Results 1 to 12 of 12
    Mar 18 2015
    United States
    belly pan is dragging..
    The other day i was driving in the furthest left lane to the concrete center barrier and i heard a loud dragging noise coming from my car, i pulled over and noticed the left side of my belly pan was dragging on the street. Ive done some research on aftermarket hardware i can purchase to correct the issue but i still dont know exactly what/how many i need to fix it. Also where can i purchase? autozone? lowes? home depot?.. thanks!
    Dec 23 2011
    The plastic belly pan is flimsy. Get a Thor or panzer plate instead
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    Unfortunately, the correct belly pan hardware ain't cheap...
    https://www.ecstuning.com/Audi-B7_A4...Pan/ES2587685/
    ll Audi Sport "Vorsprung Durch Technik"
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    By far cheaper on eBay, even if they say its for a BMW.
    http://www.ebay.com/itm/OEM-BMW-UNDE...BVgdld&vxp=mtr
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 18 2015
    United States
    alright, thanks guys, ill look into the replacement hardware.
    Established Member Two Rings SamsonKnight's Avatar
    Sep 28 2013
    NC
    Drive without it for a while till you can come up with the money to get the correct hardware for the vehicle. You'll smile and wont regret getting it the next time you take off and put back on. Sure it's more expensive at the dealership.
    2008 Ibis White A4 FrankenF23, Custom Tuned by Brandon @Breakout Motorsports, Wosner pistons, IE Forged Rods, 1.8t oil pump, 034 hfc, MagnaFlow Mufflers, Cupra R Lip, S4 Door Blades.
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    Try autohausaz for the hardware
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Before buying what shape is the belly pan in? If the holes are intact just zip tie it back up. Or drill new holes and ziptie.
    I drive without my belly pan but I think there is good protection added by keeping it on since there's a lot of wiring close to the floor
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    +1 for drill holes and ziptie. If its broken apart then buy new or an upgraded skid plate. I drive without mine.. makes oil changes easier.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Another vote for zip ties or no belly pan if you're in a warm climate. If you're somewhere cold, upgrade that shit with a metal pan.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Oct 24 2015
    Perth, WA
    Yeah i don't have mine installed either. makes almost all things easier to work on.
    My respray thread
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    zip ties work wonders....as we all know haha. If its dragging, there are only a Few mounting areas you need to work with. I bet if u get under the car, it may be better than you think.
    Junk yards are a gold mine but sucks digging/crawling around in the cold, depending where you love.
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
