Results 1 to 21 of 21
    Feb 13 2004
    Silicon Valley, CA
    Car won't unlock with remote, key won't turn in driver's door. HELP, Stuck at airport
    Left my car at the airport for 3.5 days, came back just now and not sure if battery is dead or what.
    It won't respond to the remote to unlock the car. No response from any of the buttons (lock, unlock, panic).
    When I put the physical key in the slot on the driver's door, it doesn't even turn. So, taking a taxi home since even if I call AAA, I can't get into the car.
    When I look at the dashboard, half the idiot lights are on (Brake, EPC, ABS, Air Bag, but not all).
    Any suggestion on how to get into the car so I can jump start it?
    Thanks
    Kevin - Moderator, Audizine
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by Stubek View Post
    Thanks
    physical key has to work even if battery dead as it should open lock manually, if not something completly f...., try other way around a bit more force left/right. No quick solution to get in without. I had key in car once, specialist came, somekind of plastic bag between "windowframe" and "carframe", pumped with air(door away from car frame a bit) with long hook, hooked inside door handel and it was open.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Oct 04 2015
    Sweden
    My manual key does not work either, i think its a case of not being used for the last 5 years. I have been suggested to use 5-56 or WD-40 and let it soak for a minute, then try some assertive force.
    Good luck.
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Make sure it's your car. I'm not even joking.
    Pedal Responce first responder.
    Mar 26 2012
    Charlotte, NC
    Quote Originally Posted by 4ringnut View Post
    Ditto! lol
    Feb 13 2004
    Silicon Valley, CA
    Haha, it was my car. Just got it home.
    Went back to the airport this morning, tried the key again, it took a lot of effort, but it turned (put some lube in the lock when I got home and now at every oil change I will exercise the lock).
    Got a jump start from AAA. From the time on the clock, the battery died after about 2 days. That is odd since I left it for 3 weeks at the airport in October.
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    maybe a new/used lock cylinder will fix it
    http://www.ebay.com/itm/AUDI-A4-B8-2...5WUL5D&vxp=mtr
    edit: nevermind. it would most likely require it to work with your key.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Oct 04 2015
    Sweden
    Good stuff, it took some force to get mine to work as well. I can only guess that the lock has not been used since the car was purchased more or less.
    Feb 13 2004
    Silicon Valley, CA
    Quote Originally Posted by Lemuren View Post
    This is about true. 4.5 years or so
    Oct 27 2009
    Miami, FL | Boone, NC
    Car won't unlock with remote, key won't turn in driver's door. HELP, Stuck at...
    Sounds like you're due for a new battery.
    I've let my car sit for 2 months before, and it started up fine afterwards. When it came time to replace my battery, it died overnight (I drove it one day, and it was completely dead the next morning). It gave no warning at all.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Maybe keep an eye on the battery level in the MMI (i suppose you unlocked it too).
    I suppose your door lock is fixed now and i suppose it was because of dead battery right?
    *Just fixed my rear door lock (wouldn't unlock with fob). Cleaned the internal servo's and switches, all works perfect again :) (and saved me 200€ parts/work).
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Feb 23 2015
    B8 Avant, '15 IS250 F-Sport
    Virginia Beach
    So... This is new to me. The b8's have a slot for the key?
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Quote Originally Posted by Cwian View Post
    Yes, physical key can be removed from the FOB and used in the driver's door, maybe the trunk also.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Feb 23 2015
    Virginia Beach
    Quote Originally Posted by booost View Post
    I knew that the key could be removed, I just never noticed the key slot in the door.
    Oct 04 2015
    Sweden
    Have not found a keyhole for the trunk on my Avant, do you have a picture?
    Jul 17 2008
    It appears that the B8 trunk does not have a slot which my B5's had, my bad.
    Feb 13 2004
    Silicon Valley, CA
    I have a key hole on the driver's door, but not on the trunk. I also could not find an emergency release for the trunk from the inside which kind of makes sense as an Avant I should be able to climb to the front
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    The emergency release for Sedan's is under the back seat, not sure if its same for avant
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Oct 04 2015
    Sweden
    I know there is a manual latch inside the avant trunk door, you can access it by removing a small cover.
    Feb 13 2004
    Silicon Valley, CA
    I saw the little plastic cover in the middle with the trunk icon on it, but couldn't figure out how to open the hatch once I got in there.
    Established Member Two Rings RArroyo's Avatar
    Sep 02 2011
    chicago, il
    I know this was posted a while ago but I'm trying to figure out how to access the latch. Having a hard time lifting the seat.
    Xenon retrofit
    *VAG-COM Equipped* and willing to help with VAG-COM mods
