It may or may not be known, however I have been tuning Subaru's and Evo's since 2005 and recently had the chance to tune a friend of mines Big Turbo B5 A4..
Built 1.8, Scatt Rods, JE Pistons (9.5:1), Cat 3578 cams (I think), supertech valvetrain, ported AEB Head, Apikol AEB Intake manifold, big FMIC w/ 2.5" piping, ATP Turbo Manifold, Custom 3" DP, Garrett GT3076R BB, Bosch 044 pump, 630cc injectors..
Im missing some things, but y'all get the point.
Regardless, We discovered on Pump gas we run out of fuel at 5500rpm if we try to run higher boost.
But currently, We're tuned at a steady 21psi, full boost comes on about 4400rpm!
Still have some other things to do to the car, going to increase the fueling capacity and injector size to hopefully run on E85.
Moving on, I can honestly say this...I will NOT be using Eurodyne for my BAT build.. The software is horrible, the features are limited, the interface is garbage, the latest update from Eurodyne doesnt allow you to Copy/paste tables so to rescale your load to higher values is now a pain staking cell my cell process which is infuriating.
You can't adjust the Voltage / offset / multiplier on the MAP Sensor so you can't even use a better MAP so you're limited to the stock 2.5bar which limits your boost reading and really fucks with the tune at times.
You cant adjust any of the sensor calibrations with exception to the MAF...which this car isn't using, we're running it Speed Density.
In Retrospect, for anybody wanting to go over the 450whp range, consider investing in a better EMS. Eurodyne will probably work just fine for most peoples 300-350whp builds, but for those who have a more hardcore end goal in mind.. dont waste the $800 on this trash.
Regardless, here's just a little sample of the progress of the tune from the second revision to the last one we finished the other night. And I'll get some pics up of the build and the car!
Ign Timing:
Car / Motor:
Enjoy!
- Dave
