Originally Posted by
SJorge3442
well damn. The more you know. Since I never built a car for power, I would have assumed the limited disc options for the stock flywheel is where the limit would be. Clearly with a larger clamping area and a larger disc will hold more power, but it will come at the cost of smoothness.
There are a ton of options for the stock flywheel, but they are all aftermarket.
If you were local, I'd let you drive my car with a s4 disc. It is not bad at all. Maybe try to find someone locally with a b5 s4? Some people do complain about running the LWFW because of chatter, yet I have not noticed a bit of it at all.
