Results 1 to 40 of 70
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Split Decision Black Friday Turbo Upgrade - Need opinions (F23L, CTS K04, APR K04)
    Because it's black friday and there are sales, I've suddenly decided it's time to upgrade the turbo
    I've done a ton of reading and the following pro's and con's are what I gathered from reading forum posts. If you have any input on yourself, please give me your opinion!
    I don't plan on keeping this car for more than 25-30k more miles. It's currently sitting at 35k
    Frankenturbo f23L
    Pros:
    1.Cheaper (2300$ with tune)
    2. More power? (Not really sure about this but lettuce has the best 1/4 time)
    3. Access to maestro, MBC
    Cons:
    1. Reliability? I've read through every F23L thread I could find and there are so many split reviews.
    2. More tuning needed
    CTS Turbo K04
    Pros:
    1. On sale for $2040 ($2540 with APR K04 tune
    2. ?
    Cons:
    1. ?
    I didn't read much on the CTS kit on reliability.
    APR K04
    Pros:
    1. Probably most reliable
    2. I have APR stage 2 so I get the loyalty program
    Cons:
    1. Still the most expensive at 3000$
    2. Least power?
    I would continue to read up on more, but I want to take advantage on the CTS k04 sale if that is the best option.
    Thanks for reading, I'll gladly take any reviews and/or opinions on what I should do
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    All ko4 kits have the same turbo, made in the same factory. Franken turbo does seem to be hit or miss, if its your daily driver I would stick to a BW ko4. Grab the turbo and then buy the tune separete. The turbo can be found for ~1500 if you look hard enough.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    The CTS K04 needs their HFC or testpipe to bolt onto the turbo (idk why this is the case). So take that into pricing consideration for that kit. Haven't actually seen anyone on this forums run that either though. Iirc, they have it tuned by unitronic, whom are very conservative on the power it makes.
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    I am basically running option 2. I will say that in terms of turbo, like stated they are all made in the same place. The difference is in the compressor cast. CTS uses an interesting weld on fabrication. However it doesn't affect anything and cannot be seen, so its irrelevant mostly. The Frankenturbo is certainly the cheapest. However I have 3 people I know who have ran them, and all three blew the turbo. So take it as you will, its why I didn't go that route. Dollar for Dollar, option 2 wins in power and reliability. Or wait a couple months and Ill sell you a CTS K04 with 1100 miles on it...
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Apr 02 2015
    Rochester NY
    Quote Originally Posted by Chanman94 View Post
    My kit, came with the test pipe, and I believe all the kits do. I run APR software with it 100oct file, no problems. 1100 miles no error logs to report. Did have to upgrade coils and plugs of course and DV+ is super recommended.
    Apr 21 2015
    Very very tempted to get the ctsko4
    May I ask why you'll be taking it off Paradigm?
    Senior Member Two Rings inception's Avatar
    Mar 19 2015
    2018 Q7 3.0T
    phoenix arizona
    Quote Originally Posted by Smellie View Post
    Frankenturbo f23L
    Pros:
    Cons:
    CTS Turbo K04
    Pros:
    2. ?
    Cons:
    1. ?
    APR K04
    Pros:
    Cons:
    2. Least power?
    For the extra money go with APR. worth the money for less headache. reliability and peach of mind... totally worth it for the extra $500.
    i have modified so many cars and i have decided after so many issues. just the cost or replacing the turbo is worth the quality and reputed company..
    2018 S6 APR Stage 1
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Been running the CTS K04 since Jan 2014 w/ the APR K04 tune -- never an issue. My kit came with the test pipe, but I ended up going back and buying the HFC because I just couldn't deal with the smell with the test pipe.
    I've been very happy with the kit and tune -- track days are a blast! Latest dyno day on the 93-octane map:
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Aug 15 2014
    I'd go with APR just for the "one stop shop" ease of hardware and tune. Also not very impressed with the CTS weld on structure. I'm just too meticulous to rock something that looks like an 8yr old boyscout weld job.
    For Sale: Mini Part Out
    Feb 02 2012
    Colorado Springs
    Quote Originally Posted by Shimmy View Post
    Oh come on, the welds don't look that bad.
    Aug 15 2014
    ^ ok you're right... at least those welds look fine. The one posted in a previous thread looked gawd awful.
    Feb 02 2012
    Colorado Springs
    You raised a good point with going with a "one stop shop". By time you calculate in the cost of the APR K04 tune (I thought I read it's quite expensive now), you're probably back at the APR kit price. Likely much easier to deal with warranty work, too, when you only have one company in the mix.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    skip the k04 and wait for apr's efr kit to come out next year.
    Aug 23 2014
    Philadelphia, PA
    You could go with the CTS kit now and than flash with Unitronic via Uniconnect at home. Takes like 20min to flash
    We have been moving a bunch of Uniconnect lately as you will see less and less people going to shops anymore
    More info on Uniconnect if you want to check it out
    https://www.moddedeuros.com/products...tool-uh008-tla
    We also have the CTS k04 kits
    https://www.moddedeuros.com/products...09-14-a5-10-14
    Apr 21 2015
    Quote Originally Posted by auditd0rk View Post
    It's 2540$ vs. 3000$ for APR.
    Still pretty significant. If i was calculating non-sale prices, $2850 vs $3000 for APR, I'd just go with APR.
    Apr 21 2015
    Quote Originally Posted by o1turbo30v View Post
    I only plan on keeping this car until spring/summer of 2017. I'm not sure if I want to dump 5k$ into the kit.
    Aug 15 2014
    in the big picture, whats an extra $500 for a well polished kit and IMO, less hassles with issues if they arise since its all APR product.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    http://www.turbozentrum.de/en/turbos...ifold/a-32000/
    Do it. Leave these K04s in the dust.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Feb 06 2012
    Allentown, PA
    Then why but money into it at all?
    Apr 21 2015
    When the EFR comes out, I'm gonna want people to have long term use feedback. By the time that happens, it'll already be trade in time.
    There's also not too many people running high HP numbers for this car, and I don't want to spend more money after getting the kit on other supporting mods that can't handle the massive amount of power.
    K04 is pretty proven already and at a pretty good price point where I can enjoy the car for another year without too much worry
    Apr 21 2015
    Quote Originally Posted by lettuce View Post
    That just scares me.. What would the tuning solution for that be?
    Maestro + Custom tune?
    Oct 27 2010
    Norwood, MA.
    Why are people waiting for APR to come out with their EFR kit before you consider it an option?
    The turbo is RIGHT THERE for the buying, and you could have a shop tune it much better than APR ever could. Stop hanging off APR's nuts.
    And dont even say "its a plug and play soloution" even APR's setup can not be plug and play when it comes to a turbo of that magnitude. It will still require logging and revisions to get the available performance, thats just how big turbos are.
    2016 S3
    Apr 19 2014
    Long Island
    Quote Originally Posted by b6Hate4 View Post
    You're not considering the pedal responce
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I need to bookmark this touching sermon. In the book of Split Decision, chapter 23, paragraph 2 and verse 2, we see some beautiful life guidance.
    A+ brother Zach
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Oct 27 2010
    Norwood, MA.
    Hahah, thanks Brian.
    People need to realize that with a big turbo, in order to make it "apr plug and play" quality, they sacrifice over 100-150 horsepower. Their gt28rs kit for the older models only made 330hp...on a 400+hp turbo all in the name of being plug and play.
    Now if paying a premium for THAT is not moronic, I dont know what is.
    2016 S3
    Apr 21 2015
    Established Member Two Rings chawaba's Avatar
    Dec 02 2013
    2017 Ford Focus RS
    North Carolina
    Amen!
    2013 audi a4 b8.5 monsoon grey , APR stage 2 K04, APR turbo back exhaust quad tips, AWE fmic, cts turbo catch can, R8 coils, RS6 grille, H&R coil springs, Vossen CV3 19" wheels, adams cross drilled slotted rotors, cf valence
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    You are better off with an EFR6758, the borgwarner turbo is much more advanced than the Garrett GT series. (not the GTX)
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    I wonder why more people didn't look at dame drizzo's EFR as a success? He had his a couple years ago. From the looks of it, he didn't seem to have any issues.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Oct 27 2010
    Norwood, MA.
    Because people swing off APR's nuts and as far as they are concerned, if APR didnt come out with it, it doesn't exist.
    AKA people with more money than sense. The same type of person who comes to a new platform and blindly follows the big conglomerate company with big money advertising, who even after proven decietful (RSC anyone?), they CONTINUE to blindly trust that this company will only release the best version of a product possible.
    Its hard to understand, I know. But thats "new model" Audi demographic for ya. GO APR!
    2016 S3
    Jun 19 2015
    Boston
    lol, same people who give me shit for making posts like this:
    http://www.audizine.com/forum/showth...1#post11218347
    Or maybe I'm just an asshole. Could be a little bit of both.
    "Look just because you drive a fast car doesn't mean you have to be mechanically inclined about it."
    Oct 27 2010
    Norwood, MA.
    Lol, exactly. Generally when you own a car like that, you find yourself taking on repairs that are incrementally more difficult until you find yourself standing in a bay with no engine in it and , while the front end and whole rad support is in your living room. It's just the way it goes.
    But nowadays we here in the b8 section wait until APR comes out with a solution to simply bolt in and go and never have to pop the hood again. God forbid. That is until the b9 comes out, of course.
    2016 S3
    Apr 02 2015
    Rochester NY
    Bigger Turbo.
    You see none of the welds, and the welds actually aren't the eyesore, its the entire output. However its out of site and for the money saved worth it.
    Because he's comparing 2k turbos, not 4k turbos.
    Along comes zach again. Why do we always have this conversation. Lets be brutally honest with the whole community. We do not want them going BT on their own with a custom tune. Have you read half of the b8 threads daily? Do you know how many face palm moments these people will provide? "Rough idle on startup on cold weather. Help?!?!" "Weird laggy feeling when I hit the throttle. Its like theres nothing there, then it all a sudden takes off" "Help, can't keep plugs in my car. I have to replace plugs every oil change" Should I keep going? The APR kit (tbd) will be the absolute best possible option for 98.98% of this forum. Can the EFR make more power on a custom tune? Yeah, Im sure I could get close to APR's Expected EFR output on the K04. Doubt it would last long, but still possible. Assuming APR is as capable as they say, Im 100% here for the convergence of drivability vs raceability that their kit should provide. Ive had way too many stand alone cars to do it again at my age lol.
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by ParadigmTony View Post
    My post was not to exclusively compare what I believe APR's kit will produce HP wise, vs. what the turbo is capable of. I'm not arguing with any part of your post at all. My above post, and all recent posts regarding this issue (and the reason you had to say "here comes Zach again") is I'm just saying..hey....maybe SOMEONE could have an original thought. Something different. This platform is so cookie cutter. There are 50+ turbos sitting on shelves just waiting to be bolted on to this engine, but, unless it has APR's magical stamp on it..who cares?
    I could type out a lot more, but at the end of the post I would have repeated the same shit over and over.
    2016 S3
    Apr 02 2015
    Rochester NY
    Ok fair enough. Slow clap. I 100% agree with you on originality. I also agree that this platform doesn't exactly draw motor heads, but seemingly fringe enthusiasts. I wish more than anything someone takes this fucking efr standalones it, and makes 500whp so I can point and say thats basically my car... I just don't have the time, effort, or interest in keeping the car long enough to justify the creativity. But to support your point, it doesn't even require that much creativity. The hardware is right there, learn to tune your car and log it, and get a custom tune done. Just hopefully you enjoy maintenance..
    Oct 27 2010
    Norwood, MA.
    See that's one thing I find crazy, that APR will de-tune the EFR so very drastically just to avoid the extra maintenance of actually having an EFR (while making it basically a ko4+) that it is worth the premium cost to people....thats a paradox if I ever heard one.
    2016 S3
    Sep 09 2010
    Destin, FL
    Sub'd
    Apr 21 2015
    Most likely purchasing a CTS Turbo K04 tomorrow since APR has 10% off their software until the end of the year.
    Hopefully the place i got Stage 2 done will make the Stage 2 - K04 software cheaper, since I paid 150$ to go from Stage 1-2.
    Veteran Member Three Rings Finder's Avatar
    Apr 02 2012
    Oakville, ON, Canada
    https://www.unitronic-chipped.com/ec...hwtsiavsk04kit
    Is anyone using the K04 kit from Unitronic? Or at least their K04 tune?
    I'm planning on getting a K04 for my B8 next year and I'm tempted to get at least the software from them (their complete kit is not bad though) as I am very happy with the K04 tune I have on my A3.
    But I can't seem to find any reviews or anyone who has their K04 tune on B8s.
    Audi A3 2.0T 6MT - UNITRONIC K04
    Unitronic|IE|Eurojet|Spulen|BSH|GFB|ECS|Fluidampr| Southbend|Wavetrac|SQS|Bilstein|H&R|Tyrolsport|Sup erPro|Powerflex|034|PTP|USP|Neuspeed|Votex|AWE|Mil ltek
    OEM mods: Adaptive Bi-Xenons w/AFS, FB MFSW, S3 cluster, MY2012 RNS-E, dimming mirrors in&out +more
    Audi A4 B8 Avant w/ ADS&Tech Pkg - UNITRONIC Stage 2
    Eurocode|CR-15|ECS|Milltek|Votex|AFE
    OEM mods: B8.5 Euro LED taillights, B8.5 RS4 steering wheel+more
    May 07 2014
    Quote Originally Posted by Finder View Post
    I have yet to meet or hear of anyone running the Unitronic system. They're right around the corner from me, but I passed it up. I think quality wise, it's probably the best kit currently available on the market. However, you'll pay for that, and especially when you consider that their tune puts out significantly less power than other K04 tuning options available.
    Still,, I hear you. They were my first choice too in trying to keep it local, but financially, it just didn't add up.
    2010 A4 2.0t quattro 6mt
