This is what the Bose enclosure looks like when you remove it.
When you remove the Bose midbass enclosure, it leaves a huge hole in the door, which you can see here.
You need to seal that hole in order to install a new speaker and have it perform well.
In my car, we used some ABS plastic and a heat gun to cut and mold a new plastic baffle that seals off that hole in the door, and then we installed an 8 inch midbass driver with ease.
The first picture also shows you the worthless Bose midrange speaker.
This picture shows a closeup of the 8 inch midbass, and it also shows you that the midrange speaker has been removed and there is no hole in the door behind it.
This is a HUUGE no-no for acoustics. The front of the speaker and the back of the speaker are never supposed to be heard together.
This pathetic Bose midrange is mounted to the surface of the door and the rear sound wave from the speaker reflects off the metal and comes right back into the car.
Terrible acoustic design.
Here is the 8 inch midbass with the door card back in place.
And with the Bose grill in place, you would never know there was an 8 inch midbass in there.....
For midrange and tweeter speakers, it will be much better to install them on the dash, like I have done here.
