Results 1 to 30 of 30
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    took off the clear bra wrap on my 2012 today. was not a pretty sight underneath
    I was always suspicious of these wraps and clear bras causing more trouble than they saved. the front of my car was covered in one when I got it, going to about 30% of the way back on the hood. looked kind of stupid to me, and I decided today to try and finally remove it. the two parts on the front areas of the fenders were not bad to get off, and only left a little adhesive. But the large hood area was a real mess. that adhesive does not want to come off after being on their 4 years baking in the sun and being heated by a 3 liter SC engine. after a few quarts of goof off and 3m adhesive remover, I got most of it, but the adhesive had reacted with the clear and edged marks and patterns on it. lucky for me, I spent the last 27 years painting and polishing classic cars for a living, so I color sanded the hood with 1500, and hit it with Menzerna's Power Gloss polish and a couple of finishing polishes afterwards. it was not easy to get the marks out and to make the main line go away, but I was able to get it done.
    think twice before using these clear bras.
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Looks good.
    Come to Colorado and experience one good winter here without a clear bra. Needless to say, sand on the roads does much more damage than a clear bra ever could.
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    Apr 05 2009
    SF BayArea
    I guess if you live in a place that gets real winters, that may make some sense.
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Quote Originally Posted by evil_O View Post
    Looks good.
    +1. Clear bra the side mirrors, too. Winters here are hell on the windshield, too.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Veteran Member Three Rings audinator's Avatar
    Nov 17 2005
    B9S4, 91 CRX, 85 CRX, 17 Thundra
    SoCali
    I've always been concerned about that with these clear bras, glue baking in the sun! Especially on black!
    Glad you got it sorted, beautiful S4!
    2018 B9 S4 Daytona Gray | Rotor Gray
    . . . and many other Audi's over the years . . .
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    When the Xpel started to yellow on my last car I got it replaced under warranty. The installer had no issues removing the original film. Also you don't need winter to appreciate PPF. Highway driving with any level of road construction is enough to value PPF even in FL. My last car without it had paint chips all over the front bumper and front portion of the hood.
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Anyone think the brand of the clear film makes a difference?..
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    This is why my installer will be removing if needed....
    [B]Current: Shopping now....
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    After 4 years my 3M clear bra is horribly swirl marked and looks like garbage. I'll be pulling it all off next spring and enjoying my car "naked" for the rest of the time I own it. Not looking forward to the labor of removing the adhesive that doesn't pull off though.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    I've been using and removing them for over 15yrs with never a problem. Can't comment on your product used, but I've used 3M in the past and Premium Shield Elite recently. Last cars I've removed had them on their for over 10yrs. My old Minivan by brother in law now owns was a 2003. My 2002 Trailblazer which was black, the second owner had it removed after 8yrs in prep to sell it. I've also re-done a couple, mainly on the front bumper of my past cars, only because they too can take a beating with sand and grit in winter here in Ohio.
    Heat gun, go slow and then solvent to remove the residue. Pretty much the reverse of putting it on.
    Glad it worked out well for you. I personally love them. Way better than having to respray and match colors, etc. in Cali, can't comment on their need, unless perhaps you do lots of highway driving.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Wouldn't a steamer make it easier?
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Apr 05 2009
    SF BayArea
    I have removed many stripes , decals, and window tints in the past without much issue, and figured this would be similar. For some reason, the adhesive on the hood really became hard though and was the hardest thing I ever tried to remove from a paint finish. Pretty much nothing I tried on it barely affected it, and at one point I was starting to think the front hood would need a respray. I ended up soaking it with adhesive remover, (big mess) and then using an old credit card to scrape the worst of it off. the goof off rubbed hard with a rag slowly got the rest. Took a few hours of tedious messy (and stressful) work. the parts on the fenders came off with the heat gun much better, and left little residue, so it must be a time + heat related issue.
    I wanted to remove it because it was already starting to look wonky and uneven, and recently some areas had gotten discolored.
    it was the fact that it left a pattern clearly edged in the clear on the hood that pisses me off--I have hear the wrap suppliers clearly deny anything like that can ever happen on a factory finish. If it would have been on much longer, I am not sure that the main line it left where it ended on the middle of the hood would not have been able to be fully color sanded and polished away either.
    Nice side affect, my front hood looks way better than any factory finish can with a color sand and buff. show quality gloss on it now. No robot can spray paint as good as a hand rubbed finish by someone who knows what they are doing..
    I'll never recommend anyone using clear bras around here except maybe on race cars
    Apr 05 2009
    SF BayArea
    Quote Originally Posted by saxon View Post
    that could permanently discolor the paint finish. I would not try that.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Agreed on the half hood job being stupid (compared to full), but I don't understand the general negativity here. You had to remove a bit of adhesive- big deal. At least your paint is now mint on your four year old *black* Audi.
    The clear bra should ideally not need to be removed during ownership, but still the issues you had are not at all typical of removal.
