Results 1 to 13 of 13
    Nov 14 2015
    Unhappy coolant leak - opinions please :)
    Since a few days I had some issues with a leaking coolant system (I have a '08 A4 B7 2.0TFSI), tonight I finally had the time to put some uv dye into the system and fire up the uv lamp.
    I personally think it's the coolant flange but please give me your opinions
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Is that a blacklight?...trippy.
    Senior Member Three Rings Ori0n's Avatar
    Sep 26 2010
    Saskatoon, SK
    Neat trick with the uv light!
    Would definitely be your coolant flange. I wouldn't wait fixing it. I know if you let this go too long on a 1.8T you eventually soak your clutch in coolant and that's never a good thing. I did this on my 1.8T, took an afternoon and it's pretty much blind back there so you do it all by feel.
    If you don't feel like cursing at your engine for a few hours take it in to the shop! It's worth it.
    2004 Audi A4 Avant 1.8TQM - Stage 2+ [ SOLD :( ]
    2007 Audi A4 Avant 2.0TQM - OEM+
    May 22 2010
    N.E. Connecticut
    It's one of the main fails on the 1.8T motors that T shaped flange crystalizes over time from the motors heat. Once the molecular structure changes, the flange is no longer able to expand and contract with changes in temperatures thus cracks form as the flange disintegrates.
    I have also had that problem with my A4. Solution is to replace the flange but at the same time inspect all other hard to reach connections in the rear of the motor and replace them. If one is gone, the others are not far behind.
    You could also insulate the flange from excessive heat with header shield cloth or one of those little snap on blankets that Audi installs on some of the wiring behind the motor in the B6 S4.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    Yep, most likely the coolant flange. Cheap part, a bit of a pain to replace.
    Aug 04 2015
    Kansas City
    After you replace it, flush out that nasty green coolant and replace it with the proper G13 pink stuff. I heard that the green fluid is bad for aluminum engine blocks.
    Nov 14 2015
    Quote Originally Posted by KJack View Post
    I already use the pink G13 stuff; the yellow crap is the uv dye I bought from autozone. The label said I should use 1 oz for two gallons of coolant; given how well it worked I now would recommend 1/2 oz for two gallons of coolant.
    Aug 04 2015
    Kansas City
    Quote Originally Posted by H3ndr1kD View Post
    Oh cool. The photos threw me off when I saw the fluorescent green! Yes, I'd say the dye works great. I'm going to keep that stuff in mind!
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    It's either the coolant flange or the coolant temp sensor is also back there. Super easy to check the coolant temp sensor to rule that out.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Nov 12 2015
    Orange County
    +1 on coolant flange. You'd think VAG would make these out of metal...
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    Its your coolant flange 100%.
    Feb 21 2015
    Ohio
    Feb 21 2015
    Ohio
    Didnt see any comments my bad for the late response.
