Results 1 to 17 of 17
    Senior Member Three Rings GTA's Avatar
    Feb 08 2013
    2003 Audi A4 1.8TQ, 5-Spd
    Toronto, Ontario
    Want to know tubing size for bleeding brakes
    I've sifted through a lot of info but can't seems to find out the exact size of clear tubing needed to bleed my brakes. Basically looking for the Inside Diameter (ID) of the bleed nipple so I can get the proper clear tubing to manually bleed my brakes this weekend with my buddy. I know I can squirt it on the ground but I want to be enviro friendly as well as see how tainted the old stuff is.
    I really don't want to lay out for a power bleeder (yet) so I'm doing it the old fashioned way with two people starting with the caliper farthest away from the Master Cylinder: Right rear, Left rear, Right front, Left front and then the clutch slave cylinder.
    With this said, would 1L be enough to do everything including the clutch slave cylinder? Or do I need to get 2L from Audi?
    Thanks in advance everyone.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    1/4" ID tubing will work fine. And you should get 3 quarts of fluid to be safe. 2 might be enough but I would definitely have at least 3 on hand
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    I had to replace my brake booster a while back. So I had to bleed my system too. I did it manually without any problems. I think 1/4" ID is good. Whatever will fit tight over the bleeder valve. You don't want to bleed it to the ground you want to put the other end of the bleeder hose into a container and submerge it with brake fluid. This way you can sees the bubbles and it won't get drawn back into the system.
    Feb 08 2013
    Toronto, Ontario
    From what I mostly read, usually 1L is good enough for the entire system. Or am I missing something? That stuff's expensive from Audi: CAD$36 per Liter - Ouch!
    So 1/4" ID it is. Am I correct in bleeding it out the 'normal' way? RR, LR, RF, LF and then the clutch slave? In other words, Bentley's suggests bleeding it out the nipples nearer the master first, which is the opposite of what I intend to do. Is it because Bentley's procedure uses a power bleeder? I'd like to know your procedure when you bled it out manually, Let It Snow?
    Feb 27 2011
    Winnipeg
    when I manually bleed I start farthest away, I also don't use the $36L Audi fluid, I just get a reputable brand of DOT4 from the local parts place for much less, last time I think it was NAPA DOT4.
    Feb 08 2013
    Toronto, Ontario
    That is good to know sean. It sucks to be held captive to Cad prices, I'm sure you know
    Holy crap! The Pentosin Super DOT4 is $60/L LOL! Almost twice the price of OEM brake fluid at $36/L. It's my stock daily driver and I don't track it. I'm just looking to use quality stuff equivalent to OE.
    I've found a local supplier that sells Fuchs MAINTAIN DOT4 for $15/L which is a helluva lot more reasonable than the others. I've use Fuchs 'Oil Finder' on their website http://fuchs-eu.lubricantadvisor.com....aspx?Lang=eng and it specifies that I can use either their MAINTAIN DOT4 or MAINTAIN DOT5.1 products on my '03 A4 1.8T Q's Hydraulic Brake/Clutch System. I don't think this is a bad choice.
    Jun 27 2011
    Pentosin is $12/L at my local parts store. What ripoff store are you getting your pricing from?!
    Also 2L is plenty. You could maybe squeak by with 1L but it's better to have more than less.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 08 2013
    Toronto, Ontario
    I got a quote of CAD$59.95 for Pentosin Super DOT4 from Napa Canada over the phone and he insists it was for only 1L but I suspect it was for a jug for that price. That guy sounded like a douche.
    Anyway, the Fuchs was back ordered and I've found a local garage selling ATE SL6 brake fluid for CAD$20/L tax in so I'm going with that instead. I ordered 2L and he has to order it in so I'll pick it up tomorrow along with a 5L jug of Motul Excess 8100 5W40 oil that he stocks for CAD$45 tax in.
    Thanx for chiming in Charles.
    Jun 27 2011
    No worries. Any decent DOT 4 fluid will work just fine for street use.
    -CP
    2017 Q7 3.0t
    Feb 08 2013
    Toronto, Ontario
    I've heard that from other experienced members on this board. What concerns me are others suggesting the magnesium part of our braking systems can be damaged by using the wrong fluid. If what you say is true, then I can use Prestone synthetic DOT 4 fluid? It's only like CAD$11/L from Parts Source locally. That's a really reasonable price and it's a lot closer to me.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by GTA View Post
    The prestone is what I've got in my garage right now and what I flushed my rear brakes with when I did B7 A4 rear brake swap last winter, did not have any brake fluid related issues this summer. If you're on top of your bi annual brake flushes I wouldnt worry too much as long as its not some no name fluid you got from the discount bin.
    Feb 08 2013
    Toronto, Ontario
    I get what you're saying Sean, and I'm ashamed to say that I haven't been on top of my brake flushes. This will be the first time doing them since I acquired the car 3+ years ago. Who knows how long since it was last done as I can't find anything in the stack of receipts the prior owner handed to me.
    I'll go with the ATE SL.6 since I promised the guy I'd pick it up from him (for good relations).
    It seems to me that brake system flushing is one of the most neglected part of any service. I've been around the block and every time I mention it, I get a blank look from even mechanics. Obviously they're aware of this type of service (including cooling system flushes) but they never seem inclined to do it as regularly scheduled service.
    I should mention this to my mechanic buddy and see what he thinks about regular brake flushes. Maybe he will get a proper power bleeder that I can take advantage of .
    Anyway, I hope my bleeding nipples aren't seized when I attack them this weekend.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I get what you're saying Sean, and I'm ashamed to say that I haven't been on top of my brake flushes. This will be the first time doing them since I acquired the car 3+ years ago. Who knows how long since it was last done as I can't find anything on the stack of receipts the prior owner hand to me.
    Brake fluid should be flushed annually. It's even more critical for humidifier minutes.
    Aug 27 2013
    Philly
    Quote Originally Posted by texasboy21 View Post
    Its hard enough to get people to get their cars inspected yearly, let alone to flush their brakes. Before getting my Audi, I never flushed brakes. No one ever explained to me how important it was to do it. Now all the vehicles I work on/service, get a brake flush regularly. Hell, my a4 should get one soon as its been about 2 years since my clutch job when I bled everything last.
    Time to add it to the list.
    Sent from my Nexus 6 using Tapatalk
    Jun 21 2005
    Milton, Ontario
    Is there any sure way of telling if your bleeder screws are seized before actually trying to loosen them during the bleeding process?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Jun 27 2011
    You can turn them maybe 1/4 - 1/2 turn before they do anything. So give them a quick crack and see if they move.
    -CP
    2017 Q7 3.0t
    Jun 21 2005
    Milton, Ontario
    Thanks Charles
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