    Do you know which film was used?
    Yes, steamer is great for removal and what most professionals use.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Apr 05 2009
    SF BayArea
    It must have been on when the car was new by the PO, so I have no idea what film was used. They use steamers to remove them? that surprises me. Seen what trapped hot water vapor can do to paint finishes under plastic tarps-it can bleach and discolor the finish to where no amount of polishing will bring it back. Must be a very specific and careful technique required.
    I would have charged a client $500 for the work I had to do to remove mine and color sand and polish the hood.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by onlyaudis View Post
    Lol, no. I used a clothes steamer to loosen up the clear bra strip that was on my rear bumper to protect it from loading things in the trunk. I never scuffed it with anything in the last 4 years and it was horribly swirled. Looked like crap.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Says the guy with a perfectly finished hood. (thanks to the clear bra)
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    May 13 2011
    2015 BMW F30
    don't they sell a rubber wheel that attaches to a power tool that is used for adhesive removal? anybody ever try that?
    | Autospeed | JHM | Pure MS
    Mar 26 2010
    US
    Had Ventureshield installed on the whole front end on my S4. After 4 years a rock hit the hood & made big tear in the hood film, which looked pretty bad. I had the original installer remove and replace the ppf on the hood. When he had removed the old film, it looked perfect underneath. He put Suntek ppf on the full hood & it looks perfect, even after another 1.5 years in the sun.
    It helps to have a good installer do the work. The ppf really saved my hood.
    BMW M3 Competition X-drive
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Reminds me of what phil had to go through at detailers domain...
    "plastic razor blades, 30 or so mf towels (tossed out later as the adhesive embedded in the towels) 10 microfiber cutting pads, 4 gallons of water in the steamer, lots of blood (bloody knuckles) and blisters"
    http://www.detailingbliss.com/topic/...val-nightmare/
    Apr 05 2009
    SF BayArea
    Quote Originally Posted by Acejam View Post
    more like a perfectly finished hood from 27 years of experience color sanding and polishing out paint jobs. I should have gotten some photos of the pattern it had left on the clear--looked horrible and was pretty deep. most people would have thought they needed to have the hood repainted.
    Sep 29 2010
    Portland, Oregon
    The older 3M clear bra's were known to be a disaster, and adhesive residue causing paint damage upon removal. Wouldn't surprise me if the newer stuff is the same.
    Newer SunTek & Xpel Ultimate PPF are easily removable now.
    Dec 22 2009
    MA
    Of course it's going to need some cleaning and prep - this isn't like pulling plastic covers off a brand new car or iPhone.
    My point was simply that if your clear film wasn't present, odds are you'd have a bunch of rock chips present on the hood that *would* require paint in some form.
    Mar 01 2006
    Kitchener, ON
    you can color sand and polish out stone chips? I was always told to fix something like that you needed to repaint but I could be wrong...
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Jul 16 2015
    Scarborough, Me. NorthEast.
    3m eraser wheel works great, that's what I used to get all the hard stuck glue off when I took my clear bra off.
    It goes in the end of a drill, and does a very good job.
    I've used these for many, many years of removing badges off cars and trucks.
    Bill
    2012 S4 DSG, Phantom Black............................................. ...........................
    mods; StaSiS WC Sport Exhaust, gmg downpipes, StaSiS Challenge Suspension Kit, gmg WC Swaybar KIT front and rear, Adjustable front control arms, StaSiS 390-32mm mono6 BBK
    Revo Supercharger pulley, APR Coolant Performance System, Roc Euro intake, Revo Stage 1+, FORGELINE SC1 19x9 wrapped in Michelin PSS 255/35/19's
    1/[email protected]/[email protected]
    More to come, work in progress.
    May 13 2011
    2015 BMW F30
    Quote Originally Posted by hdmlnium1 View Post
    Bill
    that's what I was thinking. I'll be sure to look for it if I need it.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    I live in Cleveland, where we have perpetual construction and long and terrible winters. My last car I had for 2.5 years and only had 3 chips on it (2 very small, one fairly small). They were only noticeable at all because it was a black car.
    I have one toward the front of the hood on my 4 month-old S4, but it's still better than a clear bra. You think it's bad taking a clear bra off of a dark car? Try white...it discolors the paint enough that you can't really fix it without a full repaint.
    Jun 28 2012
    North NJ
    Quote Originally Posted by hotleadsingergu View Post
    Really? I just took film off both front fenders on my Ibis S4 and I see no difference at all compared to the doors which were uncovered. Car lives outside so more than enough sun baking down. Film came off easy with minimal residue after 3.5 years on. No regrets. Certainly nothing to repaint.
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Sep 21 2012
    2012 Audi Q5
    Do you do any highway driving? 3 chips in 2.5 years is extraordinary.
    2015 BMW M4
    Mar 21 2015
    Had it on my white car for 3 yrs and it showed no issues after taking it off. It was 3M from 6 yrs ago.
