Results 1 to 6 of 6
    Oct 18 2011
    2005 B6 A4 3.0 CVT, 2009 B6 A4 3.0 CVT
    Memphis
    B7 2.0 vacuum pump oil leak-which manufacturer?
    Looks like the vacuum pump on the back of my 2.0 motor is leaking quite a bit of oil. It's run down the back of the engine, and onto the transmission. I've looked at some threads here, and most people had no luck replacing the pump gasket or seal to stop the oil leak, but instead needed to replace the entire vacuum pump with a newer revision model that relocates the o-ring. I know there are a few versions available, with ECS offering the "H" revision, but wondered what everyone recommended. The pump isn't cheap and ranges from 249.95, 265.45, and 337.78 by makers Pierburg, Vaico, and Audi respectively. Any opinions?
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    Jun 17 2013
    jersey city nj
    No signs of any leaks when ed of the old motor either
    Veteran Member Four Rings brandonpham's Avatar
    Dec 06 2014
    Quote Originally Posted by vce1232000 View Post
    Which rev is this? Im about to get this off you didn't know you had it lol. I'm pretty sure mine is leaking, top of my trans is wet. i'll pull it off this week or something.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by brandonpham View Post
    Its at he garage rite now. I wont be back there until tuesday thou
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Pierburg makes our oem Diverter Valve I know that for sure, not sure though what brand is the vacuum pump, but I guess you can't go wrong with the Pierburg brand if you can find one.
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
