Results 1 to 19 of 19
    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Question Brown coolant?....
    I'm pulling my blown turbo and as I was draining the coolant I noticed that the coolant is brownish? What could be the cause of this? I haven't put coolant in this car since I bought it a year and a half ago but here is a picture of it:
    [IMG][/IMG]
    Aug 04 2015
    Kansas City
    Hmmm. I wonder if the previous owner originally had the correct pink fluid and then topped it off with the wrong green stuff. Either way make sure you flush it and replace it with G13 coolant.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Yeah looks like a mix of green coolant and rust water.
    If green coolant gets mixed with pink coolant, it will coagulate, which is why you cannot mix the two. If this is what happened, that could have caused your turbo failure as well.
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    I topped off with some green about a year ago...no problems since. And im in Florida..its wicked hawt here.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by 1killera4 View Post
    You mixed green and pink coolant?
    Jul 25 2014
    Mississippi
    Alright awesome, thanks for the quick info guys.
    Mar 18 2014
    Dunedin Florida
    Quote Originally Posted by Jake@JHM View Post
    Yea...its still pink too!
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    look like your coolant shit itself
    Oct 21 2015
    Current: 2003 A6 4.2 Widebody, 2004 A4 1.8T, 2008 A4 2.0T - Past: 1998 A4 2.8 , 2001 A6 2.7T
    Wisconsin
    Not a good idea but do what you want. Theres reasons for using the proper fluids in a car.
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Quote Originally Posted by Flotronux View Post
    In hot climates I run water, its the best and doesnt pollute. Get some distilled and call it a day.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Mar 18 2014
    Dunedin Florida
    I'm glad you feel that way because I did.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    I'm not so sure that straight water is such a good idea. Antifreeze not only lowers the freezing point of the water-coolant mix but it considerably raised the boiling point at well. These cars run hot, especially in summer and in the warmer climates. The coolant temperature can occasionally exceed the boiling point of water. I would not advise doing this. Straight water, especially distilled water, contains no corrosion inhibitors so all metal contact surfaces are subject to corrosion.
    Veteran Member Three Rings cheemn's Avatar
    Jan 21 2010
    bunch of parts
    New Fairfield, CT
    Flush your fluid ASAP and put the proper coolant in. Its almost obvious as stated above someone mixed in the wrong coolant. There is a reason we "have our "pink" coolant. But again as stated people are free do what they want on their own cars. Problem is this. German cars are not "bullet proof" like Japanese cars can be.
    Oct 24 2015
    Perth, WA
    This is a bad idea. Water, even distilled, quickly dissolves metal ions and can start galvanic corrosion. Also, as stated, the colligitive properties of coolant not only lower the freezing point but raise the boiling point. Straight water is a bad idea.
    My respray thread
    Dec 05 2007
    lol at this thread. Why not throw some Gatorade in the reservoir while you are at it. That stuff is chock full of electrolites, which everubody knows cars love.
    Sep 30 2009
    Indiana
    Gatorade is not a good idea. It's known to adversely affect turbo performance. Jim Beam on the other hand...and it's about the same price as G13.
    Dec 05 2007
    Then that car can never be designated driven
    Mar 18 2014
    Dunedin Florida
    Patron for me.
    Aug 31 2011
    Lathrop
    I thought it was plants that loved electrolytes
