Results 1 to 2 of 2
    Dec 01 2015
    kapaa ,Hi.
    Trouble code P0301 cylinder 1 misfire
    I need help please... I have a 2002 A4 Quattro 1.8T and have trouble code P0301 cylinder 1 misfire. I have replaced the pcv, maf coil packs and spark plugs. This has not changed anything, the car still runs rough. Is there anything else that I need to look at?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Two suggestions. First pull back on the cover of the #1 coil pack harness connector and look for cracked insulation on any of the wires.
    If that checks out try switching the fuel injectors between cylinder #1 and #2 and see if the misfire follows the injector.
