Results 1 to 17 of 17
    Senior Member Three Rings dr_always's Avatar
    Jul 20 2011
    About to try Lucas stop-leak PS fluid.. stop me before it's too late?
    My 96 A4 2.8 just started leaking power steering fluid a few weeks ago and it seems to be slow but constant. A buddy of mine who knows cars (though not necessarily german) suggested this stuff:
    http://lucasoil.com/products/problem...ring-stop-leak
    I know that Lucas makes a strong product though I've also read all the warnings on here about using nothing but OEM fluid (or maybe a Pentosin blend). I ran out of extra fluid yesterday and need a new bottle or two until I fix this leak, this stop-leak is maybe $6 and can be had now. OEM fluid is $40 shipped and will take several days.
    Would you put this Lucas stop-leak in your B5 A4?
    Nov 16 2015
    Northern Mass
    Thumbs down
    Don't do it!!! I tried the same thing on my B7 A4 and a week later I had to replace the rack. I suggest getting it fixed ASAP or you will be sorry.. Not sure what a b5 rack goes for but I am sure it aint cheep! You need also to be considered with you power steering pump, if the car is groaning when you turn you could really be in bad shape.
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    Your car is not a Ford F-150. In fact, I wouldn't even put stop leak in an f-150.
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Aug 30 2014
    United States
    Use the Pentosin CHF 11s version which can be had for much cheaper. OEM approved. As far as I've read. The Pentosin stuff is identical to the OEM.
    Dec 10 2013
    Borden, Ontario, Canada
    FOR THE LOVE OF GOD DON'T PUT THAT SHIT IN THERE.
    FIX YOUR LEAK
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jul 20 2011
    Lol thanks guys.. I don't think I could've put that stuff in there no matter what you had said but the reassurance makes me feel better.
    I'm sure I'll go ahead and get the OEM fluid but just in case, anyone know where to find a bottle of Pentosin chs-11s? Preferably local? Has anyone tracked down a cheaper source for the OEM?
    The car only groans just a little when I accidentally let the PS reservoir go below the min line in which case I refill it asap and it purrs like a kitten again.
    Aug 30 2014
    United States
    Had a quick look and Pentosin CHF 11S appears to be at most auto store chains (Autozone, Oreilly's, Pep boys, Napa etc)
    Jul 20 2011
    Oh wow, you're right. I had misspelled it.
    Has anyone mixed Pentosin CHF-11s into a system already running OEM? Any adverse effects?
    I need fluid before a shipment of OEM would be able to reach my doorstep so I'll likely be going with the Pentosin.
    Aug 30 2014
    United States
    ^ I did. No issues. As far as I've researched, the Pentosin CHF 11S IS the OEM fluid. The fluids are identical just different packaging. Pentosin makes the fluid and relabeled/packaged with a markup for Audi dealers.
    Same thing goes for brake fluid. The Pentosin DOT 4 IS the OEM fluid. OEM brake fluid for our car is just repackaged Pentosin DOT 4 and markup. Pentosin is a german company that makes hydraulic fluids (braking, steering, suspension etc.)
    The only thing I have not figured out is if the VW G12 (or G13) is also made by Pentosin. I know Pentosin makes a G12/g13 that is compatible, not sure if it's identical just repackaged for dealers.
    Jul 20 2011
    Hopefully my local orielly's or advance auto can get it delivered in from a nearby town tomorrow. Thanks a bunch, exactly what I needed to know!
    Jan 15 2012
    NEPA
    Oops, I've used Lucas multiple times now...
    My rack was already shot, and that stuff seems to work okay in the summer. Now that it's winter I'll drain what I can get out and replace with the OEM fluid because of how thick it is. Needed a new rack for like two years now, just haven't gotten around to replacing it. I'll probably end up replacing the pump again also.
    1996 Audi A4 aka Moneypit
    Jul 20 2011
    Wow, didn't realize you could get by for two years on a busted rack.. maybe my allergic reaction to working in the cold *cough cough* won't be anything to worry about this winter then. ;)
    Oct 21 2005
    y
    Check what type of fluid you have first (regular or syntethic) chf 7.1 and 11s shouldn't be mixed. Unless maybe if you do a complete flush.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Quote Originally Posted by ricekikr View Post
    CHF 7.1, 11S and 202 can all be mixed and interchanged as they are all mineral based hydraulic fluid. They cannot be mixed with CHF 4.1 or ATF.
    Just to clarify.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Aug 30 2014
    United States
    Quote Originally Posted by Wrath And Tears View Post
    Just to clarify.
    No.
    CHF 7.1 is mineral oil based. CHF 11S and CHF 202 are synthetics. 11S and 202 are not backwards compatible with 7.1 according to Pentosin so do NOT mix them in your system.
    On an older car, you really should not mix CHF 11S with 202S. You'll just risk introducing leaks.
    Orange County, CA
    Quote Originally Posted by Bordom View Post
    FIX YOUR LEAK
    Quote Originally Posted by Articus View Post
    G13 superseded G12. I can check my G13 Jug to see who makes the G13 but it's not difficult to find G13 without going to the dealership. Amazon has everything. Not expensive either way.
    Amazon. Cheaper than any of those options. I buy everything on Amazon prime.
    B5 Parts For Sale
    Feb 27 2011
    Winnipeg
    check this out post #32 lots of the B6 guys use the stuff, its good for swelling up rack seals and keeping you from having to say replace the rack in December when its -40 and allows you to drag it out until the spring when warm. The lucas PS stop leak is the only stop leak I'd ever attempt in my own car and actually have a bottle just in case.
