Originally Posted by
c0ntract_thrill
I know Mr. Lahey in real life haha
As for the rest of your comments, I have read your posts and there is some great information but I disagree with some of your points related to earlier posts on blending.
Well thanks for the kind words and may I ask as to where and how you came to know the real Mr. Lahey?
c0ntract_thrill
First I agree, occasionally using MMT for "octane boosting" is probably not going to cause your valve train to fail, but it will hurt your 02 sensors for certain.
Interestingly enough, I really didn't see much, if any information about O2 sensor failures in the research articles that I examined. Not to say that it can't happen, but most of the concerns seemed to center around spark plugs and the catalytic converters. To summarize the research, there was one test conducted by Ethyl which indicated that concentrations of 8 to 16 Mn/L could impair O2 sensor function. However, the two subsequent studies did not find any evidence of O2 sensor function impairment.
http://www.cvma.ca/eng/publications/...MMT_072402.pdf
http://www.theicct.org/sites/default..._ICCT_2004.pdf
Here's the quote from the CVMA study "
The limited available data regarding MMT impacts on oxygen sensor performance indicate that MMT has the potential to adversely affect sensors, but do not prove that low
level (8.3 mg Mn per liter) MMT use adversely impacts the performance of current sensors."
Now, as I said earlier, just because the studies found little evidence that MMT impaired O2 sensor function doesn't mean that it's not a risk. I would say that the biggest issue with the study results is due to the years that they were conducted, they were likely testing narrowband O2 sensors. It's entirely possible that MMT could have a greater effect on wideband O2 sensors. However I haven't been able to find any research articles to confirm nor deny this.
What I would invite you to consider is this, up until very recently, MMT has been used between 8 Mn/L and 16 Mn/L (the latter number in Canada at least) concentrations and has been used to power hundreds of thousands of vehicles. If the effects of MMT were as severe as some claim, you would think that these vehicles would be suffering O2 sensor failures in droves. However, that doesn't appear to be the case.
Again, I want to be clear, I'm not suggesting that MMT poses NO risk to your sensors. However when I look at the research, and the fact that MMT has been (and still may be) used for years with O2 sensor equipped vehicles, you would think that somewhere along the lines, researchers would have been able to show a causal link between MMT and sensor failures and that doesn't seem to be the case.
c0ntract_thrill
If you have a 91 octane tune, putting 93+ octane in will only yield a small increase at best, the ECU thinks it is only going to be seeing certain fuel parameters and will not exceed those on a factory ecu. So putting C16 into your car with a stock tune will probably due jack squat compared to running 93 pump. You have to be able to make use of the fuel, the car must be tuned for it.
This is what I was referring to when I asked you to have a re-read of what I had posted earlier. No biggie tho
If you look at my logs, you can see that my car was pulling up to 5 degrees of timing on the stock ECU tune on 94 octane at around 0C no less. That's power that you would get back even with the stock tune.
As well, you don't need a new ECU tune to take advantage of a higher octane fuel even if you aren't pulling timing on the stock ECU settings. You can always add timing in 0.75 increments with Unisettings/Lemmiwinks.
With respect to my own vehicles I've spent hundreds of hours over the last 4-5 months developing winOLS definition files for both 3.0 V6 and 4.2 V8 and teaching myself how to tune ME7 vehicles. So while I may choose to buy a tune from a vendor, it's not necessary if I wanted to take advantage of higher octane.
c0ntract_thrill
In terms of you running lean, that has nothing to do with the octane level of your fuel, if you were too low in octane (which is impossible on 94) you would get knock, and your engine would pull timing. I would be amazed if your were actually running lean on a factory tune (unless you have a leak post MAF), the ECU can compensate for a lot of factors.
I realize that my running lean has nothing to do with octane. As I had indicated in post #4 the stock ECU is the reason that the engine runs lean. What I was saying is that I think that part of the reason that i was pulling timing is because you go into peak load @3000 RPM at about 13.5:1 AFR and it doesn't raise above 13:1 until after 6000 RPM. Factor in the fact that stoich decreases to 14.2:1 with E10 and that means that you're running even leaner than that.
