Results 1 to 14 of 14
    Active Member One Ring WYSEguy84's Avatar
    Aug 07 2014
    California
    A/C Vent Stuck - Motor or flapper access
    I have a 2008 B7 A4. The center HVAC vent seems to have gotten stuck in the off or closed position. Any feedback on how to access the flap or motor to the flap? Can I just reset the system somehow?
    Any and all feedback appreciated.
    Oct 16 2008
    South Florida - Ft Lauderdale
    Front flap is item #10. Do you have access to VAGcom to run a test?
    Phil
    Aug 07 2014
    California
    Phil
    Thanks Phil,
    I may be able to get access to VAGcom. However, if not, what recommendations would you have for me in order to move forward?
    Oct 16 2008
    Quote Originally Posted by WYSEguy84 View Post
    Thanks Phil,
    Not many solution other than pull the dash if you have a flap issue
    If the culprit is the motor, you can access it from the driver side
    Reason why I would perform first a test output of the motors to figure out what is going on exactly
    Phil
    Aug 07 2014
    California
    Phil
    Alright, I'll try running a test first and go from there.
    Thanks Phil
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Did you drop anything down the vent?
    Run the flapper test via vag come first but if that doesnt work...
    weird story time.
    When i bought my b5 audi s4, the car had a APR vent boost gauge. Ever since i had the car the ac never worked so i literally replaced every single part of the ac system and it still never worked right. It got to the point where i had no other options but to tear the dash apart. Iit turned out that while the previous owner was installing the APR vent boost gauge, he dropped a flashlight into the vent and never mentioned this to me. the flash light was stuck inside the vent and not allowing the flapper to close shut.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    When you direct the flow to the top or bottom, does the two sides (6 & 4) closed or stays open as always?
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Aug 07 2014
    California
    Quote Originally Posted by nizmosx View Post
    weird story time.
    I did not drop anything down the vent. Air just stopped coming out. I'm hoping its just a stuck flap.
    Aug 07 2014
    California
    Quote Originally Posted by 80sGuy View Post
    When I direct the flow to top or bottom, side vents (6 &4) work exactly as they should. It is just the middle vent 5 that isn't working properly.
    Oct 09 2007
    Miele S7
    ^^Do they shut or stay open all the time?
    Aug 07 2014
    California
    Yes, they stay open all the time.
    Oct 09 2007
    Miele S7
    ^^Well, at least that part is working correctly. Hope you tackle the issue with the center ones.
    Aug 07 2014
    California
    Ended up just being a bad vent motor. Bought one on ebay and all works fine.
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    Damn...a year and half later? lol...I have the same issue, how hard was it to change out?
