Results 1 to 13 of 13
    Oct 22 2005
    Reppin the Mitten.
    Air Ride Preferences - Accuair / Airlift / Etc - Issues, drivability, maintenance
    I've been doing some reading for the kits, and it appears there is a widespread of different opinions on which "kit" is better. I've searched, and there is a compilation thread, but nobody really posts about what it is like to daily drive a air ride kit, the maintenance it requires to keep it trouble free etc etc. So here I ask this, what are some of the issues people have experienced when they daily drive their bagged cars? Do you run more water traps for winter? Did you have any leaks? How was customer service with the companies you worked with?
    So lets go by this platform -
    1) What kit do you have?
    2) Ease of installation?
    3) Product Support?
    4) How many miles on setup?
    5) Issues experienced?
    6) Maintenance up keep for the duration of miles?
    7) Additional info that you find useful?
    I like info, and sorry if there already was a thread exactly like this, but I've searched on our site, and google and didn't find much. So lets see what people have to say here!
    Vince
    Jun 14 2009
    Marietta, GA
    Airlift performance struts with Airlift 3P management
    Easy
    3) Product Support?
    A+
    5K+
    none
    none
    Veteran Member Three Rings bakerrrr's Avatar
    Apr 01 2014
    2016 Silverado
    1) what kit do you have?
    Airlift Struts & Airlift V2 Management
    Not a hard install if you've done suspension work before, just takes time to complete
    3) Product Support?
    Met with them in SEMA about a week ago and gave excellent info on all my questions, called two days ago about replacement bushings and they where great with support.
    10/10
    About 1000
    What I think is a bushing failure in the front struts, common problem with their kit but they just came out with a new redesigned bushing.
    Haven't done any other than emptying my water traps once a week.
    Make sure to look for leaks on the tank and fittings, the first tank I had (accuair 5 gallon) had a leak in a weld.
    Bagged Moonlight Blue S4 / CTS Turbo Intake / Air Lift 3P / HRE 540R / Custom Exhaust /
    Veteran Member Four Rings Just A B8's Avatar
    Sep 29 2012
    is Messy!
    Northern NJ
    Quote Originally Posted by bcg717 View Post
    Easy
    3) Product Support?
    A+
    5K+
    none
    none
    How do you like your 3P management? The new version have better bushings than the crap ones that came with the older model?
    B8 A4 | PRESTIGE | S-LINE | SPORTS PACKAGE
    034 | AIRLIFT | AFE | APIKOL | APR | AVANT GARDE | AWE | BILSTEIN | DEFI | DEVAL | EUROCODE | HOEN | ROC-EURO | SPC | VIAIR | XPEL | YAKIMA
    Apr 01 2014
    2016 Silverado
    Quote Originally Posted by Just A B8 View Post
    Can't speak on 3P, I did play with the 3H (height and pressure) at SEMA and it was a great product and best bag for your buck when it comes to height and pressure based management.
    IMG]https://images.tapatalk-cdn.com/15/11/18/3162457cae498ff479ddd6eb95d01785.jpg[/IMG]
    New updated bushings, i called in 2 days ago so hopefully these will be coming in the mail and not the same ones as before
    Apr 01 2014
    2016 Silverado
    Jun 14 2009
    Marietta, GA
    I like the 3P alot. Its way more accurate than V2. I have been selling alot of 3P and 3H kits to people upgrading from v2 and elevel.
    Sep 29 2012
    is Messy!
    Northern NJ
    1) What kit do you have? Airlift Performance w/ V2 Management
    2) Ease of installation? Got it installed by a pro so no comment
    3) Product Support? I heard they are good but didn’t need any as of to date
    4) How many miles on setup? 8k ish
    5) Issues experienced? Had a leak on the line once but that’s common and it never happened again
    6) Maintenance up keep for the duration of miles? No maintenance but just release anything in the water trap in the winter once a week
    7) Additional info that you find useful? I’d recommend this kit!
    Senior Member Two Rings gstno1's Avatar
    Oct 10 2011
    Carrollton, TX
    Air ride can be tricky. I tell EVERYONE who is doing research and thinking of doing the install. Do it right, DO NOT GO CHEAP!! After all, you are messing with your suspension!
