Results 1 to 32 of 32
    Established Member Two Rings A4MZ's Avatar
    Dec 21 2007
    West Chester, PA
    Thermostat Fail Signs...
    Hey Everyone, I searched for a while and didn't see any pre-signs or symptoms of a failing thermostat so I wanted to see if anyone recalls what happened before it actually failed.
    I have a 2013 S4 with 22,300 miles on it. It has the AWE Cool Front System and reservoir so I'm not sure if that would affect the systems.
    A few weeks ago after starting the car, the "Low Coolant Warning" message popped up on the display. I added some coolant to the OEM and Aftermarket system and the light went off, no issues. This morning the warning message came up again. I popped the hood and checked the levels and both were fine. I drove the car for a bit and logged on VAGCOM to see if any issues would arise. By the time I got to work, the light turned itself off, the engine temp level did not move at all, and when I looked at the logging, everything looked okay.
    Would you think this is a sensor starting to fail or a precursor to the thermostat crapping out?
    Thanks in advance.
    2023 S5 Chronos Grey
    Veteran Member Three Rings CaptSlow's Avatar
    Apr 18 2014
    NoVA
    I have yet to experience it, but if I recall from reading a thread here, Thermostat failing would increase your engine temp level and the car would tell you not to drive it
    2014 Glacier White | Premium Plus | S-Tronic| AWE Touring with 102/mm Silver Tips
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by CaptSlow View Post
    A dealer in LA quoted my buddy $1200 to replace the thermostat for his 2013 S5 and claimed it would not be covered by warranty....which means $60 in parts, $1200 in labor, sounds insane to me..
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I just had mine done. They day or two before I noticed my cooling fan still being on full blast after the car turned off. When running it sounded like it was going at 150%. You can just hear it being louder. 2nd day my temp gauge starting rising to high towed it to dealer. I had them do it for 1,065$. Went bad at 85,000 miles.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Apr 18 2014
    NoVA
    Quote Originally Posted by xuandatou View Post
    Not covered under warranty? For a 2013? lolwut
    Active Member Two Rings TAGHRP2's Avatar
    Oct 07 2015
    Des plaines IL
    Sounds very fishy, it should be covered by warranty "if the car still has warranty". I would rather go to a different dealer or call AOA and let them know the issue.
    Yes!, sounded like thermostat issue only.
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    That's what I was thinking. Why would that not be under warranty? I have a CPO 2012 and mine was replaced under warranty at around 40k miles. Overheated, loud, and warning came on that said to check coolant levels and not drive.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Dec 21 2007
    West Chester, PA
    Quote Originally Posted by schirm View Post
    Okay, sounds like my issue may be un-related to the T-stat then. I'm wondering if a sensor is going bad, if that's the case...any one have experience with that?
    Apr 18 2014
    NoVA
    Maybe it's water pump?
    Or I just don't know what I'm talking about.
    Established Member Two Rings kr3w45's Avatar
    Mar 19 2014
    02 a4, 06 a4, 09 a4, yamaha r6
    Boston, MA
    Quote Originally Posted by A4MZ View Post
    If you are loosing coolant you have a leak somewhere. If the low coolant light came on but the coolant level was full then it may have been a sensor.
    Automate your Dealership: www.DealerScience.com
    Automotive Technician @ Amherst Autoworks
    B7 A4 - Frankenturbo F23L
    B8 S4 Stage 2
    Dec 21 2007
    West Chester, PA
    Quote Originally Posted by kr3w45 View Post
    I havent lost any coolant since I topped it off. I'll keep an eye on it and see if the light comes on again.
    Thanks all!
    Aug 27 2014
    Denver, Co
    This...
    Mine went around 45k miles. My fan would blow well after the car shut off. Also you will get the Tep warning sign in your info screen area. And your thermostat will be off the chart. I drove mine for about a week before i got the parts to fix it as the dealer also quoted me $1,200... It is ridiculous because it took me 4 hours and i did not know what i was doing. An Audi Tech should be able to complete this job in 2 hours. even at $120 and hour and a $60 part i am not clear where they get $1,200.
    2011 Meteor Gray S4 6-spd, B&O, Sport Diff, CTS Intake, Red Leather Interior, Hotchkis F&R Sways. EPS Stage 2, Bilstein PSS-10
    Apr 05 2014
    Is thermostat still a ticking time bomb for B8.5 or just the B8s?
    2014 S4 Ibis White 6MT. Stealth Daily Commuter. Best Option = B&O
    Mar 26 2010
    US
    At 34k miles, the only warning I got was temperature warning sign in your info screen area the temerature guage was at high. It said shut down now, but was in dense traffic no shoulder. Had to stop/start to get top a safe area, for flatbed.
    BMW M3 Competition X-drive
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    just replaced mine about 3 weeks ago. 2011, 53k
    got raped by the dealership to the tune of 1k, put in a claim thru AOA which was promptly denied because they are c u n t s and reeling from the dieselgate scandal, only 3k and about 5months out of warranty on a known defective part...
    symptoms are easy to spot fans will run on full blast all the time when car is on and after you turn it off.
    if you are driving and worried about engine temps, you can turn the heat on highest temp and turn the fan to full blast and this should help you limp it home or to the shop etc
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Senior Member Three Rings ob_1jr's Avatar
    May 05 2012
    Clinton, UT
    Mine didn't fail fully, but got covered in the fuel rail recall. the dealer showed me my thermostat and said it was cracked and almost broke all the way. I was pretty close to having mine fail.
