Page 1 of 3 123 LastLast
Results 1 to 40 of 95
    Aug 06 2012
    Parker, CO
    2.0T Gas Powered Cars- Recall
    SHOULD READ "CARS" --- NOT CALLS. Posted via Tapatalk on my iPhone and damn auto-correct messed with it and I hit submit. If a moderator could fix the title - I would appreciate it.
    Heads up folks. A new recall for 2.0T powered cars was released on Friday November 13th.
    The recall is on the pressure relief valve for the engine crankcase. I found out when I dropped off my allroad this afternoon for something else.
    I did get a VERY nice 2016 A6 for a loaner. Thank you Prestige Imports!
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I did not receive any such recall. Do you have something that shows more detail?
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    yea i didnt get anything either. What exactly was the mechanical issue? Symptoms?
    Also was that A6 the 252 hp 2.0T? If so, what did you think of it?
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Mar 17 2014
    Los Angeles, CA
    JK, Just found it on their website when I ran my VIN.
    Service Campaigns
    Service campaigns shown may be available for a limited time only. Please contact your authorized Audi dealer for additional information.
    see details Crankcase Pressure Regulating Valve REPAIR NEEDED
    START DATE
    Nov 10, 2015
    AUDI ACTION CODE
    17F9
    DESCRIPTION
    On certain Audi vehicles with 2.0L TFSI engine, the diaphragm of the crankcase pressure regulating valve may have been damaged.
    REMEDY
    Inspect and, if necessary, install a repair kit for the crankcase pressure regulating valve.
    instagram
    May 10 2015
    Pittsburgh PA
    Is this only for the 2013+ B8.5 cars?
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by 19birel View Post
    Didn't specify on the website. Just said 2.0 TFSI
    instagram
    Jan 09 2015
    North Dakota
    Mine called for a service campaign not a recall, 2012 B8. Is this the same for anyone else?
    May 29 2014
    United States
    Is that the same as breather valve or crank case valve?
    Mine just had to be replaced last week. But on my dime. I put in my VIN and my car doesn't come up.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Is this the diaphragm in the disc shaped housing on top of the PCV valve? My mom just had hers blow out in her B8.5 with 20k miles causing a vacuum leak.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Aug 06 2012
    Parker, CO
    I don't have my paperwork yet. My service adviser called it a "recall." I will likely be picking up my vehicle tomorrow, so I will post that info.
    Feb 23 2015
    2014 Audi A4
    Fort Lauderdale, Florida
    I have a 2014,CVT and according to AudiUSA's website theres no current recall or campaign open on my vehicle.
    Senior Member Two Rings McFuzz's Avatar
    Jun 20 2014
    CA Bay Area
    Interestingly enough, my car was in for a leaky valve cover seal/gasket and on the work order I did notice a repair kit for the PCV. Alas - I no longer have the stock PCV in favor of a shiny catch can :)
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by ND_audi View Post
    Same with my '13.
    Active Member Two Rings IngolstadtTech's Avatar
    Nov 05 2015
    1986 Ford Mustang Lx Notch
    Massachusetts
    Yes, Audi's crank case breather, or oil separator valve as they call it, is very prone to failing and creating vacuum leaks. I have replaced many of these both under warranty and customer pay. At least they are finally doing something about it. Although, if any of you had to pay for it you got the whole new valve assembly, Audi will only be paying for the cap, diaphragm, and spring during the recall
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    For recalls, can you still get marked TD1?
    I'm assuming so :(
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Quote Originally Posted by Smellie View Post
    I'm assuming so :(
    Sure, they will probably scan it.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Dec 12 2014
    Bolingbrook/Illinois
    I brought my car in for codes related to the pcv and the service guy told me it was a recall and would be repaired for free. However, they told me that they had to replace other parts with the repair kit and charged me the $85 CPO deductible. Not sure how true that is since I only see the repair kit and their other standard checks on the service sheet.
