Results 1 to 11 of 11
    Mar 30 2014
    Colorado
    Strange Noise Coming From Engine Bay After Timing Belt Replacement
    So, first of all I realize this is a tech question, but for some reason I was not able to "Post a New Thread" in the subforum. If I'm missing something, let me know, but the link was just not there, but it obviously is when I'm in the normal B5 A4 forum.
    Second of all, Hi. It's been a while since I've posted anything.
    I've searched around and just can't quite find anything that matches the same symptoms I have. I had a few ideas before digging into it, as well as a few new ideas after searching the forums, but nothing guaranteed.
    Sorry if this is a long read, but I want to add as much info as possible.
    Problem:
    Strange noise from the engine bay. Almost sounded at first as if someone next to me had a modified exhaust when I first heard it (windows up). The sound almost sounds to me if something is turning on and turning off (it will make a sound as if it is revving up, and then make another sound as if it is revving down). I really can't describe the sound any better than that. It does continue to make this sound on and off while driving, but only when accelerating or maintaining speed. So far I have not been able to replicate it on decel or at idle. I also can't get a good video recording of the sound as it just isn't loud enough for the mic to tell a difference between the sound and my own engine noise. This sound is also associated with a very slight change in power delivery. If the rev up sound is heard, the car seems to gain a little bit of power, while when the rev down sound is heard, there is a slight loss in power. Almost as if something is catching and releasing.
    Ideas:
    Based on the above, I initially thought it might be the AC compressor trying to turn on and off. This would describe the power gain/loss, but the sound has never been heard before when turning on/off the AC. Just to be sure, I disconnected the wire to the AC compressor to see if it would stop the noise, but it did not.
    Based on searching, I'm also now wondering if it might be a relay (like the SAI) turning on and off? I have not yet checked the relay, but.... As far as other troubleshooting, I've also checked all the fuses and came up with nothing.
    Other info that may be relevant:
    This all began after a timing belt change.
    All belts, tensioners, etc. were changed. Water pump was changed. Temp sensor was changed. The heater hoses on the backside of the engine were also changed because of a leak.
    I also switched to a lightweight crankshaft pulley (Maybe the problem always existed and with the lighter weight, now the noise and power change is just noticeable???)
    About a week ago, the car went into the shop needing a new catalytic converter. This should be irrelevant but???? ***EDIT***The revs seem to stay up higher for longer in between shifts, as well. Kinda chalked this on up to the lightweight pulley, too. But maybe its relevant.
    I'm just stumped. Maybe a fresh set of eyes and brains on this will come up with something I haven't thought of. I'm also still relatively new to working on this car coming from the Nissan/Infiniti side of the world and don't know as much as others on here. Anything helps, guys! Thanks ahead of time.
    Nov 07 2010
    South of Heaven
    So, I read all of that and my best guess may be that you own some kind of 1.8T. The most basic of information is needed to help you.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Mar 30 2014
    Colorado
    Suppose that would have been smart....
    '98 AEB 1.8t
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Have you had someone maintain slight throttle with the car in neutral while you listened under the hood?
    Sent from my XT1095 using Tapatalk
    Nov 03 2011
    All Over!
    Turbo / compressor surge?
    1986 Type 85 Audi 90 quattro
    Mar 30 2014
    Colorado
    Quote Originally Posted by bmos View Post
    Gave this a shot and got nothing as the sound is apparently only there under load.
    Definitely looked into this one... and you have helped immensely! I'm not sure it is surge, exactly, but looking into the boost at least helped me pinpoint EXACTLY when the noise occurs. The "rev up" sound I mentioned is coming as the car switches from vac to boost, while the "rev down" sound is coming as the car switches from boost to vac. It happens in the split second directly in between when the turbo noise quiets down and the diverter valve starts working. During acceleration it is almost unnoticeable because of how fast that change is, but at cruising speed when that changeover can be a little more prolonged, it is more noticeable.
    NOW... I just have to figure out exactly what the noise is. I'm trying to figure out if something is loose and vibrating to cause the sound I'm hearing, or if this noise is somehow simply the result of the lightened crank pulley. Once again, none of this ever happened prior to getting the timing belt replaced.
    Nov 03 2011
    All Over!
    Was the lightened crank pulley fitted the same time as the timing belt?
    Mar 30 2014
    Colorado
    Yes. It was all purchased and installed at the same time
    Nov 03 2011
    All Over!
    Quote Originally Posted by the_PEZi View Post
    I would replace the lightweight pulley with an OEM one. Imbalance issues...
    Mar 30 2014
    Colorado
    Noted...
    After driving around all day today, knowing what I know now, I don't think this is what is causing the noise, though. It seems as if there is something that is maybe vibrating as the engine is switching from vac to boost. Maybe something loose? Time to start digging. Thanks for all the help!
    Jun 30 2008
    Erie, Pennsylvania
    98 AEB (or any AEB) will not have SAI. So you can rule that one out.
    I was momentarily wondering if MAYBE you switched the plugs for the N249 solenoid (diverter valve control) with the N112 solenoid (SAI Kombi Valve control). This would make the combi valve open on every throttle lift and could potentially make a sort of weird noise. But a 98 AEB would have neither of these solenoids, so my genius theory went out the window.