Stock fueling
10 * * *20 * * * 40 * * * * 60 * * * 80 * * * * 100 * * * * * *% LOAD
1.00006 1.00006 1.00006 1.00006 1.00006 0.91412 *520 RPM
1.00006 1.00006 1.00006 1.00006 1.00006 0.91412 *1000 RPM
1.00006 1.00006 1.00006 1.00006 1.00006 0.91412 *1520 RPM
1.00006 1.00006 1.00006 1.00006 1.00006 0.91412 *2000 RPM
1.00006 1.00006 1.00006 1.00006 1.00006 0.91412 *2520 RPM
1.00006 1.00006 1.00006 1.00006 1.00006 0.91412 *3000 RPM
1.00006 1.00006 1.00006 0.97663 0.96100 0.91412 *3500 RPM
1.00006 1.00006 0.98444 0.95319 0.94537 0.90631 *4000 RPM
1.00006 0.97663 0.95319 0.93756 0.92975 0.90631 *4520 RPM
1.00006 0.97663 0.95319 0.92975 0.91412 0.89850 *5000 RPM
1.00006 0.95319 0.93756 0.92193 0.90631 0.88287 *5520 RPM
1.00006 0.93756 0.92193 0.90631 0.89068 0.88287 *6000 RPM
1.00006 0.91412 0.88287 0.89068 0.88287 0.86724 *6520 RPM
1.00006 0.90631 0.87506 0.85943 0.85162 0.85162 *7000 RPM
1.00006 0.90631 0.86724 0.85162 0.85162 0.85162 *7520 RPM
However, my understanding is that on a N/A engine, you should richen up to about 12.5:1 (0.85V) at peak torque then lean out to about 13:1 - 13.5:1 as the revs rise towards redline.
My revised fueling settings
10 * * *20 * * * 40 * * * * 60 * * * 80 * * * 100 * * * * * *% LOAD
1.00006 1.00006 1.00006 1.00006 0.92975 0.85943 *500 RPM
1.00006 1.00006 1.00006 1.00006 0.92975 0.85943 *1000 RPM
1.00006 1.00006 1.00006 0.96881 0.89850 0.85943 *1520 RPM
1.00006 1.00006 1.00006 0.93756 0.86724 0.85943 *2000 RPM
1.00006 1.00006 1.00006 0.92975 0.85943 0.85943 *2520 RPM
1.00006 1.00006 1.00006 0.90631 0.84380 0.84380 *3000 RPM
1.00006 1.00006 1.00006 0.89850 0.84380 0.84380 *3520 RPM
1.00006 1.00006 0.98444 0.89068 0.84380 0.84380 *4000 RPM
1.00006 0.97663 0.95319 0.88287 0.84380 0.84380 *4520 RPM
1.00006 0.97663 0.95319 0.88287 0.85943 0.84380 *5000 RPM
1.00006 0.95319 0.93756 0.88287 0.85943 0.85943 *5520 RPM
1.00006 0.93756 0.92193 0.88287 0.86724 0.85943 *6000 RPM
1.00006 0.91412 0.88287 0.88287 0.86724 0.85943 *6520 RPM
1.00006 0.90631 0.87506 0.86724 0.86724 0.86724 *7000 RPM
1.00006 0.90631 0.86724 0.86724 0.86724 0.86724 *7520 RPM
So with the stock fueling settings between 80-100% load you get:
(I have included values for both Ethanol free E0 and 10% Ethanol E10)
13.43:1 (E0) / 13.93:1 (E10) @ 3000-4000 RPM
13.32:1 (E0) / 13.82:1 (E10) @ 4000-4500 RPM
13.20:1 (E0) / 13.70:1 (E10) @ 4500-5000 RPM
12.97:1 (E0) / 13:47:1 (E10) @ 5000-6000 RPM
Finally, the reason that I'm not using the Fury 99 Oct that I can buy at AFD Petroleum is 1) because it's a 50 min round trip from my house and I'm hardly never on that side of town 2) I have to be there between 9-5 Monday to Friday.