    2012 A4 P+ quattro S-line appearance
    Nov 05 2015
    Massachusetts
    Quote Originally Posted by booost View Post
    I have yet to scan one for only the recall. But for routine services, we usually end up scanning them abyway
    Apr 21 2015
    Quote Originally Posted by IngolstadtTech View Post
    agh.. making me worried hahaha
    Established Member Two Rings mlzervas's Avatar
    Oct 02 2009
    2009 B8 A4 Avant Gone: 03 A6 Avant- 04 350z roadster - 98 A4 1.8tQ - 03 Range Rover HSE
    Louisville, KY
    http://web.audiusa.com/recall/# Here is the website for anyone wanting to check themselves. My 2009 A4 avant is recall free.
    Aug 06 2012
    Parker, CO
    Officially Audi is calling it a 'service action' ----- not a recall.
    Repairs for effected vehicles are free.
    If you have replaced the part, Audi will reimburse you.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    ran my vin. im good.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jan 03 2013
    Baltimore
    I searched my vin, 2010 a4, nothing came up.
    Sent from my XT1096 using Tapatalk
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by McFuzz View Post
    Everything get sorted out?
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by lettuce View Post
    Did that vac leak cause the brake pedal to be stiff before startup, after the car was shut off for awhile? I have a vac leak on mine that's causing that, but haven't really gone in depth with figuring out where the leak is.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Mar 26 2012
    Charlotte, NC
    I got the Recall too
    2009 A4 2.0T CAEB Engine.
    Going Friday Morning. I'll post what they changed.
    Apr 19 2014
    Long Island
    Run my vin, sadly it affects me.
    I'll email my SA and see what he says
    Aug 06 2012
    Parker, CO
    If ots not a recall - it won't show up when you run your VIN
    Apr 19 2014
    Long Island
    Quote Originally Posted by treginginco View Post
    It doesn't show up as a recall but as a service campaign.
    May 26 2015
    Mormon Country
    Quote Originally Posted by SDF1 View Post
    Via mail or website check? My 2009 shows no open service campaigns or recalls.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Apr 19 2014
    Long Island
    Quote Originally Posted by GilliamOS View Post
    Then you should be good
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    My car has done this since I got it with 10k miles and its now at 55k, are you sure its a leak? Hopefully someone else can chime in because now I'm curious if I have a leak.
    I'm also pretty sure my last car, Nissan Armada did the same thing.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Aug 29 2014
    I'm also pretty sure my last car, Nissan Armada, did the same thing.
    EDIT : Double Post, Sorry.
    May 26 2015
    Mormon Country
    Quote Originally Posted by Townending View Post
    See, I can't remember if it was like that when I bought it back in March or not. STA4 said it was most likely a vac leak.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Senior Member Three Rings vdubtx's Avatar
    Nov 24 2014
    Rockwall, TX
    Believe I had that part replaced a week before the Service Campaign came out. Will have to check with service to be sure.
    Car ran normally with the issue, just had check engine light come on while I was travelling.
    2018 S4 Prestige, Daytona Gray Pearl, Black Optic, S Sport, Napa Leather
    2012 A4 Premium Plus, Monsoon Gray, Quattro, Navi, Push Start. VCDS mods needle sweep, windows up/down with fob, no wink turns, fogs as cornering lights.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    No issues with mine but apparently its involved. Under warranty so I'm taking it in Tuesday to be checked.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    My car has (recently) started doing this too, but I wouldn't THINK a vacuum leak at the engine would be the culprit. There is no vacuum at the engine when it's not running. The brake booster stores vacuum so it's available even if the engine loses vacuum. There should be a check-valve @ the booster, so for us to lose our boost after the car has been sitting for a bit, the leak either has to be at the check valve, or some other point within the booster.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    May 26 2015
    Mormon Country
    Quote Originally Posted by dscline View Post
    You know, you're right. There is a check valve in the plastic pipe that goes from the brake booster to the vac system on the engine. I should find a way to test that valve holding a vac outside of the car to see if it or the brake booster is the culprit.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Mar 17 2014
    Los Angeles, CA
    I just spoke with my SA and he told me there is no rush and to bring it in after Thanksgiving...?
    instagram
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Any chance you could please post the replacement part numbers for us?
