it without issue.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by Bones510 View Post
    As the title states, any time I reach 78mph I get a warning on the console Speed Limit Exceeded. Symbol is a plain MPH, no numbers
    I have done plenty of searches regarding this issue and haven't found a solution. What this issue is not:
    The vehicle is CPO, so not sure if this is a setting that can be set through vagcom. Deal doesn't seem to have an answer. The traffic in Phoenix regularly moves @ 80 so this is quite annoying.
    thats good so you wont get a speeding ticket. i mean @ 78 you already would
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Quote Originally Posted by JeriQo View Post
    Not here you wouldn't. The speed limit here is 75, and unless you're weaving through traffic, tailgating or going 85+, cops here don't generally waste their time with a 3 mph over ticket on the highway.
    Bones, can you snap a picture of your MMI menu showing your speed sensor settings? I don't have the issue in my car, so I'm curious if your settings look the same as mine.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Dec 01 2015
    Phoenix, Az
    Quote Originally Posted by HazeMyth View Post
    Jul 17 2015
    Colorado
    Hmm, yeah, that's the same as mine. Isn't there also a reset function on the wiper arm? I would maybe try to use that reset function to see if it disables this. I think you can cycle to the MPH1 and MPH2 features using one of those buttons on the wiper arm, and then reset it from there.
    I had the dealership disable the feature before I took delivery, so I have no idea whether or not they had to do anything else besides set it up in MMI.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Sep 16 2006
    SOLD: RS5
    when at speed, hold down the left button on the DIS for 2 seconds. It should put a line through the warning symbol. Use the left button on the DIS, not the wiper stalk. I believe it says "SET"
    __
    SOLD: []RS 5
    Suzuka Grey Pearl
    HRE|Bilstein|AccuAir|Capristo
    Dec 01 2015
    Phoenix, Az
    I haven't had any luck with the reset button on the wiper arm. That is used for resetting the trip computers 1 & 2, and the instant MPG info.
    If i use the SET button on the dash, that will enable a speed warning, but that's note #1 in my original post. I can make and clear that warning, and it shows up as MPH1 on the dash. Same with the MMI, I can make and clear that and it shows up as MPH2.
    This afternoon I will try to get a picture of all 3 Alerts so you can see the difference.
    Junior Member Two Rings
    Jan 26 2011
    2019 Jeep Wrangler
    Interlaken, NJ
    Why not set the speed warning at 150.
    Dec 01 2015
    Phoenix, Az
    Quote Originally Posted by Gate 17 View Post
    Because it's not that speed warning that's going off, that shows up as MPH2
    Dec 01 2015
    Phoenix, Az
    Here's all three images of the cluster - I have also updated the original post with pictures in attempt to weed out anyone who isn't quite paying attention to the actual issue.
    What I get
    Using SET button on cluster
    Setting in MMI
    Dec 01 2015
    Phoenix, Az
    Fixed
    Deactivated Four Rings
    Sep 15 2008
    Is Big
    Fort Worth, Texas
    I set my wife's speed warning at 35 mph...drove her nuts for a week.
    Dec 01 2015
    Phoenix, Az
    Unfortunately, Mines been like this since 10/31/15. Quite a pain in the ass finding it in the vag-com codes. This was not the 2 users normally face, so hopefully in the future if anyone else has this happen there's a solution out there.
    Quote Originally Posted by Rshane View Post
    <-- that is funny
    Veteran Member Three Rings jpenneck's Avatar
    Dec 14 2006
    Denver, CO. USA
    From what I recall, there are 2 separate speed warnings that can be set independently. Are they both disabled ?
    2019 RS5 SB - Navarra Blue, Alu Optic Carbon, Dynamic package, Driver assistance, B&O, 5-arm-peak wheels.
    2019 Q5 - Florett Silver, Prestige
    2013 RS5 - Sepang Blue, Alu-Optic, Black Alcantara, Nav, Sports Exhaust
    2012 S4 - Monsoon Gray, Prestige package, S-Tronic, Sports Diff
    2007 RS4 - Mugello Blue
    2000 S4 - Santorin Blue
