Results 1 to 12 of 12
    Mar 29 2012
    SF
    Constant beeping from stereo speakers
    The entire time I've owned this car *3 weeks*, it's had this annoying beeping sound coming from the speakers. It's always there unless I turn the head unit off. Even when the stereo is on but the volume is off the beeping is constant and the volume of it never changes no matter how high or low the music volume is. The beeping almost sounds like morse code it's so strange. I've searched this on the forum and online and other ppl have had this issue but as far as I can tell nobody ever found out what the cause was. My guy at the car audio shop has no clue either. Help?
    Oct 24 2015
    Perth, WA
    Check your ground wires. Remove the head and inspect the wiring to ensure your antenna and other cables are good. You're probably picking up erroneous signals due to poor earth or other issues with the receiver.
    My respray thread
    Established Member Two Rings redbat's Avatar
    May 23 2015
    Santa Cruz, CA
    Quote Originally Posted by inked_up415 View Post
    Do you have any CDs in the changer? If so, try ejecting them all and see if the sound is still present.
    The Garage:
    2005.5 Brilliant Black A4 Quattro 6spd manual / JHM Stage 1 / 034 snub / NewSouth Vent Boost Gauge / GFB DV+ / JHM Lightweight Flywheel Clutch Kit / Koni FSD / Eibach springs
    2008 Dolphin Grey S-Line Avant
    Mar 29 2012
    SF
    No CDs in changer
    Mar 29 2012
    SF
    Can anyone help me? I really don't want to have to replace the head unit.
    Oct 24 2015
    Perth, WA
    Dis you try what I said?
    My respray thread
    Senior Member Two Rings JMVant's Avatar
    May 27 2007
    Do you hear the beep when you are not in the car? Maybe its in your head.😠 joking.
    Check your Bluetooth settings on your phone. I had connect disconnect sound when I had cell on power save mode.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    __
    B7 A4 S-Line
    Current project
    Mar 29 2012
    SF
    The Bluetooth is off. And as for removing the headunit, no I didn't do that yet. I'm no car stereo expert and would leave that to a professional. I was just hoping that someone else had encountered this and could speak from experience. I know it's pretty random.
    Oct 24 2015
    Perth, WA
    Its not random, your earths or RCA grounds are wrong thus you're picking up transient signals from other sources that go through the amp without any regard to settings or channel selection. Half-split method.
    My respray thread
    Mar 29 2012
    SF
    Ahhh okay. Your probably right. I'm just holding off on paying someone to remove the headunit till I buy a new one. Thanks
    Oct 24 2015
    Perth, WA
    No worries, good luck.
    My respray thread
    Sep 02 2008
    Boonies VA
    Why are you paying someone to remove the headunit???? They literally slide out and then it's 2-3 plugs on the back, even if you don't have the specific Audi keys to remove the head unit itself you can pick them up cheap or make some out of metal file hangers. This guy had the same issue and it was the CD changer:
    http://www.audiforums.com/forum/audi...e-wierd-17959/
    White Wagon
