I have the above code in ABS and tranny module. Appears to come back after erase.
What might be causing the code?
What are effects of the code?
Suggestions for troubleshooting?
Monday,19,October,2015,18:46:22:36008
VCDS Version: Release 15.7.1 (x64) Running on Windows 7 x64
www.Ross-Tech.com
Address 02: Auto Trans Labels: None
Control Module Part Number: VAWerks.com
Component and/or Version: Stg 1 2.7l5VT USA 1414
Software Coding: 00012
Work Shop Code: WSC 12345
VCID: 102F08D150EFDBBECD-5124
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU – Intermittent
Monday,19,October,2015,18:47:16:36008
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Control Module Part Number: 4Z7 907 389
Component and/or Version: ABS/ESP allrad D47
Software Coding: 06397
Work Shop Code: WSC 02325
VCID: 091925B533B5EA760A-5140
1 Fault Found:
P1850 - 35-10 - Missing Message from ECU - Intermittent
