Results 1 to 2 of 2
    Junior Member Two Rings
    Jul 26 2013
    DFW
    Scanned my 2002 Allroad with VCDS - Electrical Issues
    Scanned my Allroad last night and got the following codes. I'm not savvy when it comes to electronics so any advice is appreciated.
    Also, a couple symptoms I've had issues are: not recognizing open doors, no headlight left on chime, and the doors don't always lock electronically.
    See below for full scan.
    Thursday,19,November,2015,18:25:44:00997
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    www.Ross-Tech.com
    VIN: WA1YD64B92N090075 License Plate:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    VIN: WA1YD64B92N090075 f
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 4Z7 907 551 M
    Component: 2.7l V6/5VT G 0001
    Coding: 06752
    Shop #: WSC 02325
    VCID: 4D9A957387D2FB56E6-513C
    WA1YD64B92N090075 AUZ7Z0A1982822
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4Z7 927 156 F
    Component: AG5 01V 2.7l5VT USA 1818
    Coding: 01002
    Shop #: WSC 02325
    VCID: 4992A16373BAE776CA-513C
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 4Z7 907 389 A
    Component: ABS/ESP allrad D55
    Coding: 06397
    Shop #: WSC 00000
    VCID: 4A909E6F76BCEC6EC3-513C
    Address 06: Seat Mem. Pass Labels: None
    Part No: 4B0 959 760 C
    Component: Sitzmemory R1 BF 0103
    Coding: 00003
    Shop #: WSC 00000
    VCID: 2D5AF5F3E712DB56C6-4B00
    Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
    Part No: 4B0 820 043 AD
    Component: A6-Klimavollautomat 0105
    Coding: 00010
    Shop #: WSC 02325
    VCID: 5CBC6837CC2862DE61-2580
    Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
    Part No: 4Z7 959 655 E
    Component: Airbag 8.4E 4000
    Coding: 0000307
    Shop #: WSC 02325 785 00200
    VCID: 51A28903CBEADFB682-513C
    Address 16: Steering wheel Labels: 4B0-907-487.lbl
    Part No: 4B0 907 487 H
    Component: Lenkradelektronik D00
    Coding: 01012
    Shop #: WSC 02325
    VCID: 3162E983FB2ABFB6E2-522A
    1 Fault Found:
    01305 - Databus for Infotainment
    80-00 - Single-Wire Operation
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 981 P
    Component: KOMBI+WEGFAHRS. VDO D09
    Coding: 06264
    Shop #: WSC 19411
    VCID: 336EE38B01368DA690-513C
    1 Fault Found:
    01311 - Information Data Bus
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 E
    Component: - 2C1A1 D040
    Coding: 25500
    Shop #: WSC 09999
    VCID: 4796A75B65AE1106DC-513C
    1 Fault Found:
    01772 - Signal from Level Control Pressure Sensor (G291)
    27-10 - Implausible Signal - Intermittent
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 J
    Component: Central Lock/Alarm D35
    Coding: 15885
    Shop #: WSC 02325
    VCID: 3064EC87F020B6BEED-4EE6
    5 Faults Found:
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00668 - Supply Voltage Terminal 30
    07-10 - Signal too Low - Intermittent
    01561 - Rear left door
    59-10 - Can't Unlock - Intermittent
    01573 - Alarm triggered by Door Contact Switch; Rear Left
    35-00 - -
    Address 36: Seat Mem. Drvr Labels: None
    Part No: 4B0 959 760 B
    Component: Sitzmemory R1 F 0102
    Coding: 00001
    Shop #: WSC 00000
    VCID: 2C5CF8F7DC08D25ED1-4AE6
    Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
    Part No: 4B0 951 178 A
    Component: Innenraumueberw. D04
    Coding: 00102
    Shop #: WSC 02325
    VCID: 26480ADFC2E4E80E07-5178
    2 Faults Found:
    01349 - Alarm via Theft Warning System; Front
    35-00 - -
    01350 - Alarm via Theft Warning System; Rear
    35-00 - -
    Address 55: Headlight Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D07
    Coding: 00030
    Shop #: WSC 02325
    VCID: 040C70571418FA1E79-4B64
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 4B0 035 195 J
    Component: symphony II NP2 0008
    Coding: 00201
    Shop #: WSC 00000
    VCID: 275607DBC5EEF1063C-4EB0
    1 Fault Found:
    01336 - Company Data Bus for Comfort System
    Address 76: Park Assist Labels: 8Z0-919-283.lbl
    Part No: 8Z0 919 283
    Component: Parkingsyst. A6 RDW D08
    Coding: 01186
    Shop #: WSC 02325
    VCID: 0200764F0E0CF42E4B-513C
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    End-------------------------(Elapsed Time: 04:38)--------------------------
    Established Member Two Rings S6XTC's Avatar
    Jan 17 2015
    Christchurch, New Zealand
    First thing I'd do is clear all codes and see which ones return after awhile... It looks like you have a issue with one of the micro switches in the rear left door which is probably triggering all/some of the alarm faults... I managed to pull mine apart and found the rubber boot on the lobe jamming one of the micro switches so it thought the door was always open... Another thing I've found with these cars is bad earths (grounds) can cause all sorts of electrical issues... start at the battery terminals... clean them give them a light sand if need be and make sure they are tight! Pretty much look for any strap anywhere that mounts to the body, make sure its bare metal under the terminal and that its tight... A friend of mines C6 was showing about 20 faults which all went with clearing codes and cleaning all the earths!! Mind you his battery terminals weren't even finger tight!