    If you do not have the money for the "high end" system. I suggest saving up and doing it right. People who have issues with air usually have skimped on
    components,have cut corners on installation or have went the cheap route. If you do this... YOU'RE GOING TO HAVE A BAD TIME. Your suspension is a VERY integral part of your vehicle. You do not want to go with a air system if you are not 100% committed on doing it right the first time. I have had plenty of friends who have done this very same thing after my warnings. Only to spend even more money in the end to get the right components.
    1) What kit do you have? Accuair E-level Management (with remote) and Air Lift Performance struts/bags
    2) Ease of installation? I send all my vehicles into my local Accuair/Airlift vendor for a proper installation. On the off chance you are the DIY type of person, both companies have easy step by step instructions that are very clear to follow.
    3) Product Support? 100% Accuair team is always on point, and supportive. It's rare to find a large operation such as Accuair that still has a family vibe, they are really easy to talk to and will go the extra mile to help. Airlift knows everything and anything about your bag setup and how it should operate. They are easily excess able as well.
    4) How many miles on setup? Currently on my TTRS around 2,500. But tally up my other builds and it's well over 50k on air ride.
    5) Issues experienced? In the past on other builds the only real issue I used to have (and it really wasn't bad) were the Accuair E-level arms. They used to break sometimes, when the suspension took a decent pot hole. The system still functioned when it broke a sensor just the pre-programed ride heights were unavailable. But Accuair has since corrected the problem with their new upgraded stronger arms. And in the TTRS I have yet to have any kind of issue.
    6) Maintenance up keep for the duration of miles? Really none. Again, if you spend the money and do it right, there is really no maintenance or upkeep. The only thing I maybe suggest for colder climates is to drain the water. As with any air system condensation will build up. I live in Texas and we don't have may issues with temperatures that really effect the system.
    7) Additional info that you find useful? Air ride is absolutely amazing when done right. It affords the driver the luxury of not having to worry about hazardous roads and conditions all while maintaining that dropped look we all enjoy. Not to mention the adjustable ride hight and in most cases saves your car from needing extensive body work due to your drop too low. And for me, that is priceless.
    The 3 cars that have all had the setup!
    Wait......what goes here?
    Jan 26 2015
    OC
    Quote Originally Posted by vinny.dtw View Post
    Vince
    Full AccuAir B-8 Sport kit, E-Level and I upgraded the factory dampers to Bilsteins.
    One word - BODEN - I am not the most technical individual so I chose to go to a local shop and have it taken care of. From what I understand in talking with AccuAir and the shop the B8 Sport Kit is a total solution product and is designed specifically for this application, so I would imagine that if you were a mechanical sort, installation should be pretty straight forward.
    3) Product Support?
    I have not had issue one with the system, but both the manufacturer and installation shop were amazing when I was doing my research. I had a lot of questions and wanted to ensure that I was getting exactly what I was looking for.
    7K Lots of road trips, including dirt roads to access trails, both hiking and MTB.
    Not one problem
    tap the water trap valve every couple of weeks.
    Bottom line is ask a lot of questions make, sure you are comfortable with YOUR decision. I would not change a thing with my set up and highly recommend to anyone interested.
    Jeff
    Oct 22 2005
    Reppin the Mitten.
    I'm just new to air ride, and wanted more of a concensus from all for the platform. After talking to many, it seems like I'll be fine with either air lift or accuair. But keep the reviews coming. I think it's beneficial to all for people that are deciding on a nice set of coilovers of bags.
    Established Member Two Rings Jsivadas's Avatar
    Sep 27 2013
    Airlift performance struts with Accuair E-level Air Management System
    Easy
    3) Product Support?
    A+
    5K+
    None
    None besides adding a cap full of airline anti-freeze in my tank(winter drive my car)
    Instagram: jsivadas
    Jan 16 2014
    United States
    Where should I get an alignment?? Every time I go somewhere they say they can't do it because the claps won't fit because the fender is in the way.
    Sent from my SM-N920V using Tapatalk