    2017 SQ5 Premium + | weathertech floor mats | 20% tint
    Sold:2012 S4 Premium + | 6MT | comfort key | supercharged badges | weathertech floor mats | 15% tint | Gunmetal VMR 710 18x9.5 w/ bridgestone potenza RE970AS from PYSpeed| Roc-Euro intake | Alu Kreuz | Eurocode Meisterwerk ASTS | 034Motorsport Transmission Mount Insert | Spulen Rear Differential Mount | ECS GEOMET Slotted and Drilled rotors | Hawk Ceramic pads
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Mine failed 2 days ago 100K mark (MY2011), fans stayed on but hadn't overheated yet as I drove with the heater full blast. $700 CDN including the thermostat for the fix at my local German shop.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Mar 19 2014
    Boston, MA
    I replaced mine 2 weeks ago for 60 dollars haha.
    https://www.ecstuning.com/Audi-B8_S4...All/ES2640066/
    B8 S4 Stage 2
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The only early warning you might get is the radiator fans running much more than before (as stated by other people in this thread),
    OR, if you have a P3 gauge, you will see some above-normal coolant temperatures spikes shortly before the thermostat fails completely. The coolant temp gauge in the instrument cluster will not give you an early warning, as it is purposely inaccurate. It will only move above the normal middle mark when the thermostat has completely failed, and the engine is truly overheating.
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    Fan stays on all the time and then pop goes the thermo.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by S4snowfan View Post
    This...
    Great question!
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I plan on doing my tstat when I clean the intake valves out, its been on my todo list for a while.
    Sep 02 2015
    Edmonton
    Try to bleed the coolant first, easiest step.
    I replace the tstat myself last week. There was no sign indicates it's about to fail. When it fails you will hear loud fan noise, coolant temperature will go up, and coolant in the reservoir will remain cool.
    Oct 17 2012
    NoCal
    It seems like this deal is a little bit better:
    http://genuineaudiparts.com/parts/in...&siteid=214407
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Dec 21 2007
    West Chester, PA
    Quote Originally Posted by ilovefood View Post
    Any tips on how to bleed the coolant?
    Sep 02 2015
    Edmonton
    1, Run car to operating temperature
    2, remove top black cover on supercharger, you will see two black plastic bolts on each side underneath it.
    3, Loose (DON'T REMOVE!) one of the bolts, then throttle the car to 2000rpm until coolant comes out.
    4, Tighten the bolt and do the same to the other bolt.
    5, Remove rain tray cover, you will see two pipes will the positive terminal box (iirc) in the middle. Pull the passenger side pipe until coolant flows out of the little hole on the pipe, this also needs 2000rpm.
    That way you can force the air out of the coolant system.
    Sep 24 2014
    Central NJ
    Use a vacuum coolant refill tool, about $60 on Ebay. That is how the factory fills the system.
    Sep 02 2015
    Edmonton
    Quote Originally Posted by S4'ed View Post
    This too, I was just too cheap.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Bump for a great thread. Noticed my fans on constantly today. Checked coolant temp on P3 gauge and it was over 220F in normal driving. Ordered new OEM thermostat from Amazon tonight and it will be here tomorrow. Guess I'm driving the Turbo to work ;)
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Feb 20 2016
    Phoenix, AZ
    Just had my thermostat and water pump replaced under CPO warranty today.
    Took the car in last week and complained of low coolant level - I had figured I shouldn't really be needing to add coolant since this is a closed system. They pressure checked the system and found a leak where the pump was so they replaced that. They checked the car again and found the thermostat was not opening correctly and so that got replaced too. Car has 41k miles on it.
    So if anyone is still under warranty, CPO or original, and has low coolant levels, just have it checked by the dealer - might have issues with the pump and thermostat like I did!
    Senior Member Two Rings rockstar143's Avatar
    Oct 01 2013
    United States
    Did some part number checks and it looks like the B8 and B8.5 share the same Thermostat Part number so if it prone to failure that affects both.
    Water pumps are different so that's probably the polymer vs aluminum pump difference. I would say using logic that if you have a B8 you should
    change both if you have the SC off and if you're B8.5 you can get away with just the thermostat.
    J.
    Veteran Member Three Rings SSSSS5's Avatar
    Apr 16 2018
    '85 300TD, '85 500SEL, NA MIATA, Merkur XR4Ti, '99 Cactus Avant, '10 S6, GX470, '16 Outback
    Bangor. ME
    Quote Originally Posted by rockstar143 View Post
    J.
    I have B8.5 with polymer water pump fins, just put a metal one in because why not. Also note that Audi has multiple part numbers for these thermostats. I believe they have 4 revisions so just make sure you get the most recent one. ShopDAP or ECS will always sell you the most recent one.
    -Casey @CaseyCactusV10 | 1999 Cactus Green B5.5 A4 Slicktop + V10 + 0A3
