Results 1 to 14 of 14
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quieting turbo spool up noise.
    I know it seems a little weird, but sometimes i wish turbo spool up noise, and dv noise were a lot quieter. Windows down, with turbo spool, but mostly air getting sucked in sounds like a turbine engine. Easy solution, just drive slower, but who wants to do that? With my current config, plus future plans, a stock air box is out of the question.
    Any suggestions?
    Are GTX's generally quieter or louder than there gt counterparts?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jun 30 2008
    Erie, Pennsylvania
    Is this post for real? "I want to make my Big Turbo car sound less Turbo-ey". lol
    I put a Forge splitter valve on my car because I wanted to hear more turbo-ish noises.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    I had the same issue with my FrankenTurbo setup while using a cone filter on 3" MAF housing.
    My solution: stock air box; much quieter. I think it unfortunate this won't be a viable solution for you, but understandable.
    Here's my take: if you can make some sort of enclosure that completely surrounds your air filter, and adapt it do the air inlet in the radiator support/lock carrier (or some other non-stock air inlet location), you ought to be able to reduce this noise greatly.
    2001 Corvette (C5) Z06
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Lots of larger turbos come with a "silencer ring". There is a lip machined on the inside of the turbo inlet, and a snap ring is installed in that groove.
    It would cost a lot and could alter the way your turbo works, but hey, its a solution.
    This one looks like it is not removable and it was just machined on the inside.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    May 16 2008
    WA
    that way when your penis grows back you can just take them off JFWY
    Apr 22 2007
    Riverbank, Ca
    Build a box for your intake. That is where 90% of the noise comes from.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    B5s are very turbine-y. I'm naturally aspirated and my car sounds like a jet engine from the drivers seat
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by andyrew View Post
    This, and line the box with foam. Sound deadening foam if you really want to go for broke.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Dec 05 2007
    Quote Originally Posted by getslideways View Post
    lol. Old B5 A4 veteran. How are things on the other side?
    Nate, post a pic of your current intake. They are right, as you need some type of sound insulation. I like custom stuff, so incan make suggestions off your current intake with basically a sound deadening intake box. Im no expert on this matter, but i like cool one-off projects.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Wait.. you have a BT but don't like the noise..?
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Nov 21 2006
    san francisco, ca
    I just enjoy the sound when wanted. Just like i like to go faster when i want. Its a sacrifice.
    Its sorta like the dude that wants to put the silencers in their fart cans.
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Jun 30 2008
    Erie, Pennsylvania
    I wish all those dudes would put the silencers in their fart cans.
    Dec 23 2009
    Boulder, CO
    Sometimes it just sounds too fast and furious. I do drive a grocery grabber.
    May 16 2008
    WA
    haha I miss my b5a4 brethren!
    The dark side can only be summed up as:
